Magnitude of frictional force during terminal velocity
In summary, a parachutist is accelerating down and a force of friction slows his motion. When he reaches terminal velocity, the force of friction is zero and he falls to the ground.
Ace.
52
A parachutist, after jumping from the plane, is accelerating down with average acceleration of 1.6 m/s2 (relative to the ground). What is the force of friction slowing his motion is mass of the parachutist with his equipment is 124 kg? What is the frictional force when the parachutist reaches terminal velocity?
F = ma
F=ma
F=124 kg x 1.6 m/s2
F= 199.36 N [down]
Would the force of friction also be 199.36 N except in [up] direction because for every action there is an equal and opposite reaction?
What happens when he reaches terminal velocity? Wouldn't acceleration = 0 and cause force unbalance to equal to 0. Doesn't this mean the two forces of gravity and friction are equal but in opposite direction? So how do I find the frictional force upwards during terminal velocity?
Note that when F = ma is used the symbol F represents the RESULTANT force on the system.
Then when he is accelerating, resultant force (downwards) = weight - frictional force
and when he is moving at terminal speed, resultant force = 0.
F = ma
F=ma
F=124 kg x 1.6 m/s2
F= 199.36 N [down]
This is the net force acting down. There are 2 forces acting on the 'chutist. The net force is the vector sum of both.
No.
yes
yes
solve your last question!
Well...
Fg=ma
=124 kg x9.8m/s2 [down]
=1215.2 N[down]
This is force of gravity on the parachutist.
FNET = 199.36 N [down]
FNET = Fg + Ff
Ff = FNET - Fg
= 199.36 N[down] - 1215.2 N [down]​
= -1015.84 N [down]​
∴ Frictional force during Vterminal = 1015.84 N [up]
Ace. said:
Well...
Fg=ma
=1215.2 N[down]
FNET = Fg + Ff
Ff = FNET - Fg
This however is not right because frictional should be equal to gravity?
Am I overthinking everything and the frictional force at V_terminal is simply 1215.2 N [up] (magnitude of his weight).
EDIT: sorry for double posting, I accidentally clicked quote instead of edit and I don't know how to delete this
Yes - at terminal velocity friction must exactly "balance" weight force.
Okay, thank you.
Say Ace. it appears that you made an error in determining the direction of the friction force when the chutist is accelerating downward. One must be very careful in the use and interpretation of the minus sign. Please give this important topic some thought.
Related to Magnitude of frictional force during terminal velocity
What is the concept of terminal velocity?
Terminal velocity is the maximum speed that an object can reach when falling through a fluid, such as air or water. It occurs when the gravitational force on the object is equal to the drag force of the fluid. At this point, the object stops accelerating and continues to fall at a constant speed.
What factors affect the magnitude of frictional force during terminal velocity?
The magnitude of frictional force during terminal velocity is affected by the mass, shape, and surface area of the object, as well as the density and viscosity of the fluid it is falling through.
How is the magnitude of frictional force calculated during terminal velocity?
The magnitude of frictional force during terminal velocity can be calculated using the equation Fd = 1/2 * ρ * v^2 * Cd * A, where Fd is the drag force, ρ is the density of the fluid, v is the velocity of the object, Cd is the drag coefficient, and A is the cross-sectional area of the object.
What happens to the magnitude of frictional force if the object's velocity changes during terminal velocity?
If the object's velocity decreases, the magnitude of frictional force will also decrease, as there is less resistance from the fluid. If the object's velocity increases, the magnitude of frictional force will also increase, as there is more resistance from the fluid.
Can the magnitude of frictional force be greater than the force of gravity during terminal velocity?
No, the magnitude of frictional force can never be greater than the force of gravity during terminal velocity. This is because terminal velocity occurs when these two forces are equal, and if the frictional force were to become greater than the force of gravity, the object would decelerate and stop falling.
