Magnitude and Direction of an (E) Electric field of a square
In summary, the homework statement is trying to find the direction and magnitude of the electric field at the center of a square of charges. The attempted solution is to use the equation for the electric field, and to know the angles between the charges and the test point. Once these are known, the direction and magnitude of the electric field can be calculated.
Sipko
What is E in Magnitude and Direction at the center of the square of (fig. 3-7). Assume that q = 10x10-8 C and a = 5 cm
Now I have am not well versed with vectors, I don't like them and they don't like me.
I can not figure out the directions the magnitudes move in.
r=1/2(√2 a) = a/√2
E=k*q/r2
ETotal = E1 + E2 + E3 + E4
So far I only managed to do this:
r= 5.0cm/√2 = 3.55*10-2
E-q=(8.99*109)*((-1.0*10-8 C)/(3.55*10-2 m)) = 7.13*104 N/C
E2q=(8.99*109)*(2*(-1.0*10-8 C)/(3.55*10-2 m)) = 1.43*105 N/C
And since the other magnitudes are the same I don't need to calculate the others.
So the next step involves knowing exactly which angles you need to calculate everything together. And that's what is giving me trouble.
Oh, please do make friends with the vectors. They are just waiting to shower you with love. All they ask is that you put some effort into getting to know them, and they will kindly return the favor with friendship and good grades. :smile:
r=1/2(√2 a) = a/√2
E=k*q/r2
r= 50cm/√2 = 3.55*10-2
I think you mean "5 cm" rather than "50 cm," but you seemed to have used the correct value in your calculation.
But there is another typo when you wrote the result down. The radius isn't quite what you specified; it's close, but not quite.
[Edit: there's a few typos in your intermediate steps such as using 1.0 x 10-8C instead of 10 x 10-8C, and forgetting to square the radius, but it seems you worked out some of these things correctly in your calculations (although you should still fix the slight radius calculation error discussed above).]
So yes, the next step is breaking up the individual electric field contributions into their respective x- and y-components.
In electrostatics, the electric field from a given, positive point charge points from the point charge in question to the test point (in this case the test point is point P). Don't forget to take the sign of the particular point charge into consideration. It's the opposite direction if the point charge is negative.
As far as the angles go, remember the charges lie on a square, and the test point P is at the center. Can you form any triangles between a given charge and the test point P? Do you see any right angles in your triangle? Remember, the sum of all angles in a triangle always sum to 180 degrees.
Also, there is some symmetry in the charge configuration. Taking note of this symmetry will cut the required calculation effort in half.
Corrected 50cm to 5.0. Yes that was a typo.
For my professor it is more important to understand the problem rather than the exact number. So close should be close enough. :)
But for the sake of being exact here It should have been 3.53*10-2.
So and if we are going to Look at directions I imagine I am looking at something like this:
Where positive charges have a somewhat "repelling" force negative ones have a somewhat "Pulling" force. (I know that's cheesy but I couldn't quite find the words in english)
And since all of these forces are directed whether outwards or towards a particular charge I can see that in my example the direction of the Electric field in this case is heading towards the "-X" direction. Correct so far?
Yes, very nice. :smile: That is correct so far.
As you've determined, the y-components sum to zero due to symmetry.
So now, concentrate on the x-components of each vector. You'll still need to calculate those and sum them together.
So considering the vectors I found this:
I understand that the individual vectors of each charge seem to cancel out.
But I still don't quite grasp what I have to do to figure out the angles.
I know it's staring me in the face... :)
Triangles.
There are triangles in the diagram you made if you would prefer to use those. Or you can form new triangles too. Anyway, do you see any obviously 90 degree angles (i.e. right angles) in there anywhere?
Keeping in mind that all the angles of a triangle add up to 180 degrees. If one of the angles of the triangle is 90 degrees (opposite the hypotenuse), and the other sides of the triangle, besides of the hypotenuse, are of equal length (meaning the other two angles are equal to each other) what are those other two angles?
Of course. from point P to their respective charges form a triangle.
And the 45° Angle going from each charge towards the point P is quite obvious.
Edit: So does it mean that all of the angles are 45°?
So are all of them positive or are the angles from the -q charges towards the +2q charges negative and the angles from the +2q charges toward the -q charges positive?
Likes collinsmark
To be more exact about my edit above,
If I take the angle (between the x-vectors and the vectors heading towards the point P) how would I go about telling whether they are positive or negative?
And should they all be 45°?
Like:
ETotal= (-7.13*104)*(cos(-45°)+sin(-45°))+
+(1.43*105)*(cos(45°)+sin(45°))+
+...(1 more time each..)
Or simply the two above *2 would give the same result i suppose.
All that would equal to 4.4*105
this?
Before you start with the particular vector component, make sure you have the 2- or 3-dimensional vector in you mind, or better yet, drawn out on a diagram. Remember, for positive charges the vector starts from the point charge and ends at the test point; it's reverse for negative point charges.
Then to get the x-components of each vector, imagine that a light is cast on the vector such that the light rays are perpendicular to the x-axis. Thus imagine that the vector's shadow is on the x-axis. Then ask yourself whether the shadow points toward positive or negative x.
It turns out that in this particular problem, all x-components point in the same direction: along negative x. But that is just this particular problem.
Yes, in this problem, all the angles are 45°.
Like:
this?
Something is not quite right with the math there.
For starters, recalculate the magnitudes. They seems to be off by about a factor of 2 or so. (sorry if I didn't make that clear in my earlier post.)
Then I'm not sure I follow the the "(cos(-45°)+sin(-45°))" parts, unless that is the result of factoring after adding two components together, in which case there wouldn't be a need for "+...(1 more time each..)" section.
For an individual vector component, there need only be a single trigonometric function (in this particular problem where the arrangement is in 2-dimensions).
Likes Sipko
Sadly I ran out of time and I had to send in what I had yesterday, otherwise all the other homeworks I have done already wouldn't have been accepted. I know Its bad to leave things undone but I have to say that this topic can be closed now. But thanks for your help anyway.
Related to Magnitude and Direction of an (E) Electric field of a square
1. What is the formula for calculating the magnitude of an electric field for a square?
The formula for calculating the magnitude of an electric field for a square is E = kQ/d^2, where E is the electric field strength, k is the Coulomb's constant (9x10^9 Nm^2/C^2), Q is the charge of the square, and d is the distance from the center of the square.
2. How do you determine the direction of an electric field for a square?
The direction of an electric field for a square is determined by using the right hand rule. If the charge of the square is positive, the direction of the electric field is outward from the square. If the charge is negative, the direction is inward towards the square.
3. What factors affect the magnitude and direction of an electric field for a square?
The magnitude and direction of an electric field for a square are affected by the charge of the square, the distance from the square, and the medium in which the square is located. Changes in any of these factors can alter the strength and direction of the electric field.
4. How does the shape of a square affect the electric field around it?
The shape of a square does not have a significant effect on the electric field around it. As long as the charge and distance are the same, the electric field will have the same magnitude and direction regardless of the shape of the square.
5. Can the electric field of a square be negative?
Yes, the electric field of a square can be negative if the charge of the square is negative. In this case, the direction of the electric field would be inward towards the square, indicating a negative field. However, the magnitude of the electric field can never be negative.
