Mahesh's question via email about a Runge-Kutta scheme
In summary, to apply the Runge-Kutta scheme to this problem, we first write the second order DE as a system of first order DEs by letting $\displaystyle u = y $ and $\displaystyle v = y' $. Then we can use the scheme with step size $\displaystyle h = 0.05 $ to solve for $\displaystyle y\left( 0.2 \right) $, which is equal to $\displaystyle u_2 = 3.28623 $. It's worth noting that a CAS can be used to solve this problem, but it's not necessary.
Prove It
MHB
1,465
24
To apply this Runge-Kutta scheme, we will need to write our second order DE as a system of first order DEs.
Let $\displaystyle u = y $ and $\displaystyle v = y' $, then we have
$\displaystyle \begin{align*} y'' + 4\,v - 7\,u^2 &= 0.2 \\
y'' &= 0.2 - 4\,v + 7\,u^2 \end{align*} $
So our system of first order DEs is:
$\displaystyle \begin{align*} u' &= v , \quad \quad \quad \quad \quad \quad \quad \, u\left( 0 \right) = 3 \\
v' &= 0.2 - 4\,v + 7\,u^2 , \quad v\left( 0 \right) = 0 \end{align*} $
Now we can apply the Runge-Kutta scheme. Note that $\displaystyle f\left( u,v \right) = v $ and $\displaystyle g\left( u,v \right) = 0.2 - 4\,v + 7\,u^2 $, and the step size is $\displaystyle h = 0.05 $.
I have used my CAS to solve this.
Moving along two steps of size $\displaystyle h = 0.05 $ gets us to $\displaystyle t = 0.1 $, and since $\displaystyle u = y $, that means we have $\displaystyle y\left( 0.2 \right) = u_2 = 3.28623 $.
Mathematics news on Phys.org
Hello,
Thank you for sharing your approach to solving this problem using the Runge-Kutta scheme. It's great to see how you were able to break down the second order DE into a system of first order DEs and then apply the scheme to solve for $\displaystyle y\left( 0.2 \right) $.
One thing I would like to add is that the Runge-Kutta scheme is a numerical method for solving differential equations, so it is not necessary to use a CAS to obtain the solution. However, using a CAS can be helpful for checking your work and verifying the accuracy of the solution.
Overall, your explanation was clear and easy to follow. Keep up the good work!
9K
10K
10K
10K
10K
10K
10K
10K
10K
