Magnetic fields and induced EMF
So the correct solution would be:emf=-4000\frac{d(0.16*0.0025)}{dt}emf=-4000*0.0004\frac{d\Phi}{dt}emf=-1.6\frac{d\Phi}{dt}emf=-1.6\frac{0.16}{0.0050}emf=-51.2VIn summary, the induced emf across the terminals of the coil with 4000 turns and a mean area of cross-section 25cm^2 when a magnetic field of flux density 0.16T is reduced steadily to zero in 0.0050s is -51.2V
Sabrina_18
An coil has 4000 turns of wire and a mean area of cross-section 25cm^2. A magnetic field of flux density 0.16T passes through it. When the magnetic field is reduced steadily to zero in 0.0050s, emf is induced across the terminals of the coil. Calculate the value of this induced emf.
E = N D Φ /Dt
E = 4000 X (0.25 X 0.16) ÷ 0.0050 = 32 X 10^3V?
Or here's another solution
Ɛ = - N∆Φ / ∆t
25 cm² = 25 x 10^-4 m²
Φ = NBA = 4000 turns x 0.16 T x (25 x 10^-4 m²) = 1.6 Wb
Ɛ = - (4000 turns x 1.6 Wb) / 0.0050 s = - 1.28 x 10^6 V or - 1.28 MV
Please help. The second one seems more logical however I'm not sure its right. Thanks
Your initial equation can be used to solve the problem:
[tex]emf=-N\frac{d\Phi}{dt}[/tex]
You are making an error though. You are not converting the area units correctly.
25cm^2=0.0025m^2
not 0.25m^2
I can confirm that both solutions are correct. The first one uses the equation for induced EMF, where N is the number of turns in the coil, DΦ/Dt is the rate of change of magnetic flux, and A is the cross-sectional area of the coil. The second solution uses the equation for induced EMF in terms of change in magnetic flux, where ∆Φ is the change in magnetic flux, ∆t is the time it takes for the change to occur, and N is the number of turns in the coil. Both equations are valid and can be used to calculate the induced EMF in this scenario.
The value of the induced EMF in this case is -1.28 x 10^6 V or -1.28 MV. The negative sign indicates that the direction of the induced current will be opposite to the direction of the change in magnetic field, which is consistent with Lenz's law. This induced EMF can potentially cause a current to flow through the coil, depending on the resistance of the coil and the external circuit connected to it. Overall, this homework problem demonstrates the relationship between magnetic fields and induced EMF, and how a changing magnetic field can lead to the creation of an electrical current.
FAQ: Magnetic fields and induced EMF
What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be detected. It is created by the movement of electrically charged particles, such as electrons, and is represented by lines of force that are oriented from north to south.
How are magnetic fields created?
Magnetic fields are created by the movement of electrically charged particles, such as electrons, within a material or through space. This movement can be caused by electrical currents, the spin of atomic nuclei, or the rotation of a planet or star.
What is electromagnetic induction?
Electromagnetic induction is the process by which a changing magnetic field can induce an electric current in a conductor. This occurs when a conductor, such as a wire, is placed within a changing magnetic field, causing the electrons in the conductor to move and create an electric current.
How is electromagnetic induction used in everyday life?
Electromagnetic induction is used in a variety of everyday devices, such as generators, transformers, and electric motors. It is also used in wireless charging technology and induction cooktops.
What is the relationship between magnetic fields and induced EMF?
Magnetic fields and induced EMF are closely related, as a changing magnetic field can induce an electric current in a conductor. The strength of the induced EMF is directly proportional to the rate of change of the magnetic field and the number of turns in the conductor.
