Vivek098
- 9
What is the difference between the Magnetic Field Lines of the Dipole and Circular Current Carrying Wire at the centre?
Magnetic lines of dipole are imaginary lines that represent the direction and strength of the magnetic field around a dipole (a pair of equal and opposite poles). They are used to visualize and understand the behavior of magnetic fields.
Magnetic lines of dipole are formed due to the movement of electric charges. In the case of a dipole, the electric charges are separated and their movement creates a magnetic field. The lines are formed in a way that the direction of the lines is from the north pole to the south pole.
Magnetic lines of dipole are significant because they help us understand the behavior of magnetic fields. They allow us to visualize the strength and direction of the magnetic field around a dipole. They also help in predicting the interaction between different magnetic dipoles.
Circular current wire produces magnetic lines of dipole due to the movement of charges in the wire. As the charges move in a circular path, they create a magnetic field around the wire. The direction of the magnetic field can be determined using the right-hand rule.
Yes, the strength of magnetic lines of dipole can be changed by altering the strength of the current or by changing the distance between the poles of the dipole. The closer the poles are, the stronger the magnetic field and the denser the lines of the dipole will be.
