Magnitude of force of a disk on a circular track
In summary, a small disc with radius r and mass m = 7.9 g rolls down a track and reaches a circular section with a much larger radius. The initial height of the disc is 30.4 cm above the lowest point of the track. When it reaches the top of the circular section, the magnitude of the force it exerts on the track can be found using conservation of energy and considering the normal and gravitational forces acting on the disc. However, the concept of centrifugal force should not be applied in this scenario.
dodosenpai
A small disc, radius r and mass m = 7.9 g, rolls on its edge. The friction with the track is enough to prevent slipping. When released, it rolls down the track (sketch) and reaches a circular section with radius R = 5.1 cm, which is very much greater than r. The initial height of m above the lowest point of the track is h = 30.4 cm. The disc reaches the top of the circular part of the track. When it does so, what is the magnitude of the force the disc exerts on the track? (Hints: how fast is it going? and don't forget to draw a free body diagram)
½mvi2+mghi = ½mvf2+mghf
Fc=mv2/r
The initial height is 30.4cm from the bottom while the final height is 10.2cm from the bottom, therefore the change in height is 20.2cm = 0.202m
At the top, the force of the disk on the track would be the centrifugal force pushing it against the track which is equal to the centripetal force
Subbing into conservation of energy to get the velocity:
Initial v is 0, therefore:
mghi = ½mvf2 + mghf
divide by m and rearrange
v = √2*g*(hi-hf)
sub in values
v = √2*9.8*0.202
= 1.98977
subbing it into mv2/r:
(0.0079*1.989772)/0.051 = 0.61N
What did I do incorrectly?
The centripetal force is the radial component of the net force. What other forces act on the disc?
Gravity and the Normal Force, both pointing downwards and equal in magnitude
Why would they be equal in magnitude?
Nevermind they aren't
So at the top the normal, gravity and centripetal force are all acting downwards while the centrifugal force acts outwards? So the force of the ball on the track would be the centrifugal force - normal force since the centripetal force should be provided by gravity?
Don't mix centrifugal and centripetal in the same analysis. They are two different ways of viewing the same thing.
In an inertial frame, there is centripetal, not centrifugal. But centripetal force is not an actual force acting on the system. It is the radial component of the resultant of the actual forces. The actual forces are the normal force and gravity:
Centripetal force = radial component of ( normal + gravity).
In the frame of reference of the accelerated body, there is no acceleration, by definition. Yet there are forces (such as normal and gravity). To explain this you have to invent a balancing force, which we call centrifugal. If you are being spun around in a drum, you feel the normal force from the wall of the drum, and to explain it you feel there must be an outward force pushing you against the wall.
For more on the subject, see https://www.physicsforums.com/insights/frequently-made-errors-pseudo-resultant-forces/
FAQ: Magnitude of force of a disk on a circular track
What is the formula for calculating the magnitude of force of a disk on a circular track?
The formula for calculating the magnitude of force of a disk on a circular track is F = mω^2r, where F is the force, m is the mass of the disk, ω is the angular velocity of the disk, and r is the radius of the circular track.
How does the mass of the disk affect the magnitude of force?
The greater the mass of the disk, the greater the magnitude of force required to keep it moving in a circular path on the track.
What is the role of the angular velocity in determining the magnitude of force?
The angular velocity of the disk determines the speed at which it is rotating on the circular track. As the angular velocity increases, the magnitude of force also increases.
How does the radius of the circular track affect the magnitude of force?
The greater the radius of the circular track, the smaller the magnitude of force required to keep the disk moving at a constant speed on the track.
Is the magnitude of force constant throughout the circular track?
No, the magnitude of force is not constant throughout the circular track. It varies depending on the position of the disk on the track and is highest at the top and lowest at the bottom of the track.
