Magnitudes of the largest and smallest force?
In summary: Fg=Fgsin45-Fgcos45Fnet=Fa-Fs =mu(mgcos45+mg) =mu(9.8m/s^2)(22kg)cos45+mu(9.8m/s^2)(22kg) =75.9N+66.7N =142.6Nthe net force parallel to the ramp is 142.6NAm I on the right track?In summary, the conversation discusses the problem of determining the magnitude of the largest and smallest forces that can be applied to a box at rest on a ramp inclined at 45 degrees to the horizontal. The coefficients of friction between the box and the ramp
Fittler
This is what I have and I have a feeling that I do not understand.
11. A box with a mass of 22 kg is at rest on a ramp inclined at 45 (degrees) to the horizontal. The coefficients of friction between the box and the ramp are: (mu(s): o.78 and mu(k): o.65)
a) Determine the magnitude of the largest force that can be applied upward parallel to the ramp, if the box is to remain at rest.
Fa = Fgsin45(degrees) - mu(k)Fncos45(degrees)
=53.4N
b) Determine the magnitude of the smallest force that can be applied onto the top of the box, perpendicular to the ramp, if the box is to remain at rest.
Fa= Fgsin45(degrees) + mu(s)Fncos45(degrees)
=271.324N
So tell me, where di I go wrong?
=53.4N
Answer these questions:
(1) What's the normal force?
(2) What forces act on the box parallel to the ramp, including the applied force?
(3) What's the direction of the friction force?
(4) Since the box remains at rest, what must the net force be?
=271.324N
Answer the same questions, only this time realize that the applied force is perpendicular to the ramp.
Also: Since the box remains at rest, only static friction is involved.
So I drew a diagram and I am come up with the idea of needing touse the cosine. As in Cos45(deg)=Fn/9.8, which in turn gave me the force, and in turn I was able to use the Fs=(mu(s))Fn formula. Whatcha think? But I am still kind of stuck on the other one (b).
Not exactly sure what you are talking about. Why not answer the questions I posed? Step by step.
Allright so, we will go through it together?
The normal force is the force of gravity 9.8m/s^2 x mass
Since I do not know mass, it is 9.8m/s^2m
The forces that act parallel to the ramp on the box are the force of gravity, force of friction and the applied force.
The friction force is upward, (parallel to the ramp) but in the case of pushing down on the box, the friction force would be downwards.
F=ma or F=mg?
I dunno.
Good.
No, the normal force is not mg. That's the weight! (Yes, you are given the mass.)
Good.
I think you have it backwards. The friction force opposes slipping. When pushing up with max force, the friction pushes down; in the second problem, friction opposes gravity and thus acts upward.
F=ma or F=mg?
I want a number. (Think equilibrium.)
Allright:)
1. What's the normal force?
Is the normal force the cos of 45(deg) x 9.8? haha. I have no idea?
3. What's the direction of the friction force?
The friction force opposes motion of the applied force? So the friction force is acting downwards (parallel to the ramp). And the force of friction in part b) is acting to push the box upward, as a downward force is applied?
4. Since the box remains at rest, what must the net force be?
Thinking equillibrium, I could say that the normal force = the force of gravity?
I'll give you this one. In part (a) the normal force is [itex]mg\cos\theta[/itex]. Not so for part (b).
Correct. (Mostly.)
What's the net force parallel to the ramp?
Correct. (Mostly.)
hi again!
ok so i was looking at this problem and well i kind of came to this conclusion from the last quote on here.
Fnet=Fn+mgy
=mg+mgcostheta
=(22kg)(9.8m/s2)+(22kg)(9.8m/s2)cos45
=215.6+152.45
=367.45
the net force parallel to the ramp.
is that the net force? am I on the right track?
ok, I'm not sure if my last post was anywhere near correct...
I reworked it and this is what i came up with...
parallel forces to the ramp
Fg, Fs, Fa
sum of F= Fa - Fs - Fg
Fa=Fs + Fg
=usFn+mg
=(us)(mg)costheta+mg <-- do the mg cancel out?
=(us)costheta <--- I canceled them out
=(7.8)cos45
=5.5N
I'm not quite sure what you're doing. For one thing, the weight of the box acts vertically, not parallel to the incline.
Try answering the questions that I posed in post #2.
ok so after good session of thinking... lol
here are the answers to the questions you posed in post #2
the normal Force is Fn=FgNcostheta
Fs,Fa,Fgr
downward
if it will remain at rest both forces must be equal
so, Fa=Fs
Are you multiplying the force of gravity (Fg) by the normal force (N)?
Fs,Fa,Fgr
Which direction does Fg act? What component is parallel to the ramp?
downward
OK. Downward and parallel to the ramp.
so, Fa=Fs
What happened to gravity?
ummm... ok I'm really really confused...
do you mind solving the problem so i can understand how to even start it?
This post is for question b) The box is being pushed directly against the ramp. Therefore, why would the box move?
Wouldn't the smallest force that can be applied to the top of the box without it moving be 0.
Or are they asking about the smallest force that would make the box move? I don't know.
Is the box, like the question says, being pushed into the ramp or down it?
In question b) the applied force is perpendicular to the ramp (pushing the block directly against the ramp). If that force were zero, would the block slide down the ramp? Find out by analyzing the forces acting on the block. (Other forces act on the block, not just the applied force.)
thank you so much. your post just made me realize what i have to do.
So, what you are saying is that it is as if we can control the force of gravity, and we need to find out the minimum force of gravity needed to keep this box from sliding. Am I correct?
No. When the box is pushed directly into the ramp, gravity doesn't change. But the normal force does, which changes the friction force. Find the minimum friction force needed to keep the box from sliding. Then figure out the added force required to create such a friction force.
I see. Thank you
Hold on, maybe I don't see. I did the question and I got a value that was higher than the original normal force, which is impossible seeing how the original normal force held the box in rest.
How did you reach that conclusion?
Quite simple. The question states that the box is at rest. And when the normal force is calculated, it is smaller than the minimum normal force needed to hold the box in rest.
You might want to reread the problem statement:
"b) Determine the magnitude of the smallest force that can be applied onto the top of the box, perpendicular to the ramp, if the box is to remain at rest."​
Nothing in there says that the box would remain at rest if you didn't apply some kind of force.
So what does that tell you?
Whoa, I am a slow thinker. Sorry about that, I should have seen it a long time ago. The needed force would be that larger number I had minus the normal force. That I should have seen. Sorry and thanks for the help!
for a) i see how the applied force would be against the force of gravity acting down the ramp and the force of friction acting against the force of gravity. for part b) i don't quite see how to recalculate the normal force, isn't Fn=mgcos45? i would then get the same results for the normal force unless mass, gravity or angle would change. my thinking is that the because it is the smallest amount needed you set the force of gravity against the box going down the ramp to 0, and end up with Fnet=0. Fnet=Fa-Ff, Fa=Ff. therefore the Fa=119.39
FAQ: Magnitudes of the largest and smallest force?
What is the difference between the largest and smallest force?
The difference between the largest and smallest force, also known as the range of forces, is the magnitude of the strongest force subtracted by the magnitude of the weakest force. This range can vary greatly depending on the specific system or situation being studied.
How are the largest and smallest force determined?
The largest and smallest force are determined through various methods such as calculations, measurements, or simulations. In some cases, the maximum and minimum forces may be directly observed, while in other cases they may need to be calculated using mathematical principles and equations.
Can the largest and smallest force change over time?
Yes, the largest and smallest force can change over time. Forces can vary due to many factors, such as changes in the environment, interactions with other forces, or changes in the system being studied. As a result, the largest and smallest force may fluctuate over time.
How do the largest and smallest force affect a system?
The largest and smallest force can greatly impact a system. The largest force can cause significant changes and movements in the system, while the smallest force can be crucial in maintaining stability and balance. Understanding the magnitudes of these forces is important in predicting and analyzing the behavior of a system.
Are the largest and smallest force always opposite in direction?
No, the largest and smallest force are not always opposite in direction. While the smallest force is typically in the opposite direction of the largest force, this is not always the case. In some systems, the smallest force may be in the same direction as the largest force, or it may act in a different direction altogether.
