Keasy
- 21
- 6
- TL;DR Summary
- This is what seems like a simple magnetics question involving a transformer, but the answer could have potentially important implications for advanced circuit design. The answer to the question may appear obvious, but is it really?
We have an ideal electrical transformer, 1:1 turns ratio. We can ignore winding resistance, core losses, hysteresis, core saturation, etc.
Call the primary P and the secondary S. The secondary is connected to a programmable voltage generator and to a resistance R in a simple series circuit.
The voltage generator is initially set to provide a constant 1 A current through the secondary S and the resistor R.
Now we use a voltage source to provide a changing voltage and current across and through the primary. But at the same time we vary the voltage across the secondary S (adding approximately the negative of the primary voltage to the secondary voltage source) so that the secondary current stays constant at 1A. I can see nothing that would prevent us from doing this.
Now the question : Is the time varying input impedance seen by the voltage source supplying P any different than if the secondary S had been open, rather than having the constant 1 A current?
Comment: It seems to me the 1A current in S establishes a constant magnetic flux in the transformer core. The current variations in P due to the voltage source adds to and subtracts from the magnetic flux in the core. But so long as the 1 A secondary current does not change it is unclear why the primary input characteristics should be different than if the S output terminals were open.
