vagabond260
- 4
Consider three straight infinitely long (parallel to each other), equally spaced
wires (with distance d), each carrying a current I in the same direction.
(a) Calculate the locations where magnetic field is zero.
(b) Sketch the magnetic field line pattern.
(c) If the middle wire is rigidly displaced a very small distance x (x << d) upward while
the other two wires are held fixed, describe qualitatively the subsequent motion of the middle
wire.
Biot-Savart Law and Ampere's Law
I know the magnetic fields are zero near the wires on the sides but how exactly do i calculate that in terms of "d"?
For part (c) I was thinking since the middle wire will be pulled on both sides (to the points where the magnetic fields are zero) with equal forces it should remain stationary. But then it's not lying on the same plane as the other two wires, so does that mean it will be pulled down to the same plane?
