Magnitude and Direction of Electric Field at the origin? Please help
In summary: I don't know what to call it. :confused: summary.In summary, the electric field at the origin is given by: E(r) = k*Q/r2. Q is found by the problem statement and is λ*Δr/r2.
SilverGirl
27
A continuous line of charge lies along the x axis, extending from x=+xo to positive infinity. The line carries charge with a uniform linear charge density lambda. What are the magnitude and direction of the electric field at the origin?
E = lambda/2pieor for the magnitude of electric field produced by a uniformly charged infinite line.
I have drawn a cylindrical Gaussian Surface around it. By the wording of the question, I am not sure where the line of charge is placed (does it start at the origin?). I have placed the line at the origin, with the cylinder starting at the origin. I have concluded (not sure if it is correct) that the field on the end of the cylinder is equal to zero, because the field can only pass through the center of the circle.
Am I close at all to the answer?
I have drawn a cylindrical Gaussian Surface around it. By the wording of the question, I am not sure where the line of charge is placed (does it start at the origin?) …
Hi SilverGirl! :smile:
(have a pi: π and an epsilon: ε and a lambda: λ and an infinity: ∞ :smile:)
No, the line starts at x0 and goes to +∞.
hmm … no idea what you mean by a cylindrical Gaussian Surface. :confused:
Hint: slice the line into bits of length dx, and integrate from x0 to +∞. :smile:
Is xo at any particular place on the x-axis though? Maybe I didn't have to use the cylinder.
erm … it's at x0 ! :confused:
isn't that particular enough for you? :wink:
Not really..lol..because couldn't x0 be at the origin? Also, couldn't it be very very far away from the origin? Do you know of a way to do this without integrating?
No, because the question says "+x0", and 0 isn't + :smile:
Nope! :biggrin:
lol..good point.
I am guessing the field is not 0 at the origin, even though the line of charge is not there.
Yes, you're right. It's not zero at the origin. It would be zero if the line extended from [tex]-\infty[/tex] to [tex]\infty[/tex]. Now tiny-tim's hint was to integrate it. You need to start with [tex]dE = \frac{dq}{4\pi \varepsilon_0 r(x)^2}[/tex], where r(x) is function of x which tells you the distance from any point on the line of charge to the origin.
You still need to express dq in some other way so that the integration can be done.
By symmetry, you should be able to determine what the E-field direction at O should be.
I've been using this problem for reference but I am so lost...I'm doing the same exact thing.
I am having trouble integrating. Could someone please walk me through it step by step with this equation?
Hi Doc Z! :smile:
Show us how far you've got with the equation (and which equation? :confused:), and where you're stuck, and then we'll know how to help. :smile:
I'm using E=2ke * lambda/r
I pretty much don't even know how to start integrating this.
What do you get? :smile:
I found the answer to be ke * lambda/x0 in the -i direction but I don't understand how to get it. I don't remember integrals too well.
You know that E = k*Q/r2 for a point charge.
So the field at the origin from any point over the range of charges is given by
E(r) = k*Q/r2
But Q by the problem statement is
ΔQ = λ * Δr
Rewriting the equation:
E(r) = k * λ * Δr/r2
Consequently then to sum up all the charge elements from r = xo to r = ∞ you take the definite integral.
[tex] E_{(r)} = \int_{x_0}^{\infty} \frac{k * \lambda * dr}{r^2} [/tex]
Thanks for the help!
FAQ: Magnitude and Direction of Electric Field at the origin? Please help
What is the concept of magnitude and direction of electric field at the origin?
The magnitude and direction of electric field at the origin refers to the strength and direction of the electric field at a specific point in space, which is the origin. It is a vector quantity that describes the force per unit charge that a charged particle would experience at that point.
How is the magnitude of electric field at the origin calculated?
The magnitude of electric field at the origin can be calculated using the equation E = kQ/r^2, where k is the Coulomb's constant, Q is the charge creating the electric field, and r is the distance from the origin to the charge.
What factors affect the direction of electric field at the origin?
The direction of electric field at the origin is affected by the direction of the electric force, which is always directed away from a positive charge and towards a negative charge. It is also influenced by the presence and position of other charges in the surrounding space.
Can the direction of electric field at the origin be changed?
Yes, the direction of electric field at the origin can be changed by manipulating the position and magnitude of the charges creating the electric field. It can also be influenced by the presence of conductors and insulators in the surrounding space.
Why is the origin often used as a reference point for calculating electric field?
The origin is often used as a reference point for calculating electric field because it allows for a consistent and easily measurable starting point. Additionally, the electric field at the origin is representative of the overall electric field in the surrounding space, making it a useful point for analysis and calculations.
