Magnitude of force one crate exerts on another (both touching)
In summary, the problem involves three crates being pushed over a concrete floor by a horizontal force of 647 N. The masses of the crates are 28 kg, 12 kg, and 22 kg, and the coefficient of kinetic friction between the floor and each crate is 0.7. The question asks for the magnitude of the force on crate 3 from crate 2. To solve the problem, the gravitational and frictional forces of each crate were calculated, and the net horizontal force was found by subtracting the forces of friction from the given force. This net force was then used to find the acceleration, which was then multiplied by the mass of crate 3 to find the force on crate 3. However, this answer
bp789
1. Homework Statement
There is an attachment of the picture of the problem.
The figure shows three crates being pushed over a concrete floor by a horizontal force F of magnitude 647 N. The masses of the crates are m1 = 28 kg, m2 = 12 kg, and m3 = 22 kg. The coefficient of kinetic friction between the floor and each of the crates is 0.7. What is the magnitude F32 of the force on crate 3 from crate 2?
2. Homework Equations
F=ma
Ffric=μN
Fg=mg
3. The Attempt at a Solution
Okay, so the first thing I did was find the gravitational forces of all three crates, which would also mean finding the normal force of each of the three crates since the gravitational and normal force cancel each other out, and there aren't any other forces in the vertical direction.
Crate 1: Fg=(28 kg)(9.8 m/s2)=274.4 N
Crate 2: Fg=(12 kg)(9.8 m/s2)=117.6 N
Crate 3: Fg=(22 kg)(9.8 m/s2)=215.6 N
Next, I found all of the forces of friction of the crates
Crate 1: Ffric=(0.7)(274.4 N)=192.08 N
Crate 2: Ffric=(0.7)(117.6 N)=82.32 N
Crate 3: Ffric=(0.7)(215.6 N)=150.92 N
Next thing I did was to find the total net force by subtracting the forces of friction from the horizontal force given (647 N), and then use that number to find the acceleration. We know that a 647 N is the horizontal force given and is pushing the system so that force is also included in the net force.
Fnet=(647-192.08-82.32-150.92)=221.68
Fnet=ma
221.68=(28+12+22)a
221.68=62a
a=3.575 m/s2
Now according to the tutorial of the question in my online textbook, all of this above information is correct and we have everything we need to find the answer.
I assumed that the next thing to do was to multiply the acceleration we found by the mass of crate 3 because we are looking for the magnitude of the force on crate 3 by crate 2. I did:
F=(22 kg)(3.575 m/s2)=78.66 N
However, when I checked my answer, it said it was wrong. The program doesn't give me the correct answer. I have to figure it out for myself and then it will tell me whether it is correct or not, but I'm not sure what I did wrong here?...
Consider ALL the forces acting on crate 3, not just the interaction from crate 2.
FAQ: Magnitude of force one crate exerts on another (both touching)
What is the definition of magnitude of force?
The magnitude of force refers to the amount of force that is exerted on an object. It is a measure of the strength or intensity of the force.
How do you calculate the magnitude of force?
The magnitude of force can be calculated using the formula F = m x a, where F is force, m is mass, and a is acceleration. In the case of two objects in contact, the magnitude of force can also be calculated using the formula F = μN, where μ is the coefficient of friction and N is the normal force between the two objects.
What factors affect the magnitude of force between two objects?
The magnitude of force between two objects can be affected by several factors, such as the mass of the objects, the distance between them, the coefficient of friction, and the surface area of contact.
How does the magnitude of force change if the two objects are in motion?
If the two objects are in motion, the magnitude of force can change depending on the direction and speed of the objects. For example, if the objects are moving in the same direction, the magnitude of force may decrease, while if they are moving in opposite directions, the magnitude of force may increase.
Can the magnitude of force be negative?
Yes, the magnitude of force can be negative if the force is acting in the opposite direction of the motion. This can happen when there is friction between the two objects or when one object is pushing or pulling the other in the opposite direction.
