Magnetic fields and superconductors
In summary, a superconductor exhibits the Meissner effect, where an external magnetic field is expelled due to the perfect diamagnetic properties of the material. The magnetic field produced by the superconducting current extends outside of the superconductor, but only at very low temperatures. When the magnetic field starts to collapse, it cannot re-enter the superconductor unless the temperature is raised or heat is applied.
Forestman
212
1. I have read that external magnetic fields cannot penetrate a superconductor. Why is this?
2. Does the magnetic field produced by the superconducting current extend outside of the superconductor? And if so, what happens when the magnetic field starts to collapse, can it renter the superconductor?
1. The Meissner effect
2. Yes it does, if i remember correctly, but I let someone else answer with more precision ;)
Thanks malawi glenn
Just add a bit Mr malawi gleen explanation,,,
1. Superconductor is a perfect dia-magnetic. When you apply an external magnetic field it will create a magnetic field that oppose the external one so it's repel the magnet. The magnetic field still remain since the free electron continues moving even there's a collision, the energy lost extremely small.
2. Yes, until you give a heat to the superconductor or bring to the room temperature. cause superconductor effect only operate at very low temperature.
Related to Magnetic fields and superconductors
1. What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be detected on a magnet or a moving electric charge. It is created by the movement of electrical charges, such as electrons, within a material or by a magnet.
2. What is superconductivity?
Superconductivity is the phenomenon in which certain materials have zero electrical resistance and exhibit perfect diamagnetism when cooled below a critical temperature. This allows for the flow of electrical current without any energy loss or dissipation.
3. How do magnetic fields and superconductors interact?
Superconductors can expel magnetic fields from their interior, a phenomenon known as the Meissner effect. This means that when a superconductor is placed in a magnetic field, the magnetic field lines are repelled and pushed to the edges of the superconductor, creating a shielded region of zero magnetic field.
4. Why are superconductors important for magnetic field applications?
Superconductors have the ability to carry large amounts of electrical current without any resistance, making them ideal for use in powerful magnets. This is why they are commonly used in applications such as magnetic levitation trains, MRI machines, and particle accelerators.
5. What are the potential future applications of magnetic fields and superconductors?
There is ongoing research and development in using superconductors to create more powerful and efficient energy storage devices, such as superconducting power cables and batteries. Additionally, the development of high-temperature superconductors could lead to their use in everyday electronics and transportation systems.
  • Atomic and Condensed Matter
