Magnetostatics: Magnetic Vector Potential
I really appreciate it.In summary, the problem involves finding the expression for the magnetic field and proving the existence of a magnetic vector in the form of \vec{A}(P) = A(r)\hat{z} and \vec{B}(P) = \vec{\nabla} \times \vec{A} for an infinite wire shown in figure 1. The solution involves using Ampere's Law and setting the curl equations equal to the magnetic field equation. To solve for the magnetic potential vector, the condition -\frac{dA_{z}}{dr}=\frac{\mu_{0}I}{2\pi r}\hat{\theta} is used. For the second problem involving two wires
KEØM
68
Give an expression for the magnetic field and show that a magnetic vector exists such as [tex]\vec{A}(P) = A(r)\hat{z}[/tex] and [tex]\vec{B}(P) = \vec{\nabla} \times \vec{A}[/tex]
For the infinite wire shown in figure 1.
Here is a link to the figure and problem statement. The problem is the second problem on the first page.
https://docs.google.com/fileview?id...UtOGNkYi00ZGQyLTkxOTktNWVjYzM2MGViNDg3&hl=en"
[tex] \vec{\nabla} \times \vec{A} = \left(\frac{1}{r}\frac{\partial A_{z}}{\partial \theta} - \frac{\partial A_{\theta}}{\partial z}\right)\hat{r} + \left(\frac{\partial A_{r}}{\partial z} - \frac{\partial A_{z}}{\partial r}\right)\hat{\theta} + \frac{1}{r}\left(\frac{\partial(rA_{\theta})}{\partial r} - \frac{\partial A_{r}}{\partial \theta}\right)\hat{z}[/tex] curl in polar coordinates
[tex]\oint \vec{B} \cdot d\vec{l} = \mu_{0}I_{enc}[/tex] Ampere's Law
First we must solve for the magnetic field at point P. Using Ampere's Law we get,
[tex] \vec{B}(P) = \frac{\mu_{0}I}{2\pi r}\hat{\theta} [/tex] where the positive theta direction is into the page.
Now in order to find A we can set the curl equations equal to the magnetic field equation by curl(A) = B.
Doing so gives,
[tex]\frac{1}{r}\frac{\partial A_{z}}{\partial \theta} - \frac{\partial A_{\theta}}{\partial z} = 0 [/tex]
[tex]\frac{\partial A_{r}}{\partial z} - \frac{\partial A_{z}}{\partial r} = \frac{\mu_{0}I}{2\pi r}[/tex]
[tex]\frac{\partial(rA_{\theta})}{\partial r} - \frac{\partial A_{r}}{\partial \theta} = 0[/tex]
The answer to this problem (given to us by our instructor) is,
[tex]\vec{A} = \left(-\frac{\mu_{0}I}{2\pi}ln(r) + K \right)\hat{z}[/tex]
and the only way I can get there is by saying that because A points most often in the direction of the current (which is the z direction in this case) then,
[tex]-\frac{dA_{z}}{dr} = \frac{\mu_{0}I}{2\pi r}.[/tex]
Then solving this differential equation gives the desired result.
Can someone please point me in the right direction as to how solve this problem in a more rigorous manner?
Do I need to use the equation [tex]\vec{A} = \frac{\mu_{0}}{4\pi}\int \frac{\vec{J}(\vec{r'})}{r}d\tau '[/tex]?Many Thanks in advance,
KEØM
You already know that:
[tex]A_r = 0[/tex]
and
[tex]A_{\theta} = 0[/tex]
and
[tex]A_z = A(r)[/tex]
since it was given to you in the problem. This simplifies your 3 diff eq's quite a bit.
Thanks for your reply nickjer. So because A is a function of only r then all other derivatives go away and because it is only in the z direction then all other components are equal to zero. This then allows me to let [tex]-\frac{dA_{z}}{dr} = \frac{\mu_{0}I}{2\pi r}.[/tex] Is there anything else I must say for that condition to be satisfied?
Thanks again,
KEØM
nope that does it:
[tex]\vec{B}(P) = \frac{\mu_{0}I}{2\pi r}\hat{\theta} [/tex]
[tex]\vec{\nabla} \times \vec{A}=-\frac{dA_{z}}{dr} [/tex]
thus [tex]-\frac{dA_{z}}{dr}=\frac{\mu_{0}I}{2\pi r}\hat{\theta}[/tex]
Thanks! I really appreciate the help kreil and nickjer.
KEØM
I now have a question concerning the third problem on that page attached.
Problem Statement:
We consider now two wires of axis (O,z) and separated by the distance (2a). The currents in the two wires are [tex]+I[/tex] and [tex]-I[/tex] (see figure). Show that the expression of the magnetic potential vector [tex]\vec{A}(P)[/tex] is given by
[tex]\vec{A}(P) = \frac{\mu_{0}I}{2\pi}ln\left(\frac{r_{1}}{r_{2}}\right)\hat{z}[/tex]
(the observation point is located at [tex]P(r, \theta, z=0)[/tex]). Note: The constant of integration is integration obtained by taking [tex]\vec{A}(O) = 0[/tex].
Relevant Equations:
Same as previous problem.
Attempt at a solution:
For this problem can I say the same as before? He did say that our answer should be of the form [tex]\vec{A}(P) = A(r)\hat{z}.[/tex]
Thanks in advance.
You solved for the vector potential from a single wire. So for two wires you will just add the vector potentials from each. But be careful with the direction of each of the vectors.
I know from just looking at the answer that the -I current must be in the positive z-direction and the +I current must be in the negative z-direction but I don't know why.
In the first problem you solved [itex]\vec{A}[/itex] for a current going in the +z direction. So use that to solve this next problem.
I think I got it. So because +I flows in the positive direction it must be negative and the opposite must be true for the wire with -I.
One more question:
For problem 4 on that document it says,
Problem Statement
The wires are now very close to each other. Determine [tex]\vec{A}(r,\theta)[/tex] such as r >> a and by keeping the first and second order terms in (a/r).
Remember that [tex](1 + \epsilon)^{n} = 1 + n\epsilon[/tex]
and [tex]ln(1 + \epsilon) = \epsilon, \epsilon << 1[/tex]
Now I know he wants us to approximate the answer by expanding[tex]\vec{A}(P) = \frac{\mu_{0}I}{2\pi}ln\left(\frac{r_{1}}{r_{2}}\right)[/tex]
with a Taylor Expansion in [tex] \epsilon = \frac{a}{r} << 1[/tex] but I don't see how to do this when the distance between the wires [tex]2a[/tex] never comes up in any of our answers.
I really appreciate all the help nickjer.
Now you will need to write out [itex]r_1[/itex] and [itex]r_2[/itex] in terms of r and a. I suggest using the law of cosines.
OK. Thanks again for all of your help nickjer.
Related to Magnetostatics: Magnetic Vector Potential
What is "Magnetostatics"?
Magnetostatics is the branch of electromagnetism that studies the behavior of electric charges and currents that are either at rest or in constant motion. This field of study focuses on the effects of magnetic fields on charged particles and the resulting magnetic forces.
What is the "Magnetic Vector Potential"?
The magnetic vector potential is a mathematical concept used to describe the direction and magnitude of a magnetic field in a given space. It is a vector quantity represented by the symbol A and is used in the mathematical formulation of Maxwell's equations, which describe the behavior of electromagnetic fields.
How is the Magnetic Vector Potential related to Magnetostatics?
In Magnetostatics, the magnetic vector potential is used to represent the magnetic field in a given space. It is related to the magnetic field through the equation B = ∇ x A, where B is the magnetic field and ∇ is the gradient operator. This relationship allows for the calculation of magnetic fields in various situations, such as around a current-carrying wire or within a permanent magnet.
What are the applications of Magnetostatics and the Magnetic Vector Potential?
Magnetostatics and the magnetic vector potential have many practical applications, including the design of electric motors, generators, and transformers. They are also used in medical imaging techniques such as magnetic resonance imaging (MRI) and in the development of magnetic levitation technology.
How is Magnetostatics different from Electrostatics?
While both Magnetostatics and Electrostatics deal with the behavior of electric charges, they differ in that Magnetostatics focuses on the behavior of charges and currents in motion, while Electrostatics deals with stationary charges. Additionally, Magnetostatics involves the study of magnetic fields and their effects, while Electrostatics deals with electric fields and their effects.
