Magnetic Vector Potential and conductor
In summary, the vector potential inside a straight current-carrying conductor of radius R is given by the equation \vec{A} = \frac{\mu_{0}I}{4\pi}(1-\frac{s^2}{R^2}), with the condition that it is zero at s = R. This can be derived using the Biot-Savart Law or the (magnetostatic) Maxwell Equations. It is also helpful to use cylindrical coordinates to solve this problem.
sikrut
49
Show that, inside a straight current-carrying conductor of radius R, the vector potential is:
$$ \vec{A} = \frac{\mu_{0}I}{4\pi}(1-\frac{s^2}{R^2}) $$
so that ##\vec{A}## is set equal to zero at s = R
## \vec{A} = \frac{\mu_{0}}{4\pi}\int\frac{\vec{I}}{|r'-r|} dl' ##
I'm really having a hard time even setting it up.
Start by drawing a picture of a current carrying wire with a significant radius.
How does the current vary with radius?
Hint: cylindrical coordinates.
Some people like to turn the line integral into an area integral too ... there are lots of approaches.
For marking - it is usually best to use the method covered in class.
Another hint: The Biot-Savart Law is not very efficient in many problems. It's easier to use the local form of the (magnetostatic) Maxwell Equations:
[tex]\vec{\nabla} \times \vec{B}=\mu_0 \vec{j}, \quad \vec{\nabla} \cdot \vec{B}=0.[/tex]
The second equation ("no monopoles") is already solved by the introduction of the vector potential, cf.
[tex]\vec{B}=\vec{\nabla} \times \vec{A}.[/tex]
So, just take the appropriate derivatives (in cylindrical coordinates), and check that you get the right current density.
As a scientist, it is important to understand the fundamental principles and equations that govern a system. In this case, we are dealing with the concept of magnetic vector potential and its relationship to a current-carrying conductor. The homework statement presents a specific scenario where we are asked to show that the vector potential inside a straight current-carrying conductor of radius R can be expressed as: ##\vec{A} = \frac{\mu_{0}I}{4\pi}(1-\frac{s^2}{R^2})##, where s represents the distance from the center of the conductor to a point inside the conductor.
To begin, let us first define the magnetic vector potential. It is a mathematical quantity that is used to describe the magnetic field in terms of a vector field. It is defined as: ##\vec{A} = \frac{\mu_{0}}{4\pi}\int\frac{\vec{J}}{|r'-r|} dl'##, where ##\vec{J}## represents the current density, ##\mu_{0}## is the permeability of free space, r is the position vector of the point where the magnetic field is being evaluated, and r' is the position vector of the current element dl'. This equation essentially tells us that the magnetic vector potential at a point is equal to the integral of the current density over the entire length of the conductor, taking into account the distance between the current element and the point of evaluation.
Now, let us apply this equation to the specific scenario given in the homework statement. We are dealing with a straight current-carrying conductor of radius R, which means that the current density is constant throughout the conductor. Using this information, we can rewrite the equation as: ##\vec{A} = \frac{\mu_{0}I}{4\pi}\int\frac{\vec{dl'}}{|r'-r|}##. We can further simplify this by considering that the conductor is symmetric, and thus the current elements are equidistant from the point of evaluation. This allows us to write the equation as: ##\vec{A} = \frac{\mu_{0}I}{4\pi}\int\frac{\vec{dl'}}{s}##, where s represents the distance from the center of the conductor to the point of evaluation.
Now, we need to consider the limits of integration for this integral. Since we are
Related to Magnetic Vector Potential and conductor
1. What is magnetic vector potential?
Magnetic vector potential is a mathematical concept used to describe the magnetic field in terms of a vector quantity. It is defined as the potential energy per unit magnetic charge, and can be used to calculate the magnetic field at any point in space.
2. How is magnetic vector potential related to conductor?
In the context of conductors, magnetic vector potential is used to describe the magnetic field generated by electrical currents flowing through the conductor. It helps to understand and analyze the behavior of electromagnetic fields in and around conductors.
3. Can magnetic vector potential be measured?
No, magnetic vector potential cannot be measured directly. It is a theoretical concept that is used to simplify the calculations of magnetic fields. However, the effects of magnetic vector potential can be observed and measured through the behavior of the magnetic field.
4. How is magnetic vector potential calculated?
Magnetic vector potential is calculated using the Biot-Savart law, which relates the magnetic field at a point to the current flowing through a conductor. It is also related to the magnetic flux density and the magnetic permeability of the medium.
5. What are the practical applications of magnetic vector potential?
Magnetic vector potential has many practical applications in various fields, such as electrical engineering, physics, and geophysics. It is used to understand and design electromagnetic devices, such as motors and generators. It is also used in geophysics to study the Earth's magnetic field and in medical imaging techniques, such as magnetic resonance imaging (MRI).
