Magtnitude and direction of e&m
  • Thread starter Thread starter bodensee9
    Direction E&m
A uniformly charged spherical shell with a hole creates a unique electric field scenario. The discussion revolves around calculating the electric field at the center of the hole, with participants considering the effects of removing a positive charge versus adding a negative charge. It is suggested that the electric field can be treated as that of an infinite plane due to the small size of the hole, leading to a simplified analysis. Participants emphasize the importance of symmetry and the uniformity of the electric field across the sphere. Ultimately, the consensus is that the electric field strength at the hole is half that of the full sphere due to the nature of the field lines.
bodensee9
Hello:
A thin nonconducting uniformly charged spherical shell of radius R has total positive charge of Q. A small circular plus is remoced from the surface. What are the magtnitude and direction of E at the center of the hole?
So this shell has a hole now. Can I just treat this as a warped sheet and do E*dA = Q/2*epsilon? Then I can do E*dA = Q/2*epsilon. And then I will have E = Q/A*2*epsilon =
Q/8*pi*R^2? Somehow this seems wrong to me.
Thanks.
instead of removing a positive charge maybe you should think of it as adding a negative charge.
So if it's a negative charge, then wouldn't the charge there still be E*dA = Q/e, where Q now is the positive charge plus (or in this case minus) the negative charge? But I don't know what the negative charge is, so if it is q, would I still do.
E*dA = Q/e. Since dA = 4*pi*r*2, so E is (1/4*pi*e)(Q -q/r^2)?
Not sure if this is the right answer.
What's a "small circular plus"? And what do you mean by "warped sheet"? I'll think in terms of symmetry and consider the fact that since a small spherical cap is removed, there is nothing to cancel out the electric field due to the spherical cap of equal shape and size on the opposite end of the spherical shell. So just find that and you're done.
Hello:
Thanks, but if I'm not given a r of the small spherical gap, how can I come up with the exact charge? Because wouldn't I be finding the portion towards the total charge of the sphere this small gap contributes? And wouldn't that depend on the area of the small gap?
bodensee9 said:
Hello:
my guess is that youre not given r because it doesn't matter. my guess is that the field there is zero. no that can't be right. the charge there is zero but the field can't be zero.
calculate the field without the missing plug. then calculate the field dues solely to theimaginary negative plug. then add them. the first one is easy.
yes. that's the whole point.
cant you just treat it as an infinite flat plate. then all you need is the charge density.
So this means that I can treat it as an infinite plate? But can you tell me why I can treat it as an infinite plate? THanks.
because you are finding the field precisely on the surface of the shere. from the point of view of an infinitesimal point an infinitesimal distance from the surface the surface is an infinite plane.
I'm assuming that when they say 'small' plug that they mean so small that its curvature can be neglected.
Got it. Thanks.
So I can do E*dA = ro/2epsilon. And here the Area would still be 4*pi*r^2? where r is the r of the sphere?
Thanks.
forget equations for a moment. just picture the flux lines. isn't it obvious that it will be 1/2 the field strength everywhere else on the sphere? that's how it looks to me.
the field lines for th e sphere only go in one direction. the field lines for an infinite plane go in 2 directions. hence 1/2
am I wrong?
Okay I see. So this is because a plate the field lines can go through the front and then outwards from the back? And because E is uniform throughout the sphere and all the field lines go out of the sphere, and so you can just do 1/2 the field strength of the sphere. I guess I got confused between flux and E because for some reason I was thinking that E would be different throughout the sphere and that the greater the area the greater E would be. But that's not correct. Thanks!
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 26 ·
