I Magnetic flux through a superconducting ring
Lagrange fanboy
TL;DR Summary
Why isn't the flux 0 since it's equal to a closed line integral of a scalar potential's gradient?
Lagrange fanboy said:
In Feymann's seminar on superconductivity, there was this equation (21.28) ##\oint_C \nabla \theta\cdot dl = \frac q \hbar \Phi##. But the gradient theorem demands that ##\oint_C \nabla \theta\cdot dl=0##
The answer to your question is already there in the Feynman lecture you linked to. See the discussion between equations 21.28 and 21.29.
Feymann said that it's the case because the region isn't simply connected, but I don't see how that leads to the gradient theorem breaking down, as it only requires the scalar potential to be differentiable along the path.
No, it also requires that, for a closed path enclosing an area, the area must be simply connected. (More precisely, it requires that the closed path be continuously reducible to a point, which is equivalent to the area enclosed by the path being simply connected.) Normally this requirement is not mentioned because normal applications of the theorem are for simply connected regions.
Another way of looking at it is that, if the region covered by the potential is not simply connected, the potential cannot be treated as a "scalar function" in the sense the gradient theorem requires, because it is not single-valued. Indeed, in the Feynman lecture you referenced, the potential ##\Phi## is not single-valued.
Likes Lagrange fanboy and vanhees71
It's the famous "potential vortex". The corresponding vector field,
$$\vec{V}=\frac{1}{x^2+y^2} \begin{pmatrix}-y \\x \end{pmatrix}$$
is singular along the entire ##z## axis, i.e., its domain is not simply connected, because you can't contract continuously any closed curve that goes around the ##z## axis.
Neverteless except along the ##z## axis you have ##\vec{\nabla} \times \vec{V}=0##.
To define a potential thus you have to choose an arbitrary semi-infinite surface with the ##z## axis as boundary and then calculate the line integral
$$V=\int_{\mathcal{C}} \mathrm{d} \vec{x} \cdot \vec{V},$$
for an arbitrary set of paths all origining from one fixed point ##\vec{x}_0## to any other point ##\vec{x}##, not crossing this surface.
The potential has a jump of ##2 \pi## across the arbitrarily chosen surface, which is the value of the line integral for any closed curve encircling the ##z## axis just once.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
