Magnetic moment of compass needle?
In summary, to calculate the magnetic moment of a compass needle in SI units, one could model the needle as a current loop and use the Biot-Savart law to determine the necessary current. Alternatively, one could measure the B field of the needle by dropping it through a coiled copper wire and relating the change in flux to the voltage. The strength of a magnet is given in Tesla, which is not the same as magnetic moment. To compare the magnetic dipole moment of a compass needle with the induced electric dipole moment in a strong electric field, further research on magnetism is needed.
shoestring
96
What would be a typical value of the magnetic moment of a compass needle (in SI units)?
Do you know the B field of the needle? If you do try to model the needle as a little current loop, Use the biot savart law to find what current your loop needs to produce that B field. Your loop will have a diameter equal to the length of the needle.
Then just multiply the current times area
M=I(area)
Maybe you could find the B field of the needle by dropping it through a coiled copper wire and relating the change in flux to the voltage .
Lots here, but not a typical value stated, and in the links at the bottom of the article:
http://en.wikipedia.org/wiki/Magnetic_moment
Looks like you can calculate a value...
Thanks both, but I'm a little confused about the units. The strength of a magnet is given in Tesla, but that isn't the same as magnetic moment, is it? Obviously I need to read up on magnetism.
The reason I'm wondering is that I'd like to compare the magentic dipole moment of a compass needle with the induced electric dipole moment it might get in a strong electric field, to see if an electric field could possible cause any deviation of the needle.
The magnetic moment of a compass needle refers to its ability to align with the Earth's magnetic field. It is a measure of the strength and direction of the magnetic field produced by the needle. In SI units, the magnetic moment is typically measured in units of ampere-meter squared (A m^2). The exact value of the magnetic moment of a compass needle can vary depending on its size, material, and the strength of the Earth's magnetic field at its location. However, a typical value for a small compass needle can range from 10^-6 to 10^-5 A m^2. It is important to note that the magnetic moment of a compass needle can also change over time due to factors such as temperature and external magnetic fields.
Related to Magnetic moment of compass needle?
1. What is the definition of magnetic moment?
The magnetic moment of a compass needle is a measure of the strength and direction of its magnetic field. It is a vector quantity, with both magnitude and direction.
2. How is the magnetic moment of a compass needle measured?
The magnetic moment of a compass needle can be measured using a magnetometer, which is a device that can detect and measure magnetic fields. The needle is placed in the magnetometer and the strength and direction of the magnetic field is recorded.
3. What factors affect the magnetic moment of a compass needle?
The magnetic moment of a compass needle is affected by the strength of the magnet used to magnetize it, the material of the needle, and any external magnetic fields that may be present.
4. How does the Earth's magnetic field affect the magnetic moment of a compass needle?
The Earth's magnetic field is one of the external factors that can affect the magnetic moment of a compass needle. The needle aligns itself with the Earth's magnetic field, and if the field is strong enough, it can overpower the needle's own magnetic moment and cause it to point in a different direction.
5. How is the magnetic moment of a compass needle used in navigation?
The magnetic moment of a compass needle is used in navigation to determine direction. By aligning itself with the Earth's magnetic field, the compass needle can be used to determine north, south, east, and west, which is essential for navigation and orienteering.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
