What Kind of Magnetic Field Does a Tubular Capacitor Generate?
In summary, when charging a tubular capacitor with a sinusoidal voltage, a perpendicular magnetic field will be generated inside the dielectric and outside the capacitor. The same is true for a capacitor with two circular plates. This is important to consider for the design of a motor.
Alokin_Alset
Hy.
I'm an amateur scientific. This is my first post. Sorry if this is not the right place. Let me know & I'll change it immediately, but as far as I have seen, this is where I consider more appropriate.
I have a copper tube, with a thick plastic strip wrapped over, between an aluminum strip wrapped over the plastic strip. That's a tubular capacitor, with the plastic acting as the dielectric, one plate is inside copper tube, the other plate is the aluminum strip. If I charge this tubular capacitor using a sinusoidal Voltage, what kind of magnetic field will generate inside the dielectric & outside the capacitor?
Same question but now, I have two circular plates like this.
If the magnetic field is ;
This means that the magnetic field goes perpendicular to the Electric Field like this? Is that correct?
I know that it is a little bit bizarre my questions, but It's a idea for a special motor, for pedagogical purposes.
Thanks.
Yes, you are correct that the magnetic field will be perpendicular to the electric field. The magnetic field generated by a capacitor is usually quite small - so it may not be very noticeable. However, if the capacitor has a large magnitude of charge, then the magnetic field can become more significant.
FAQ: What Kind of Magnetic Field Does a Tubular Capacitor Generate?
What is a magnetic tubular capacitor?
A magnetic tubular capacitor is a type of capacitor that uses a ferromagnetic material, such as iron or steel, in its construction. The magnetic properties of the material allow the capacitor to store energy in the form of a magnetic field, rather than an electric field like traditional capacitors.
How does a magnetic tubular capacitor work?
A magnetic tubular capacitor works by using the ferromagnetic material to store energy in the form of a magnetic field. When an electric current flows through the capacitor, it creates a magnetic field around the ferromagnetic material. This magnetic field then stores the energy until it is needed.
What are the advantages of using a magnetic tubular capacitor?
One advantage of using a magnetic tubular capacitor is that it can store more energy compared to traditional capacitors of the same size. This is because the magnetic field can hold more energy than an electric field. Additionally, magnetic tubular capacitors are more stable and have a longer lifespan.
Where are magnetic tubular capacitors commonly used?
Magnetic tubular capacitors are commonly used in high-power applications, such as power supplies for electronic devices and in electric motors. They are also used in automotive applications, such as in car audio systems and engine control modules.
Can a magnetic tubular capacitor be used in place of a traditional capacitor?
It depends on the specific application. Magnetic tubular capacitors have different properties and characteristics compared to traditional capacitors, so they may not always be interchangeable. It is important to consult with an expert to determine the best type of capacitor for a specific application.
