Magnetic moment and binding energy
In summary, the conversation discusses the potential role of magnetic dipole interactions in the binding force of nuclei. The magnetic moment of the neutron is approximately 9.66e-27 J/T, and when this is plugged into the formula for force between two magnetic dipoles within 1 femtometer of each other, it yields almost 9000N of force. This is comparable to the Coulomb force, but at smaller distances, the magnetic force increases rapidly. However, the formula used is a classical approximation and may not accurately represent the behavior of protons and their electric fields at such small distances.
x_engineer
55
I ran across the fact that the magnetic moment of the neutron is approx 9.66e-27 J/T. When I plug it into the formula for attractive/repulsive force between 2 magnetic dipoles within 1 femtometer of each other (nuclear dimensions) I get almost 9000N, and the energy to separate them (if attractive) would be like MeV, about the nuclear binding energy.
Of course neutrons for some reason like to orient anti-parallel to the local magnetic field so they will likely repel each other.
Has anybody proposed this as the origin of the binding force?
The strong nuclear force overwhelms electromagnetic effects.
Which formula are you using may I ask?
Creator
It's easy to estimate things like this, provided you remember a few constants - and don't try to use SI units! The constants to remember are just the fine structure constant e2/hc = 1/137 (forgive me, I'm writing h instead of h-bar) and Planck's constant, hc = 200 MeV-f. (Actually it's 197.5, but I'm rounding off.)
First the Coulomb interaction energy between two protons. It is V = e2/r = (e2/hc) (hc/r) = (1/137)(200 MeV-f/1 f) = about 1.5 MeV. Note, the Coulomb energy is *not* overwhelmed by the strong force, which is about 8 MeV/nucleon. Yes it's smaller, but not by much.
Second, the dipole-dipole interaction. The magnetic dipole moment M of the neutron is about -2 nuclear magnetons. A nuclear magneton is the unit of magnetic moment used in nuclear physics and defined as eh/2m, where e is the charge of the proton and m is the mass of the proton, which in turn is about 1 GeV. So M = -2 (eh/2m) = -eh/m. The dipole-dipole interaction energy is similar to the Coulomb energy, only it goes like 1/r3. (Never mind all the vectors and factors of 3 and stuff. We're looking for an order of magnitude.)
So V = M2(1/c2)(1/r3) = (eh/mc)2(1/r3) = (h/mc)2(e2/r3). Well we don't even have to work this out, because it's just like the Coulomb energy except for the extra factors (h/mc)2(1/r2). Here r = 1 fermi, and h/mc = the Compton wavelength for the proton, which is hc/mc2 = 200 MeV-f/1GeV = 1/5 f. So the extra factors amount to (1/5)2. Voila, the dipole-dipole interaction energy is about 1/25 of the proton-proton Coulomb energy.
Terminology aside, the physics content of my previous post is the simple observation that the strong nuclear force can bind multiple protons into nuclei, despite their electromagnetic repulsion. I think this is an even easier way to answer the original question.
I don't think this can be right, since the straight Coulomb repulsion would be about a couple of hundred Newtons, and the magnetic force is going to be less than the electrical one.
The formula I used is here:-
http://en.wikipedia.org/wiki/Magnetic_moment
Making suitable assumptions about the angles
F(r) = 3 * mu * (M^2)/ (4 pi R^4)
I made a mistake in my calculation, the force comes out to 27.99N at 1 femtometre. Because of the R^4 dependence it does not take much of a change to get to 9000 N - that is what it would be at .24 femtometre.
The Coulomb force is about 231 N at 1 femtometre, and about 4000 N at .24 femtometre.
The reason I bring this up is because at small scales (of the order of the nuclear radius) the magnetic moment can completely dominate force. Under .5 femtometer it becomes larger than the Coulomb force and grows much more rapidly than the Coulomb force. It is kind of like the binding force in that respect. It would take only a small assumption about the structure of a nuclear particle behaving like a ferromagnet/paramagnet in those enormous magnetic fields to explain why a nucleus is around femtometres in radius.
Thanks for providing the formula, X Engineer; I figured that's the one you were using , and that's why I asked... the 1/ r^4 dependence for Force...
Using that formula you make a good point.
However...
You should realize this is a classical formula and that force equation was derived from the magnetic dipole field equation (also given in the link you supplied) ...and is an approximation of the field strength based upon approximation for distances where r is LARGER than the dipole length, which at these tiny distance may be quite an unreliable assumption.
Furthermore, when protons are present, and even though its dipole magnetic moment is comparable to that of the Neutron, its electric field (from its charge) can be so great at such close radii that there are radiative corrections; IOW, the high fields (both electric and magnetic) in effect may change the vacuum permeabilty & permittivity 'constants' upon which the above 'classical' dipole magnetic field formula is based.
Now you know why QED is normally used.
However, it is an interesting point that I think bears attention.
Creator
Wow! so there is a mechanism for correction!
I can see how a high field can increase the permittivity of free space in the presence of vacuum fluctuations. I guess the same could happen with the permeability in which case the range of the magnetic moment would increase... As for the approximation condition, how big is the dipole actually, and maybe that explains why the nucleus does not just disappear into a point (at least not with measurable probability - we currently do believe in black holes)
I am basically an electrical engineer, so QED is way out of my league. But I have found there are so many solutions to the electromagnetic field equations; so that just because you find one solution does not mean the system will not behave totally differently, because there might be another solution with different properties. With things happening so fast, you need a boundary on the range of possible solutions to say something meaningful in our timeframe, and QED probably is that.
I should have said --- with things happening so fast and almost anything possible, you need a probability distribution on the range of possible solutions to say anything meaningful about the system in timeframes at our scale ---
To calculate electromagnetic form factors of nucleons, one typically uses lattice quantum chromodynamics (some observational information should be obtainable from deep inelastic scattering experiments)... the approximation of pretending we don't know about QCD is not going to be reliable.
Related to Magnetic moment and binding energy
What is magnetic moment?
Magnetic moment refers to the measure of the strength and direction of a magnetic field produced by a magnetic object, such as an electron or a magnet. It is a vector quantity, meaning it has both magnitude and direction.
How is magnetic moment measured?
Magnetic moment is typically measured in units of ampere-meters squared (A·m^2) or joules per tesla (J/T). It can be measured experimentally using devices such as a magnetometer or by calculating it based on the intrinsic magnetic properties of an object.
What is binding energy?
Binding energy is the amount of energy required to break apart an atomic nucleus or a subatomic particle. It is a measure of the strength of the force that holds the particles within the nucleus together.
How does magnetic moment relate to binding energy?
Magnetic moment is related to binding energy through the spin of subatomic particles. The spin of a particle contributes to its magnetic moment, which in turn affects its binding energy. In certain cases, the magnetic moment can also directly affect the binding energy of a system.
What are some real-world applications of magnetic moment and binding energy?
Magnetic moment and binding energy are important concepts in fields such as quantum mechanics, nuclear physics, and materials science. They have practical applications in technologies such as magnetic data storage, medical imaging, and energy production from nuclear reactions.
