Magnetic moment of the Muon and Tau
In summary: S*(1/2)*(1/m)*(1/r)mu = g*(q/(2m)*S*(1/2)*(1/m)*(1/r))In summary, the magnetic moment of an electron is −1.00115965218076(27) μB. The anomalous magnetic moment of the tau is 1/1800th of this value. The magnetic moment of the Tau is about −0.0005 μB.
zincshow
104
For the electron, wiki lists its magnetic moment as −1.00115965218076(27) μB. It does not list it for the Muon or Tau. Wiki does show for the Muon the Anomalous magnetic dipole moment of 0.00116592089. Is it correct to assume the magnetic moment of the Muon is -1.00116592089 μB?
For the Tau, wiki does not show either a magnetic moment or an anomalous magnetic dipole moment. What is the magnetic moment of the Tau?
A google search produces results like http://arxiv.org/pdf/hep-ph/0702027v1.pdf but unfortunately, the article is beyond my pay grade for understanding.
Regarding the anomalous magnetic moment of the tau, this paper says,
Theoretically, the standard model predicts aτ = 1.1769(4) x 10−3
(Since the tau has such a short lifetime, aτ can't be measured by the usual means, so the paper is mainly devoted to clever, indirect ways to do it.)
Muon: Right
The MEG experiment is much more sensitive than the upper limit on the branching ratio used in the paper, so the measurements improved since then (>2 orders of magnitude).
Great thanks, wonder why wiki doesn't just say:
Electron: −1.00115965218076(27) μB
Muon: -1.00116592089 μB
and Tau: -1.0011769 μB
Strictly speaking, it's only the electron that has a magnetic moment close to 1 Bohr magneton. The other charged leptons (electron flavors) have much smaller magnetic moments. That's because the Bohr magneton is the Dirac value of the electron's magnetic moment. In general, the Dirac value is
q/(2m)
for charge q, mass m, hbar = c = 1
The anomalous magnetic moment a is defined be
(magnetic moment) = (Dirac magnetic moment) * (1 + a)
So (MM, muon) ~ 1/200 * (MM, electron) and (MM,tau) ~ 1/1800 * (MM, electron)
Likes 1 person
Thanks for the message, it is different from the others and makes sense to me. You are suggesting the better estimates would be:
Electron: about −1.0 μB
Muon: -0.005 μB
and Tau: -0.0005 μB
Also, given the confusion in the answers, do you know any online references I could use? Would not it make more sense for the Muon to be 200 * (MM electron) rather then 1/200 * (MM electron)? Ie. wouldn't it be a lot harder to flip a Muon then it is to flip an Electron?
Much appreciate the help with this.
Another case of macroscopic intuitions causing trouble. I'll give a hand-waving argument for an elementary particle's magnetic moment.
Angular momentum J = m*((r)x(v))
Magnetic moment mu = (1/2)*q*((r)x(v))
mu = (q/(2m))*J
for (charge distribution) ~ (mass distribution)
Strictly speaking, mu = g*(q/(2m))*J
For orbital angular momentum, g = 1
For an elementary fermion's spin, g = 2
FAQ: Magnetic moment of the Muon and Tau
What is the magnetic moment of the muon and tau?
The magnetic moment of a particle is a measure of its response to an external magnetic field. For the muon and tau particles, this value is approximately 2.0023 times the nuclear magneton, a unit of magnetic moment. This value is a fundamental property of the particles and is an important factor in studying their behavior.
How is the magnetic moment of the muon and tau determined?
The magnetic moment of the muon and tau can be determined experimentally through various methods, such as measuring their deflection in a magnetic field or observing their energy levels in a magnetic field. Theoretical calculations can also be used to predict and verify the magnetic moment values.
How does the magnetic moment of the muon and tau differ from that of the electron?
The magnetic moment of the muon and tau particles is larger than that of the electron due to their larger mass. This is known as the "mass factor" and is a result of the particles' spins and charges. The muon and tau also have different magnetic moments from each other due to their different masses and charges.
Why is the magnetic moment of the muon and tau important in particle physics?
The magnetic moment of the muon and tau is a fundamental property that plays a crucial role in particle physics experiments and theories. It helps researchers understand the internal structure and behavior of these particles and can provide insights into the underlying forces and interactions between particles.
Can the magnetic moment of the muon and tau be altered or manipulated?
The magnetic moment of particles is a fundamental property that cannot be altered or manipulated. However, in certain experiments, external magnetic fields can be used to affect the behavior of muons and taus, allowing researchers to study their magnetic moments and other properties in greater detail.
