Magnitude and direction of an electric field outside of a plate?
A circular metal plate with a radius of 0.2 m has 10^10 excess electrons uniformly distributed, leading to confusion about calculating the electric field just outside the plate. Initial calculations incorrectly assumed all charge concentrated at a point, yielding an unrealistic field strength of 3.6 x 10^12 N/C instead of the expected 720 N/C. The correct approach involves using Gauss's Law to determine the surface charge density and the electric field, which requires integrating or setting up a Gaussian surface. The surface charge density was calculated as 2.04 x 10^-13 C/m², and the correct formula for the electric field just outside the plate was clarified as E = 2πkσ. The discussion emphasizes the importance of understanding Gaussian surfaces and charge distribution in electric field calculations.
Violagirl
A circular metal plate of radius 0.2 m has 1010 excess electrons uniformly distributed over its surfaces. What is the magnitude and direction of the field just outside the plate near its center?
E = kQ/r2
Starting with E = kQ/r2,
I solved for Q: (1010) (1.60 x 10-9 C)
= 16 C
Plugging into the equation for E:
E = (16 C) (9.0 x 109 N m2/C2) / (.02 m)2
I end up with a really high value of 3.6 x 1012 N/C.
However, I know this is wrong because I should end up with a value of around 720. What am I doing wrong?
For direction, I know the electron will move towards the plate.
Violagirl said:
E = kQ/r2
I like gauss law better.:biggrin:
= 16 C
Charge of electron is 1.6x10-19
It is because you are assuming all charge to be at the same place. In this case you will either need to integrate (long and tedious) or use gauss' law.
Compute the surface charge density σ. Then, if you don't know the formula for the E field just outside the plate, set up a gaussian surface, say a right circular cylinder, with one end-surface inside the plate and the other just outside. Then compute net flux leaving the surfaces. Remember to make the height of the cylinder very short. EDIT: also the area of the end sections.
Ok so Gauss's Law is:
E = 2pikσ
Q = (1010) (1.6 x 10-19) C
Q = 1.6 x 10-9 C
σ = Q/A = 1.6 x 10-9 C/pi (.02)2 = 2.04 x 10-13 C/m2
E = 2pi (9.0 x 109 N m2/C2) (2.04 x 10-13 C/m2)
E = .011
I'm still not sure where I'm going wrong with this..
What is the total surface area of the plate?
And Gauss' law does not look like what you wrote. What is k?
E = 2pikσ
Actually
##\int E.ds=\frac{q}{ε_{o}}##
##E.A=\frac{q}{ε_{o}}##
##E=\frac {σ}{ε_{o}}## As field is perpendicular to the face of cylinder.
##E=\frac{σ}{1/4 \pi k}##
##E=4 \pi \sigma k##
Oh whoops, ok, I see I wrote the expression for a conductor, sorry about that! Gauss's Law is otherwise expressed as:
∅E = Q /ε0
Total surface area of the plate, isn't it A = pi*r2?
So finding Q again:
Q = (1010) (1.6 x 10-19 C) = 1.6 x 10-9 C
∅E = (1.6 x 10-9 C) / (8.85 x 10-12 F m-1) = 181?
The final answer should be 720. I'm not sure if I'm missing something to this problem...
Lets begin at the beginning. What is your Gaussian surface?
Ok so for a circular plate, will my Gaussian surface be:
E =4pi*r2?
That is the equation for a gaussian surface (what gaussian surface I have no idea). Gaussian surface is a 3D closed figure.
See post #3 by rude man.
I'm not finding much on how to compute finding a value for the Gaussian surface of a circular plate though. Unless I need to integrate the area of A for what a circular plate would normally be? i.e. A of a circle = TTr2?
Okay, let's take RM's gaussian surface.
Let the radius of cylinder be r and height be h.
Now this cylinder will enclose how much charge?
So for a cylinder:
Won't we have, E = kQ/r-h, so to solve for Q, we'd end up with an equation of:
E(r-h)/k = Q
Is this correct? Am I thinking about this right?
Noooo...
Lets put that equation aside for this sum.
What is the charge in the cylinder?
You have the charge of the disc and its area (remember a disc has 2 sides) So find the surface charge density and multiply it with area of the disc our gaussian surface i.e.. cylinder encloses.
Sorry, its getting a bit late here. I am off to :zzz:
For your problem:
After you have got the charge enclosed, just use the Gauss's law expression. Note that you only need the area of the top face of the cylinder, as h and r are very small, we can assume E to be perpendicular to that face.
:wink:
  • · Replies 16 ·
  • · Replies 26 ·
