- #36
- 24,492
- 15,023
Yes, indeed. See my posting #31.
vanhees71 said:where →MM→\vec{M} is the magnetization unchanged by external influence due to the presence of hard ferromagnets.
Here ## \vec{M} ## can be either a remanent=permanent magnetization that is virtually unchanged by any applied ## \vec{H} ## field, or it can be the type that is found in a transformer where ## \vec{M}=\chi_m \vec{H} ##. ## \\ ## The equation ## \vec{B}=\mu_o(\vec{H}+\vec{M}) ## works for both types. The equation ## \vec{B}=\mu_r \mu_o \vec{H} ## only works for the transformer type of magnetization. In that case ## \mu_r=1+\chi_m ##.jim hardy said:So M then is remanent magnetism ?
Trying to nail down the terminology in my alleged mind.
THANKS - old jim
The current density can be free moving electrical charges, but often times, the magnetic current density given by ##\vec{J}_m=\frac{\nabla \times \vec{M}}{\mu_o} ## is the source of the magnetic moment in these equations. The magnetization ## \vec{M} ## is the magnetic moment density. When there are gradients in this quantity, magnetic currents ## \vec{J}_m ## are the result=(similar to moving electrical charges, but here any electrical charge motion usually consists of bound quantum states). When the magnetization ## \vec{M} ## is uniform but encounters a boundary of the magnetic material, the result by Stokes' theorem is a magnetic surface current per unit length given by ## \vec{K}_m=\frac{\vec{M} \times \hat{n}}{\mu_o } ##. (Here I'm defining ## \vec{M} ## by ## \vec{B}=\mu_o \vec{H}+\vec{M} ##, instead of by ## \vec{B}=\mu_o (\vec{H}+\vec{M}') ##). ## \\ ## You might also find this Insights article that I authored of interest: https://www.physicsforums.com/insights/permanent-magnets-ferromagnetism-magnetic-surface-currents/ You might also find in the section "Discuss in the Community" portion of this "link", posts 32 and 33 of some interest. ## \\ ## Post 32 is a "link" to a posting that appeared on Physics Forums of an interesting homework laboratory on the Curie temperature. Let me provide that "link" here as well: https://www.physicsforums.com/threa...perature-relationship-in-ferromagnets.923380/ You might find the experimental technique and calculations to determine the magnetization ## \vec{M} ## of the permanent magnet of considerable interest. ## \\ ## Post 33 of "Discuss in the Community" mentions some of the complications that arise from the exchange effect, so that these simple linear theories are, in general, not going to be exact, and may be only somewhat good approximations that don't work in all cases.mertcan said:@Charles Link @vanhees71 @jim hardy there is something scratch my mind...in the link https://unlcms.unl.edu/cas/physics/tsymbal/teaching/EM-913/section5-Magnetostatics.pdf and equation 5.73 we can see that magnetic moment or magnetic moment density depends on a kind of current density. I believe it is not the free charge density but what kind of current density is this what results in that current density??
@Charles Link as far as I have observed in your links and @jim hardy links and my own search, the current density I mentioned at post 40 in given link and equation which affect the magnetic moment density is the circular current around proton or nucleus. Am I right??Charles Link said:The current density can be free moving electrical charges, but often times, the magnetic current density given by ##\vec{J}_m=\frac{\nabla \times \vec{M}}{\mu_o} ## is the source of the magnetic moment in these equations. The magnetization ## \vec{M} ## is the magnetic moment density. When there are gradients in this quantity, magnetic currents ## \vec{J}_m ## are the result=(similar to moving electrical charges, but here any electrical charge motion usually consists of bound quantum states). When the magnetization ## \vec{M} ## is uniform but encounters a boundary of the magnetic material, the result by Stokes' theorem is a magnetic surface current per unit length given by ## \vec{K}_m=\frac{\vec{M} \times \hat{n}}{\mu_o } ##. (Here I'm defining ## \vec{M} ## by ## \vec{B}=\mu_o \vec{H}+\vec{M} ##, instead of by ## \vec{B}=\mu_o (\vec{H}+\vec{M}') ##). ## \\ ## You might also find this Insights article that I authored of interest: https://www.physicsforums.com/insights/permanent-magnets-ferromagnetism-magnetic-surface-currents/ You might also find in the section "Discuss in the Community" portion of this "link", posts 32 and 33 of some interest. ## \\ ## Post 32 is a "link" to a posting that appeared on Physics Forums of an interesting homework laboratory on the Curie temperature. Let me provide that "link" here as well: https://www.physicsforums.com/threa...perature-relationship-in-ferromagnets.923380/ You might find the experimental technique and calculations to determine the magnetization ## \vec{M} ## of the permanent magnet of considerable interest. ## \\ ## Post 33 of "Discuss in the Community" mentions some of the complications that arise from the exchange effect, so that these simple linear theories are, in general, not going to be exact, and may be only somewhat good approximations that don't work in all cases.
The magnetization ## \vec{M} ## , (vector sum of the magnetic moments per unit volume), can actually be due to spin magnetic moment rather than than orbital angular momentum, and I believe that is what happens in the case of iron. ## \\ ## In the case of spin, the magnetic moment is ## \vec{\mu}_s=\frac{g_s \, \mu_B \, \vec{S}}{\hbar} ## , where ## \mu_B ## is the Bohr magneton. ## \\ ## In c.g.s. units, the Bohr magneton ## \mu_B=\frac{e \hbar}{2 m_e c }##. ## \\ ## The constant ## g_s \approx 2.0 ##, and results from the Dirac equation that are beyond my level of expertise give a result that ## g_s =2.0032... ## ## \\ ## For the orbital angular momentum, for which classical models of current loops apply, (with an electron in orbit about the nucleus, etc.), ## \vec{\mu}_L=\frac{g_L \, \mu_B \, \vec{L}}{\hbar} ##, with ## g_L=1.000 ##. ## \\ ## The equation ## \vec{J}_m=\frac{\nabla \times \vec{M}}{\mu_o} ##, and a related equation ## \vec{A}(\vec{r})=\frac{\mu_o}{4 \pi} \int \frac{\vec{J}(\vec{r}')}{|\vec{r}-\vec{r}'|} \, d^3 \vec{r}' ##, still apply, regardless of the origin of the magnetization.mertcan said:@Charles Link as far as I have observed in your link and my own search, the current density I mentioned at post 40 in given links and equation which affect the magnetic moment density is the circular current around proton or nucleus. Am I right
Charles Link said:For the illustration, I like to consider a square-shaped small current loop, so that it clearly cancels the current of the adjacent loop.
Charles Link said:The magnetization ## \vec{M} ## , (vector sum of the magnetic moments per unit volume), can actually be due to spin magnetic moment rather than than orbital angular momentum, and I believe that is what happens in the case of iron. ## \\ ## In the case of spin, the magnetic moment is ## \vec{\mu}_s=\frac{g_s \, \mu_B \, \vec{S}}{\hbar} ## , where ## \mu_B ## is the Bohr magneton. ## \\ ## In c.g.s. units, the Bohr magneton ## \mu_B=\frac{e \hbar}{2 m_e c }##. ## \\ ## The constant ## g_s \approx 2.0 ##, and results from the Dirac equation that are beyond my level of expertise give a result that ## g_s =2.0032... ## ## \\ ## For the orbital angular momentum, for which classical models of current loops apply, (with an electron in orbit about the nucleus, etc.), ## \vec{\mu}_L=\frac{g_L \, \mu_B \, \vec{L}}{\hbar} ##, with ## g_L=1.000 ##. ## \\ ## The equation ## \vec{J}_m=\frac{\nabla \times \vec{M}}{\mu_o} ##, and a related equation ## \vec{A}(\vec{r})=\frac{\mu_o}{4 \pi} \int \frac{\vec{J}(\vec{r}')}{|\vec{r}-\vec{r}'|} \, d^3 \vec{r}' ##, still apply, regardless of the origin of the magnetization.
jim hardy said:You are not alone. I found a lot of those before finding that circular one.
http://farside.ph.utexas.edu/teaching/302l/lectures/node77.html
I like the round ones because i think of atoms as round and electron orbits as circles - that's all.
old jim
@mertcan This is basically a frequency response question, and in post 20, @jim hardy actually showed some examples of frequency response with and without laminations, where the laminated iron layers have better frequency response because it doesn't have the Faraday EMF's and eddy currents to contend with, with their effect increasing with increasing frequency. ## \\ ## The question you are asking I think could basically be answered by knowing the amount of phase shift that occurs between the primary and secondary. The experiment might be a little complicated by the items mentioned in post 16. In any case, I don't really know what type of frequency response might be expected.mertcan said:Another interesting question gentlemen : Let's think that we put the iron in a steady state magnetic field environment and we know that iron is going to behave like magnet, points in iron are going to have different pole strength at the end, but HOW MUCH time is required for a given specific point in iron to reach its steady magnetic field at the end?? Can we calculate that situation??
Also until reaching the steady magnetic field at the end, while time passes HOW does the magnitude of specific point's magnetic field change?? Can we calculate also that situation??
Charles Link said:in post 20, @jim hardy actually showed some examples of frequency response with and without laminations,
you say that in short there is no equation related to required time to reach steady state magnetic field and how magnitude of specific point's magnetic field changes until reaching its final magnetic field magnitude(steady)??jim hardy said:A lot goes on in a simple piece of iron. I don't think you can write a general equation. From Sylvanus Thompson's 1896 edition of "Dynamo Electric Machinery"
oops sorry for overlapping snips.
I have an original 1901 edition and it's a delight .
Your question would i think be best answered by experiment on a specimen of the particular alloy, heat-treatment, shape, size, temperature, and recent magnetization that interests you.
A search on phrase "sylvanus thompson retardation of magentization" also turns up the 1903 edition of his book "Design of Dynamos" with some similar paragraphs. Some of his books are reprinted in India, to the credit of educators there. You might find one an interesting addition to your library.
old jim
mertcan said:you say that in short there is no equation related to required time to reach steady state magnetic field and how magnitude of specific point's magnetic field changes until reaching its final magnetic field magnitude(steady)??
mertcan said:Let's think that we put the iron in a steady state magnetic field environment and we know that iron is going to behave like magnet, points in iron are going to have different pole strength at the end, but HOW MUCH time is required for a given specific point in iron to reach its steady magnetic field at the end?? Can we calculate that situation??
mertcan said:I am really eager to understand HOW MUCH time is required for a given specific point in iron to reach its steady magnetic field strength at the end when we put the iron in a steady state magnetic field environment and until reaching the steady magnetic field strength at the end, while time passes HOW does the magnitude of specific point's magnetic field or pole strength change
For a small laminated transformer, (3" diameter), I believe the time constant is quite fast: Just a guess is that it is in the 1-2 millisecond range, but I would need futher research to confirm. @jim hardy Might this number ## \tau \approx 2 \, msec ## seem reasonable?mertcan said:@jim hardy @Charles Link , initially thanks again for your nice responses. But although jim shared a couple of sources, I do not have a chance now to attain those sources for instance the book is not open source and I do not have it in library. Thus would you mind sharing much more sources with me?? (links, videos, pdf files...)
I agree. I do think for a number of years the basic E&M (electricity and magnetism) has actually been de-emphasized in the college curriculum.jim hardy said:I encourage @mertcan to get some i/o gear for his computer and experiment . We need more students interested in magnetics.
Yes, we've shortchanged a lot of students.Charles Link said:I do think for a number of years the basic E&M (electricity and magnetism) has actually been de-emphasized in the college curriculum
