FaraDazed
- 347
- 2
Not sure if this is the correct place to post so move if needed.
In a cylindrical conductor of radius R, the current density is givne by [itex]j_0 e^{- \alpha r} \hat{k}[/itex]. Where ##\alpha## and ##j_0## are some constants and ##\hat{k}## is the unit vector along the z-axis.
. Determine the magnitude of the B field at all points in space.
## \oint_C \vec{B} \cdot d\vec{r} = \mu_0 I ##
## I = \int \int_S \vec{j} \cdot d\vec{S} ##
Well I am a bit stuck on this, don't know how to proceed as I don't know if I am interpreting it wrong or what, but first I state
## \oint_C \vec{B} \cdot d\vec{r} = \mu_0 I(r) ##
That amperes circuital law related the B field to the current passing through the contour C, so in this case as the current density is not uniform, the current is a function of r.
Then I try to find ##I(r)##
## I = \int \int_S (\vec{j} \cdot \hat{n}) dS ##
And using cylindrical coordinates,##j_0 e^{- \alpha r} \hat{k}## is just simply ##j_0 e^{- \alpha r} \hat{e_z}## , and surely the unit normal vector is ##\hat{e_{\rho}}##? But then that leads to the dot product of ##\vec{j}## and ##\hat{e_{\rho}}## to be 0.
Is ##\hat{e_{\rho}}## the unit normal vector in this case? Or would it be ##\hat{e_z}##? Even if it is ##\hat{e_z}## I still run into problems .
