Magnitude of the electric force a hydrogen nucleus exerts on electron?
In summary, the question asks for the magnitude of the electric force a hydrogen nucleus exerts on its only orbiting electron in the Bohr model. The attempt at a solution involved using the formula Fe = kQq/r^2, where Q and q are equal to each other at 1.6 x 10^-19, k is equal to 9 x 10^9, and the radius is 40 x 10^-19. The answer is typically 10^-7, but the person asking the question received an answer of 1.7 x 10^-7, which may be due to a typo or a difference in units. The conversation also mentions the importance of including units and references when discussing the work of
needingtoknow
160
What is the magnitude of the electric force a hydrogen nucleus exerts on its only orbiting electron in the Bohr model?
Fe = kQq/r^2
Since there is one proton and one electron. Q and q are equal to each other: 1.6 x 10^-19.
k = 9 x 10^9
and radius = 40 x 10^-19.
All the values are given in the question.
The answer is 10^-7 but I got 1.7 x 10^-7.
Why did they completely disregard the 1.7 ?
It's called an "order of magnitude" calculation.
Though it may be a typo - depends: who is "they"?
Note: don't forget the units.
Thank you I shall look into that! Sorry they is the people who wrote the solution manual and I will remember to include units next time!
No worries - also remember, when you refer to the work of others, to include their names and the title of the work in question. Otherwise the reference is meaningless. ;)
Note: if you use k=9x10^9 SI units, then your answer should be to 1 sig fig too.
Isn't the radius supposed to be (5.3 x 10-11)?? How did you get (40 x 10-19)??
I solved the problem the same way you did so (except that i switched the radius) and found that the answer came to be -0.82 x 10-7 C.
Bohr radius (order e-11) would be a good choice, yes... you could akso have used e-10 (angstrom = order of magnitude size of an atom) OPs order e-19 meters would be inside the nucleus.
Note. Dont forget units, and justify/critique guessed numbers using a physical reference. Youd probably get away with it is a secondary course but college usually penalises you if you use the correct value without indicating why. IRL if you do this you don't get published/paid.
FAQ: Magnitude of the electric force a hydrogen nucleus exerts on electron?
What is the magnitude of the electric force between a hydrogen nucleus and an electron?
The magnitude of the electric force between a hydrogen nucleus and an electron is approximately 8.99 x 10^9 Nm^2/C^2, also known as the Coulomb constant or the electric constant.
How is the magnitude of the electric force between a hydrogen nucleus and an electron calculated?
The magnitude of the electric force between a hydrogen nucleus and an electron can be calculated using Coulomb's law, which states that the force is equal to the product of the two charges divided by the square of the distance between them.
Does the magnitude of the electric force change as the distance between the hydrogen nucleus and electron changes?
Yes, the magnitude of the electric force between a hydrogen nucleus and an electron decreases as the distance between them increases, according to Coulomb's law. This is because the force is inversely proportional to the square of the distance.
How does the magnitude of the electric force between a hydrogen nucleus and an electron compare to other forces in nature?
The magnitude of the electric force between a hydrogen nucleus and an electron is considered to be one of the strongest forces in nature, along with the strong nuclear force and the weak nuclear force. It is significantly stronger than the force of gravity.
How does the magnitude of the electric force between a hydrogen nucleus and an electron affect the stability of an atom?
The magnitude of the electric force between a hydrogen nucleus and an electron is crucial for the stability of an atom. This force keeps the electron in orbit around the nucleus and helps to balance out the repulsion between the positively charged nucleus and negatively charged electrons.
