Magnetic Mirror and particle trap
In summary, the conversation discusses the behavior of two charged particles, A and B, released in the center of a mirror where the magnetic field is minimum. The direction of A's velocity is parallel to the magnetic field while B's velocity is perpendicular. The question is whether A, B, or both will get trapped or escape. The conversation also explores the behavior of a single particle with a random angle and how it separates into parallel and perpendicular components. The idea of placing the particles in separate bottles to observe their behavior is also mentioned. The question is clarified to be about the behavior of a particle with a velocity that is exactly perpendicular or parallel to the symmetry axis.
QuarkDecay
47
Suppose we have two charged particles A and B released in the center of the Mirror (where the field is minimum). If A's velocity direction is parallel with the Magnetic field of the mirror and B's velocity is perpendicular with the field, then which one is going to get trapped, or escape, or neither?
I'm confused because the only example I could find was with only one particle moving with a random angle (different than 90 degrees or 0 degrees), and it separates its angle into one parallel and a perpedicular. When the particle heads towards the edges where the fiels is strong, the perpendicular component increases while the parallel descreases.
But I don't know how this could apply for two separate particles.
That's easy. Assuming that the particles are non-interacting, you can put them in separate bottles and see what each does in its own environment. What (I think) you are asking is what happens when a particle has a velocity that is (a) exactly perpendicular to the symmetry axis or (b) exactly along the symmetry axis. Is that your question?
Likes mfb
Related to Magnetic Mirror and particle trap
What is a magnetic mirror and particle trap?
A magnetic mirror and particle trap is a device that uses a combination of magnetic fields to confine and manipulate charged particles, such as ions or electrons. It is commonly used in research and industrial settings to study and control the behavior of particles.
How does a magnetic mirror and particle trap work?
The device works by creating a magnetic field that is stronger at one end (the mirror) and weaker at the other end. Charged particles are then injected into the trap and bounce back and forth between the two ends, with their motion being confined by the magnetic field.
What are the applications of a magnetic mirror and particle trap?
A magnetic mirror and particle trap has a wide range of applications, including particle accelerators, fusion research, and ion implantation. It is also used in medical research for studying the effects of radiation on cells and in the development of new medical treatments.
What are the benefits of using a magnetic mirror and particle trap?
Using a magnetic mirror and particle trap allows for precise control and manipulation of charged particles, which is essential for many scientific and industrial processes. It also provides a safe and controlled environment for studying the behavior of particles without the risk of external interference.
What are the challenges of using a magnetic mirror and particle trap?
One of the main challenges of using a magnetic mirror and particle trap is maintaining the stability of the magnetic field. Any fluctuations or disruptions in the field can affect the behavior of the particles and compromise the accuracy of the results. Additionally, designing and constructing a trap that is suitable for a specific type of particle can be a complex and time-consuming process.
  • Electromagnetism
  • Nuclear Engineering
  • Electromagnetism
  • Electromagnetism
