Magnetism: 12.5 kiloGauss = lbs pull
In summary, there is no direct conversion between kiloGauss and lbs pull as they are measurements of different things. When purchasing magnets, be sure to consider the end area and B field to determine which unit is more appropriate. As for where to buy, it is recommended to do research and compare prices from different sellers before making a decision.
vmars
Please;
12.5 kiloGauss = how many lbs pull .
I want buy a bunch of 3/8" x 1/4" NEODYMIUM magnets.
Some sellers designate Gauss, other lbs pull.
Also, any tips on where to buy?
Thanks!
Gauss is a measure of magnetic flux density. Pounds are a unit of force. There is no simple conversion because they are not measurements of the same thing. In order to compare them, you would need to know more information about how and the measurements were taken.
vmars said:
Please;
Thanks!
"Lbs pull" is proportional to the end area of the magnet times the B field in gauss, so they are not equivalent units. Which you use depends on what you want to use the magnet for.
FAQ: Magnetism: 12.5 kiloGauss = lbs pull
1. What is magnetism?
Magnetism is a natural force that causes certain materials to attract or repel each other. It is caused by the alignment of electrons within a material.
2. What is 12.5 kiloGauss?
12.5 kiloGauss (kG) is a unit of measurement for magnetic field strength. It is equivalent to 12,500 Gauss, which is a measurement of magnetic flux density.
3. How does 12.5 kiloGauss compare to other magnetic field strengths?
12.5 kG is a relatively strong magnetic field strength. For comparison, the Earth's magnetic field at its surface is about 0.5 Gauss, while a typical refrigerator magnet has a strength of about 50 Gauss.
4. What is the lbs pull of 12.5 kiloGauss?
The lbs pull of 12.5 kG depends on the size and shape of the magnet. It is a measure of the amount of force it takes to pull a magnet away from a metal surface. This information is typically provided by the manufacturer.
5. Can exposure to 12.5 kiloGauss be harmful to humans?
No, 12.5 kG is not considered harmful to humans. The Earth's magnetic field is much stronger and we are constantly exposed to it without any negative effects. However, strong magnetic fields can interfere with certain electronic devices and should be used with caution around them.
