Magnetic flux degaussing calculations.
In summary, the flux field degaussing effect of two magnets in repelling configuration can be estimated using equations for magnetic moment and flux field, and it would take approximately 6.8 seconds for the magnets to degauss to 50% strength with a relative velocity of 1 inch per second. However, this is a rough estimate and may vary depending on the exact properties of the magnets and their configuration. Thank you for your question.
solar71
30
Hey guys.
Ok so here goes.
I want to know if there is a way to calculate the flux field degaussing effect of two magnets passing by each other in repelling configuration. Like south to south.
Lets say I have two magnets of neodymium N52 grade. Rockwell C scale hardness of 46.
Also let's say the surface gauss of each magnet is 6,000.
These two magnets pass each other once per second. With a distance of 1/8th of an inch between them. Is there a way to calculate how long it will take to degauss either of these magnets to 50% strength?
Can someone help me with at least a rough estimate?
Thanks guys
Hello, thank you for your question. The degaussing effect of two magnets passing by each other in repelling configuration can be calculated using the following equation:
F = (µ0 * m1 * m2 * v) / (4 * π * d^2)
Where F is the flux field degaussing effect, µ0 is the permeability of free space (4 * π * 10^-7), m1 and m2 are the magnetic moments of the two magnets, v is the relative velocity between the magnets, and d is the distance between the magnets.
In this case, the magnetic moment can be calculated using the following equation:
m = µ0 * M
Where m is the magnetic moment, µ0 is the permeability of free space, and M is the magnetization of the magnet. The magnetization can be calculated using the strength of the magnet and its volume.
Using these equations, and assuming a relative velocity of 1 inch per second, we can estimate that it would take approximately 6.8 seconds for the magnets to degauss to 50% strength. However, this is a rough estimate and may vary depending on the exact properties of the magnets and their configuration. It is also important to note that degaussing is a gradual process and the magnets may not lose exactly 50% of their strength after this amount of time.
I hope this helps and please let me know if you have any further questions.
Related to Magnetic flux degaussing calculations.
1. What is magnetic flux degaussing?
Magnetic flux degaussing is a process of reducing or eliminating the magnetic field in a material or object. This is commonly done to prevent unwanted interference with electronic devices or to reset the magnetic properties of a material.
2. Why is it important to calculate magnetic flux degaussing?
Calculating magnetic flux degaussing is important because it allows us to determine the strength and direction of the magnetic field in a material or object. This information is crucial for ensuring the effectiveness of the degaussing process.
3. How is magnetic flux degaussing calculated?
Magnetic flux degaussing is typically calculated using mathematical equations such as Ampere's Law or the Biot-Savart Law. These equations take into account the strength and shape of the magnetic field, as well as the material properties of the object being degaussed.
4. What factors can affect magnetic flux degaussing calculations?
There are several factors that can affect magnetic flux degaussing calculations, including the size and shape of the object, the material properties of the object, and the strength and direction of the magnetic field. Environmental factors such as temperature and humidity can also play a role.
5. Can magnetic flux degaussing be used for all types of materials?
No, magnetic flux degaussing may not be effective for all types of materials. Some materials, such as permanent magnets, are difficult to degauss and may require specialized techniques. Additionally, certain materials may have unique magnetic properties that make them more or less susceptible to degaussing.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
