Magnitude and Direction Force Problem
In summary: I must be putting something in the calculator wrong or something. And the other way with the with the tan of (α-30) I end up with -3.29 which is also wrong.In summary, the task is to use the cosine and sine rules to determine the magnitude and direction of the resultant of a force of 11 kN acting at an angle of 50 degrees to the horizontal and a force of 8 kN acting at an angle of -30 degrees to the horizontal. The magnitude of the resultant is found to be 14.29783742 kN. To find the angle of the resultant with the horizontal, one can use the law of tangents by setting up the equation tan(α) = (
Dr Meow
Use the cosine and sine rules to determine the magnitude and direction of the resultant of a force of 11 kN acting at an angle of 50 degrees to the horizontal and a force of 8 kN acting at an angle of -30 degrees to the horizontal.
Law of Sines: (a/sinA) = (b/sinB) = (c/sinC)
Law of Cosines: b^2 = a^2 + c^2 - 2*a*c*cosB
Ok, so I actually already solved for the magnitude to be 14.29783742 kN. But the other blank for the question is for "degrees to the horizontal". I may not be understanding the term correctly but I have no real idea of how to solve for this.
Hi Dr Meow! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
(btw, 14.29783742 kN is slightly overdoing the accuracy! :wink:)
Find the angle between the resultant and the 11kN force …
then subtract that angle from 50º (which is the angle between the 11kN force and the horizontal) to get the angle between the resultant and the horizontal. :wink:
Isn't the resultant just the horizontal line? I'm sorry I did this problem a while ago and I don't remember how I did it. And the reason for the accuracy is because I'm doing this problem on WebAssign and you can't round to put in the right answer.
I don't think so … how did you get that?
(and I don't make it 14.29783742)
I'm sorry, I didn't understand what you really meant by the resultant in this case. When you said solve for the resultant.
Hi Dr Meow! :smile:
(just got up :zzz: …)
The "resultant" was in the question that you asked …
It means the (vector) sum of the two forces.
I thought you knew that, because you found its magnitude. :confused:
Had you forgotten what you did?
btw, I didn't say "solve for the resultant", I said …
Hey sorry it's taken me so long to reply I had forgotten about this. To be honest I did forget how I found the magnitude. And I'm still not sure because it's been even longer. Is there a way you could help me do just the degrees to the horizontal?
Thanks
Hi Dr Meow! Happy new year! :wink:
Show us what you've done, and where you're stuck, and then we'll know how to help. :smile:
Ok. So here's what I've done: To get the magnitude I drew a diagram of the 30 degree angle downwards and the 50 degree angle upwards. Then combined them to make a total of 80 degrees and used law of cosines to find the hypotenuse of the total triangle created and found that to be 14.29, which is correct. What I'm unsure of is exactly how to find the "degrees to the horizontal".
If α is the angle of the resultant of P and Q with P ( here it is 8 kN), then with a simple geometry you can show that
tan(α) = Q*sinθ/(P + Q*cosθ), where θ is the angle between P and Q.
Then (α - 30) will be the angle of the resultant with horizontal.
So would it end up being tan(α) = (11)*sin(80)/[(8 + 11)*cos(80)]? Then (α - 30) Because when I computed that all out it ended up to be the wrong answer.
I am getting α = 47.54 degrees. What is your answer?
There is another method.
Find the vertical and horizontal components of 11 kN and 8 kN.
If φ is the angle between the resultant and horizontal, then
tanφ = ΣFy/ΣFx
[ tan(α) = (11)*sin(80)/[(8 + 11)*cos(80)]?
This is wrong.
It should be
tan(α) = (11)*sin(80)/[(8 + 11*cos(80)]?
This is wrong.
It should be
Even then I end up with -24.325 which is wrong.
Related to Magnitude and Direction Force Problem
1. What is magnitude and direction force problem?
The magnitude and direction force problem is a physics concept that involves determining the strength and direction of a force acting on an object. It requires the use of vector addition to find the resultant force.
2. How do you calculate the magnitude of a force?
The magnitude of a force is calculated using the formula F = ma, where F is the force in Newtons, m is the mass in kilograms, and a is the acceleration in meters per second squared.
3. Can the direction of a force be negative?
Yes, the direction of a force can be negative. This indicates that the force is acting in the opposite direction of the chosen reference point.
4. How do you represent a force vector?
A force vector is represented by an arrow pointing in the direction of the force with a length proportional to the magnitude of the force. The direction of the arrow indicates the direction of the force.
5. What is the difference between magnitude and direction of a force?
The magnitude of a force refers to the strength or size of the force, while the direction of a force refers to the path or angle in which the force is acting. Both magnitude and direction are necessary to fully describe a force vector.
