Magnetic force on moving charge
In summary: So, the direction of the force exerted on a charge is directly proportional to the angle at which the current ring's magnetic dipole is aligned with the external B-field. This alignment is called the direction of the force exerted on the charge.
boris16
46
greetings
1)
I assume the field lines represent the strength of magnetic field and show the direction of magnetic force. So if we put iron filings on paper with magnet near by, then fillings will arrange themselfs in such way to show the direction of the magnetic forces on these iron fillings.
And here is the confusing part: When learning about moving charged particles inside MF, suddenly magnetic force on this charge is perpendicular to magnetic field lines ( and these lines BTW represent magnetic force ).
Why if an object such as another magnet or steel enters MF, magnetic forces represented by magnetic field lines act on this object, but when charge enters MF, the magnetic force represented by magnetic field lines doesn't act on charge, but instead new force is created that acts on this charge and direction of this force is different than direction of magnetic forces represented by magnetic field lines ( this new force is only created if charge is not moving parallel with magnetic field lines )? In short, why does magnetic field behave differently depending on whether a charge of stell enters inside it?
2)
Is this force exerted on charge perpendicular to charge, or is it perpendicular to magnetic field lines, or both?
3)
And most importantly, why is this force always perpendicular?
4)
Why does MF feel the need to exert force on charge? Is it due to MF having more strength ( greater magnetic forces ) in particular area ( because of moving charge contributing its own MF, and as such MF feels the need to move charge to area of less strength in order to make MF more homogeneous )?
5)
It's pretty easy to figure out the direction of force exerted on charge if charge is moving perpendiculary to magnetic field lines, but else how do you figure out the direction of force on a charge?
cheers
2. its the cross product of charge's velocity and the mf. If you point your fingers towards the direction of the velocity then point your palm in the direction of the mf (either up or down), then your thumb will be pointing to the direction of the force acted upon by the mf on the charge.
so, its always perpendicular to the mf, and perpendicular to charge's velocity if it is also perpendicular to the mf.
5. break the velocity vector into a parallel component and a perpendicular component. disregard the parallel component since it doesn' cause any force from the mf. Then use the perpendicular component in the equation.
These are very good inquiries. First of all, the magnetic field vector field was initially defined as the direction in which magnetic dipoles align. It is important to understand that the alignment of magnetic dipoles in B-fields due to magnets, such as iron, is caused by the same force that causes deflection of moving charges.
Take a square of wire that lies in the x-y plane with a constant current (movement of charge) flowing through it (in say the positive phi direction). Then let us apply a external uniform B-field, in say, the positive y-direction. Now, the ring of current is going to produce its own B-field independent of the externally applied B-field due to Biot-Savart's law and the magnetic dipole moment due to this B-field is in the positive z-direction, dictated by the current direction. In addition, the ring of current will begin to rotate in the presence of the external B-field, due to the Lorentz force. It is clear that the Lorentz force will want to align the current ring's magnetic dipole with the external B-field.
Now, the alignment of iron shavings with a B-field is caused by the same action. In all materials, the electrons around the atoms (bound or unbound) are moving which produce magnetic dipoles. In the absense of a B-field, the magnetic dipoles are pointing in random directions. However, in some materials (magnetic materials), in the presense of a B-field the magnetic dipoles align themselves with the B-field. This is caused by the same physical laws that cause a current ring's dipole to align with a magnetic field. Some materials do not align their at all dipoles with the magnetic field. These materials are non-magnetic. Other materials allow their magnetic dipoles to align with the B-field but when the B-field is turned off the dipoles point in random directions once again. Other materials after the dipoles are aligned by a B-field and then the field is turned off some of their dipoles stay in the direction induced by the B-field, but the rest resume their random orientations (these are called paramagnetic or diamagnetic substances). Finally, other materials after the dipoles are aligned by a B-field and then the field is turned off most of the dipoles retain their aligned orientations (these are called ferromagnetic substances).
FAQ: Magnetic force on moving charge
What is magnetic force on a moving charge?
The magnetic force on a moving charge is the force exerted on a charged particle as it moves through a magnetic field. It is perpendicular to both the direction of motion of the particle and the direction of the magnetic field.
How is the magnitude of magnetic force on a moving charge calculated?
The magnitude of the magnetic force on a moving charge is calculated using the equation F = qvBsinθ, where q is the charge of the particle, v is its velocity, B is the strength of the magnetic field, and θ is the angle between the velocity and the magnetic field.
How does the direction of the magnetic force on a moving charge change?
The direction of the magnetic force on a moving charge changes depending on the direction of the magnetic field and the direction of motion of the particle. If the magnetic field and velocity are parallel, there will be no magnetic force. If they are perpendicular, the force will be perpendicular to both of them.
What is the role of a charged particle's velocity in magnetic force?
The velocity of a charged particle plays a crucial role in determining the magnitude and direction of the magnetic force. The force is directly proportional to the velocity, so the faster the particle is moving, the greater the force will be.
How does the magnetic force on a moving charge affect the path of the particle?
The magnetic force on a moving charge can cause the particle to deviate from its original path and move in a circular or helical path, depending on the strength and direction of the magnetic field. This is known as magnetic deflection and is used in many applications, such as particle accelerators and MRI machines.
