Magnetic Field Question. Grade 12 Physics.
In summary, the conversation discusses a problem involving two wires, B and I, and their respective distances from point C. The equations B=U(I/2pir) and B1=B2 are used to find the magnetic fields at point C. The thumb rule is also mentioned as a method for determining the direction of the magnetic fields. The question of whether to add or subtract the B values is raised, but the correct method is not mentioned.
ampa23
Look at picture attached
I need help with part A
B=0
I = 10 A
Distance from Wire A to C is 0.05 m
Distance from Wire I to C is 0.15 m
I of wire i= ?
B= U ( I / 2pi r )
Ok so from Wire A to C
B1 = U (I / 2pi r)
B1= [2x10^-7(10)]/0.05
B1= 4x10^-5 T
From Wire B to point C
r=0.15 m
B2= U (I/2pi r)
B2= [(2x10^-7)(I)]/(0.15)
OK so in the question there going in different directions and at that point it equals 0
So do i subtract them even if the point is outside the 2 wires?
0 = B1 - B2
B2 = B1
and then solve
or would i have to add them together?
0 = B1 + B2
B2=-B1
and then solve?
Im confused since point C is outside of the 2 wires.
I know for Part B you would subtract.
Thank You
Hi ampa23 :smile:
Welcome to PF!
From thumb rule you can see that for left wire B is out of plane and for right wire B is into plane
and for your eqn, just use that their magnitudes shall be equal
ie B1 = B2
Thank you, but then for part B of this question would you subtract the 2 B values to find the Net B or would you subtract them?
:smile:
Use the thumb rule and tell me :biggrin:
loll I am guessing you subtract them :P
Think again ...
You know how to use thumb rule, right?
FAQ: Magnetic Field Question. Grade 12 Physics.
What is a magnetic field?
A magnetic field is a region in space where a magnet or electric current can exert a force on other magnets or moving electric charges.
How is a magnetic field created?
A magnetic field is created by the movement of electric charges, such as in the flow of electricity through a wire, or by the alignment of magnetic domains in a magnet.
How is the strength of a magnetic field measured?
The strength of a magnetic field is measured in units of tesla (T) or gauss (G). One tesla is equal to 10,000 gauss.
What is the difference between a magnetic field and an electric field?
A magnetic field is caused by the movement of electric charges, while an electric field is caused by the presence of electric charges. Additionally, a magnetic field can only exert a force on moving electric charges, while an electric field can exert a force on both moving and stationary electric charges.
How is the direction of a magnetic field determined?
The direction of a magnetic field is determined by the direction that a compass needle would point if placed in the field. The field lines always point from the north pole of a magnet to the south pole.
