Make a Brushless DC Motor this way?
In summary, your idea to use a circular magnet field to create a motor seems to work, but there are some problems with it.
hodges
I know the magnetic field makes a circle around a wire with current flowing through it. So I wondered if a motor could be made in the following way. Take a round plastic sleeve with an inner diameter slightly more than the wire. Glue 4 magnets on the sleeve, such that they form a circular magnetic field (for example, the north pole of each magnet could always face to the right when looking down at the vertical sleeve from above). Now run the wire through the sleeve and allow current to flow. It seems to me that there will always be a constant net force on each magnet, resulting in a constant torque to spin the motor.
But some things don't seem right about this. As the motor spins, it appears to me that the magnetic flux experienced by the wire is not changing. Thus, there will be no back EMF generated to limit the speed of the motor. So the motor could reach infinite speed (neglecting friction). For the same reason, the device could not be used as a generator, which seems strange from a symmetry perspective.
What is wrong with my idea? I know from a practical standpoint the current in the wire would have to be high, since there is only a single wire involved vs. the multiple turns in a conventional motor. But in theory, would this device work?
BLDC motors require a sequenced (basically AC) drive current, so I think you have designed a motor that will work with AC current. With DC there will be no change in magnetic field, so nothing to push the magnets after they line up with the first ON-pulse. Coiling the wire to concentrate the magnetic field will make a more efficient use of the current flow. Spinning the magnets will produce an AC current, not DC...
Won't there be a constant force on each of the magnets (force on a magnetic dipole in a magnetic field)?
I believe the field from a DC current in the wire is "polarized" in a fixed direction ...the right-hand twist rule or something like that... The magnets will line up with that direction to remain in balance. If you change the field strength, or better reverse it, then you get the magnets to move.
Your idea of using a circular magnetic field to create a brushless DC motor is interesting, but there are a few issues with this design. Firstly, the magnetic field created by the four magnets will not be uniform, which means that the force on each magnet will not be constant. This could result in unbalanced forces and cause the motor to spin unevenly or not at all.
Additionally, the motor would not have a stable equilibrium point, meaning that once it starts spinning, it will continue to accelerate indefinitely unless some external force is applied to slow it down. This would make it difficult to control the speed of the motor and could lead to safety concerns.
Furthermore, as you mentioned, there would be no back EMF generated in this design, which is essential for controlling the speed of the motor. Without a way to regulate the current flowing through the wire, the motor could overheat and potentially cause damage.
From a theoretical standpoint, it is possible that this design could work, but it would require precise calculations and adjustments to ensure a balanced and controllable motor. In practice, it would be more efficient and reliable to use a conventional design with multiple turns of wire to create a uniform magnetic field and generate a back EMF for speed control.
In conclusion, while your idea is innovative, there are several practical and theoretical limitations that make it unlikely to be a viable solution for creating a brushless DC motor. As a scientist, it is important to continue exploring new ideas and pushing the boundaries of technology, but it is also important to consider the practicality and feasibility of these ideas.
FAQ: Make a Brushless DC Motor this way?
How does a brushless DC motor work?
A brushless DC motor works by using electronic commutation instead of mechanical brushes. This means that the motor's magnets are controlled by an external power source, allowing for more precise control of the motor's speed and direction.
What are the advantages of a brushless DC motor?
There are several advantages to using a brushless DC motor, including higher efficiency, longer lifespan, and lower maintenance requirements. Additionally, brushless DC motors are quieter and more compact than traditional brushed motors.
How do you make a brushless DC motor?
To make a brushless DC motor, you will need a stator (stationary part of the motor), a rotor (rotating part of the motor), and electronic components such as sensors and a controller. The stator is typically made up of coils of wire, while the rotor contains permanent magnets. When the controller sends electrical signals to the stator, it creates a rotating magnetic field that interacts with the magnets on the rotor, causing it to spin.
What are the applications of brushless DC motors?
Brushless DC motors are used in a wide range of applications, including industrial machinery, electric vehicles, robots, and consumer electronics. They are also commonly used in household appliances such as washing machines, refrigerators, and air conditioners.
Can a brushless DC motor be controlled remotely?
Yes, a brushless DC motor can be controlled remotely through the use of a wireless transmitter and receiver. This allows for greater flexibility and convenience in controlling the motor's speed and direction, making it ideal for applications such as remote-controlled vehicles and drones.
