Magnitude of Electric Field from an Atom
In summary, the conversation discusses the calculation of the electric field at a distance of 6.5x10-10 m from a neutral neptunium atom with 93 electrons. The calculation involves using Gauss's law and taking into consideration the enclosed charge within a surface. It is found that the atomic radius of neptunium is 175pm, making 6.5x10-10 m well outside of the radius of the atom.
Hypnos_16
153
The neutral neptunium atom has 93 electrons.
What is the magnitude of its electric field at a distance of 6.5x10-10 m from the nucleus?
Hint: The number of protons in a nucleus is equal to the number of electrons in the neutral atom.
q = 1.6e-19 * 93 = 1.48e-17
r = 6.5e-10
k = 8.99e9
E = kq / r2
I would think that it would just be E = kq / r2 since we have all the variables we need.
E = kq / r2
E = (8.99e9)(1.48e-17) / (6.5e-10)2
E = 1.33e-7 / (6.5e-10)2
E = 3.16e11 => 3.16 x 1011 N/C
However turns out that isn't the right answer. So i took the hint into consideration, but can't see how it fits into play. If there are 93 Electrons and 93 Protons wouldn't it mean the charge would just be 0?
Any help?
Can you apply Gauss's law at this radius?
Sure, but what will that do?
Gauss's Law = EA
= (3.16e11)(4π(6.5e-10)2)
= 1.67e-6
What is the size of such a atom?
Well, you can relate the charge enclosed within a surface to the electric field at the surface regardless of how the charge is distributed. So at the this radius what charge is enclosed?
-1.67e-6 = [k(q) / r2] * [4πr2]
-1.67e-6 / [4πr2] = [k(q) / r2]
-1.67e-6[r2] / [4πr2] = k(q)
-1.67e-6 / 4π = k(q)
-1.33e-7 = k(q)
q = -1.33e-7 / 8.99e9
q = -1.48e-17 N/C
Related to Magnitude of Electric Field from an Atom
1. What is the magnitude of the electric field from an atom?
The magnitude of the electric field from an atom depends on the charge of the atom and its distance from the point where the electric field is being measured. It is typically on the order of 10^6 N/C.
2. How is the magnitude of the electric field calculated for an atom?
The magnitude of the electric field from an atom can be calculated using Coulomb's law, which states that the electric field is directly proportional to the charge of the atom and inversely proportional to the square of the distance between the atom and the point where the electric field is being measured.
3. Does the magnitude of the electric field from an atom change?
Yes, the magnitude of the electric field from an atom can change depending on the charge of the atom and its distance from the point where the electric field is being measured. It can also change if the atom gains or loses electrons, altering its overall charge.
4. How does the magnitude of the electric field from an atom affect its surroundings?
The magnitude of the electric field from an atom can affect its surroundings by attracting or repelling other charged particles. This can lead to the formation of bonds between atoms or the movement of particles in an electric field.
5. Can the magnitude of the electric field from an atom be manipulated?
Yes, the magnitude of the electric field from an atom can be manipulated by changing the charge of the atom or altering its distance from the point where the electric field is being measured. This can be done through various methods such as applying an external electric field or introducing other charged particles.
