Magnitude of velocity and impulse
In summary: No air resistance, gravity 9.81m/s^2, constant force3>How does my work look for the other parts?It looks like you've completed the diagram and calculations.
Westin
87
In one of MSU’s seven sacks, MSU linebacker Denicos Allen sacked UM quarterback Devin Gardner. Just prior to being sacked, the quarterback was at rest. Just after they collided, the two players were momentarily stuck together and both slide a distance of 1.5 m before coming to a stop. In addition, assume this motion was purely horizontal. Denico Allen’s mass was 103.3 kg and Devin Gardner’s mass was 92.8 kg.
(a) Draw a free-body diagram of Denicos Allen and Devin Gardner as they slide as one body along the field surface of Spartan Stadium.
(b) The acceleration of the two players due to the frictional force is 2.45 m/s2. What was the magnitude of the velocity of the two players immediately after their collision?
(c) What was the total impulse delivered to the two players during their slide?
(d) What was the magnitude of the velocity of Denicos Allen just before he sacked the quarterback?
(e) In answer (d), what assumption did you make?
p=mv
F=ma
F= p/t
v=d/t
a= v/t
Ffriction=uN
Force going down: mass*gravity
Force going up: force of players
Force going to left: friction
Force going to right: Force of Denicos Allen
If you assume the motion is purely horizontal, then would you disregard frictional force?****(b) The acceleration of the two players due to the frictional force is 2.45 m/s2. What was the magnitude of the velocity of the two players immediately after their collision?
v=sqrt((m1v1/(m1+2))^2+(m2v2/(m1+v2))^2)
v=sqrt((103.3*2.45/196.1)^2+(92.8*2.45/196.1)^2) = 1.735m/s
p=mv
p= 196.1*1.735= 340.2335 kg*m/s
vf=vi+(Fnet/m)*time
Im not sure how to find time(e) In answer (d), what assumption did you make?
[/B]
Responding to the following (arrows indicate points)
Force going up: force of players <<<1
If you assume the motion is purely horizontal, then would you disregard frictional force? <<<2
1> What does "force of players" mean?
2> s Spartan Stadium playing field really a frictionless playing surface?
I'm not sure how to find time
You may not need it ... is there another approach to the problem?
... and what is "force of Denicos Allen"?
1)I think you wouldn't consider friction because it says "If you assume the motion is purely horizontal"
2)force of players would just be their masses
3)How does my work look for the other parts?
I have no idea what logic leads you to that conclusion. If there were no friction, the players would slide forever.
A mass is not a force. If you mean the gravitational force resulting from their masses, you've already covered that:
They'd be the same thing, right? Both acting downwards.
What makes you think that purely horizontal motion implies no friction?
Perhaps you have been told that friction requires surface roughness, and so imagine an up-down jiggling would be present?
http://amasci.com/miscon/miscon4.html#fric
Related to Magnitude of velocity and impulse
1. What is the definition of magnitude of velocity?
The magnitude of velocity is the speed of an object in a particular direction. It is a vector quantity, meaning it has both a magnitude and a direction.
2. How is the magnitude of velocity calculated?
The magnitude of velocity can be calculated by taking the square root of the sum of the squares of the x, y, and z components of the velocity vector. Alternatively, it can also be calculated by dividing the distance traveled by the time it took to travel that distance.
3. What is the relationship between magnitude of velocity and speed?
The magnitude of velocity and speed are closely related, but they are not the same. Speed is a scalar quantity that only measures how fast an object is moving, while the magnitude of velocity also takes into account the direction of the motion.
4. What is the significance of the magnitude of velocity in physics?
The magnitude of velocity is an important concept in physics as it helps us understand the motion of objects. It is used in equations to calculate other important quantities such as acceleration and momentum.
5. How is the magnitude of velocity related to impulse?
The magnitude of velocity is related to impulse through the impulse-momentum theorem, which states that the impulse exerted on an object equals the change in the object's momentum. This means that the larger the magnitude of velocity, the greater the impulse needed to change the object's momentum.
