Making a program to interpret equations. Am I going about this wrong?
  • Thread starter Jamin2112
  • Tags
    Program
In summary, the conversation discussed the creation of a program that interprets and evaluates equations. The program would take a statement and return a numerical value, and the creator was currently working on a function to check for valid equations. The use of tools like Lex and Yacc to automatically generate parsers and analyzers was also mentioned, along with suggestions for further reading. The complexity of the C++ language and the use of recursive descent parsers were also discussed.
Jamin2112
986
I'm making a program that interprets and evaluates equations. I won't go into all the specifications, but basically it would take a statement like
~1^(2~&3) 0x3FFE 0x2FCE 0xFCC1
and returns
4926 (0x133E).
As you may have guessed, the 1, 2 and 3 are where the parameters 0x3FFE, 0x2FCE and 0xFCC1 are substituted.
I'm right now working on a function that determines whether the equation is valid in the first place. For instance, there can't be any unbalanced parentheses, any of the numbers cannot exceed the number of parameters, there cannot be any invalid characters like '#', a left-facing paranthesis must always be followed by an operator, etc.
For that function function alone, I've already written 225 lines of code, probably 150 if you exclude comments. It's very tricky. And I'm only iterating through characters of the equation once and I've carefully eliminated redundancies.
Or am I inevitably going about this wrong if I'm having to write so much?
Technology news on Phys.org
Hey Jamin2112.
What kind of data structure have you come up with to evaluate expressions?
If you have not come up with one, probably the simplest data structure to evaluate expressions like these would be a binary tree. You can evaluate an expression recursively at each node depending on the node type.
Examples of node types for standard arithmetic include +,-,*,/, and % (MOD). If you have unary operators then you will need to treat those in special cases.
Start by learning Lex and Yacc (or whateever they are called in your favorite version of Unix).
A parser for the complete grammar of ANSI C is less than 750 lines.
http://www.quut.com/c/ANSI-C-grammar-l.html
http://www.quut.com/c/ANSI-C-grammar-y-2011.html
Of course you also have to write the code that actually "does something", but for a calculator type of application that is trivial. Here's a "make a calculator " tutorial: http://epaperpress.com/lexandyacc/
chiro said:
Hey Jamin2112.
I have not gotten to the evaluation part yet. Should I be doing this in 1 fell swoop? That is, should I attempt to evaluate and check for errors along the way?
The point of using tools like lex and yacc is that you don't have to do the error checking. You just write the grammar for the input language, and the tools do the work. Turning the grammar into an executable program (in C or C++) is a solved computer science problem, and that's what the tools do for you. With luck, you never need to look at the generated code - just compile and run it.
Hand-crafting a lexical parser and input analyzer is mildly interesting to do once in your life (but as you are finding out, it can be tediously long and repetitive), but it's about as useful for real life computing as making a model of the Eiffel tower out of matchsticks and glue.
You can do it as part of the evaluation.
In fact you can use a parser like those mentioned above and use the structural aspects of the parsed sentence tree to evaluate the actual expression. You can decide whether you want to use the binary tree, yacc, or some other method and/or data structure.
That's not true. Find one single parser for C++ that uses lex and yacc. You can't. Lex and yacc cannot parse C++. The language is too complex; it's beyond the scope of a LALR parser such as lex and yacc. The compilers from gcc, clang, Microsoft: They are all hand-written recursive descent parsers.
A recursive descent parser for a BNF such as the following is a standard exercise in many computer language classes.
Code:
<full_expression> ::= <expression> <EOL>
<expression> ::= <term> | <expression> <additive_op> <term>
<term> ::= <factor> | <factor> <multiplicative_op> <term>
<factor> ::= <number> | <lparen> <expression> <rparen>
<number> ::= <digit> | <number> <digit>
<EOL> ::= "\n"
<additive_op > ::= "+" | "-"
<multiplicative_op > ::= "*" | "/"
<digit> ::= "0" | "1" | "2" | "3" | "4" | "5" | "6" | "7" | "8" | "9"
<lparen> ::= "("
<rparen> ::= ")"
Jamin2112, I suggest you see whether your local library has a copy of Programming: Principles and Practice Using C++ (Stroustrup, 2008). I had a look at it recently and feel that inexperienced programmers could benefit greatly from it, due to its emphasis on problem solving, industry-quality practices, and avoidance of toy examples.
I suggest it particularly because a simple calculator application is the first major example in the book. While writing it, he gives a gentle introduction to tokenization and grammars.
Although, as others have said, you're dealing with a solved problem, if you'd like to gain a token understanding of it*, I think that book is worth your time. (I also think it's a valuable book generally.)
* Sorry.
Likes 1 person
++thanks on that suggestion. This book is particularly apropos given that it covers a simple parser of the type that Jamin2112 is trying to learn to write.
Point taken. I should have said "Hand crafting a parser and analyzer for an input language where they can be automatically generated ..."
But if you are designing your own input language (rather than implementing a camel designed by somebody else), why design it so an LALR parser can't handle it? More language complexity or ambiguity = more user misunderstandings and errors, I think.
The reason lex and yacc "cannot" (see below) parse C++ is because the syntax and semantics of C++ are horribly intertwined A well known example is
Code:
int (x);
This is legal but ambiguous, without the context of the rest of the program source code. It could be a declaration of an integer variable x (with a redundant set of parentheses), or an expression statement which casts the value of x to an integer (and probably has no useful purpose, but that is beside the point).
You can make examples with much more complexity than the above by using features like templates.
One way to resolve the ambiguity is to mix up the semantic analysis with the parsing. Another way is to recast the grammar into something that can be parsed be context-free methods like lex and yacc, and create a parse tree that captures the semantic ambiguity so that it can be resolved later on. See section 5 of http://www.computing.surrey.ac.uk/research/dsrg/fog/FogThesis.pdf for more.
* Sorry.
Good suggestions.
I think that I'm going to start by making a function that evaluates expressions limited to integers, multiplication, addition and parentheses. That will give me practice writing elegant recursive algorithms for this type of problem. I'll post my solution here.
I'm a bit confused here. AFAIK the main advantage of recursive descent parsers is that they are easy to hand-craft, because the translation of the grammar into code is so simple it's hard to make mistakes, and easy to debug them just by reading the code.
The other advantage is that for a simple application like a calculator, you can combine the syntax analysis and semantic operations in one pass, and for a simple application you night not need any data structures at all, because the calling tree of the functions at run time is equivalent to the parse tree.
But apart from the ability to mix up syntax and semantic operations in an arbitrary way, I wasn't away that recursive descent was a more powerful parsing algorithm than LALR. In fact I thought it was less powerful. unless you put something sneaky in your example grammar that I missed, that example is simple to parse in lex and yacc.
Alright, guys. I mentioned in my last reply that I'm making a simple equation interpreter that does addition and multiplication, with parentheses allowed and with addition having a higher precedence than multiplication.
So far I've made a function that checks whether the equation is valid. It's passed every test that I've given it. The code is below and I'd like you to scrutinize it and give me input, even if condescendingly. I'm trying to avoid repeated logic but at the same time be somewhat elegant.
Code:
#include <iostream>
#include <string>
bool valid_equation(const std::string&);
int str2Int(const std::string&);
bool isdigit(char);
int main (int argc, char* const argv[]) {
	std::cout << valid_equation("4*(3+4)");
    return 0;
bool valid_equation(const std::string& eq) {
	std::string::const_iterator it = eq.begin();
	// Equation cannot be an empty string:
	if (it == eq.end())
		return false;
	// Count for the number of right-facing and left-facing parantheses:
	int RFPcnt(0), LFPcnt(0);
	/* Iterate through the characters of the equation to check that it is valid based on
	   which characters are lined up next to which. For example, if two plus signs are found
	   next to each other, that makes the equation meaningless and the our function
	   valid_equation immediately returns false;
	while (it != eq.end()) {
		if (*it == '(') {
			   Rules for a right-facing paranthesis:
			   (1) Must be followed by a digit or another right-facing paranthesis
			   (2) Must be preceded by an operator or another right-facing paranthesis or nothing at all
			if ((it + 1) == eq.end()) {
				return false;
			} else {
				if (!isdigit(*(it + 1)) && *(it + 1) != '(')
					return false;
			if (it != eq.begin()) {
				if (*(it - 1) != '*' && *(it - 1) != '+' && *(it - 1) != '(')
					return false;
			++it; // If we made it here, increment the iterator
			++RFPcnt; // Increment the count of right-facing paranthesis as well
		} else if (*it == ')') {
			   Rules for a left-facing paranthesis:
			   (1) Cannot be the beginning of an equation
			   (2) Must be preceded by a digit or another left-facing paranthesis
			   (3) Must be followed by an operator or another left-facing paranthesis or nothing at all
			if (it == eq.begin()) {
				return false;
			} else {
				if (!isdigit(*(it - 1)) && *(it - 1) != ')')
					return false;
			if ((it + 1) != eq.end()) {
				if (*(it + 1) != '*' && *(it + 1) != '+' && *(it + 1) != ')')
					return false;
			++LFPcnt; // Increment the count of left-facing paranthesis as well
		} else if (*it == '*' || *it == '+') {
			   Rules for an operator:
			   (1) Cannot be the beginning or end of an equation
			   (2) Must be preceded by a digit or a left-facing paranthesis
			   (3) Must be followed by a digit or a right-facing paranthesis
			if (it == eq.begin() || (it + 1) == eq.end()) {
				return false;
			} else {
					return false;
					return false;
			++it;
		} else if (isdigit(*it)) {
			// Simply increment the iterator until it's no longer on a digit:
			while (isdigit(*++it));
		} else { // If we're here, *it is invalid character
			return false;
	if (RFPcnt != LFPcnt)  // Unbalanced paranthesis?
		return false;
	return true; // If we made it here, the equation is valid; return true
int str2Int(const std::string& str) {
    std::string::const_iterator it = str.begin();
	if (it == str.end()) {
		std::cout << "Invalid parameter: str2Int() only accepts non-empty strings." << std::endl;
		return -1;
    int sum = 0;
    while (it != str.end()) {
		if (!isdigit(*it)) {
			std::cout << "Invalid paramter: str2Int only accepts strings of chars '0' through '9'" << std::endl;
			return -1;
		} else {
			sum *= 10;
			sum += *it++ - '0';
    return sum;
bool isdigit(char c) {
	return (c >= '0' && c <= '9');
I think you should do this in several steps. First you tokenize the input. i.e.
You turn this
into a list of tokens like so
~, 1, ^, (, 2, ~, &, 3, ), 0x3FFE, 0x2FCE, 0xFCC1
For that you could also use regular expressions.
Then you can turn that into a tree, or alternatively into rpn (also know as postfix) notation.
That can then be interpreted very easily.
Of course it would be a lot easier to write this, if your program get's the expression in rpn form.
My mini addition and multiplication calculator needs a little debugging, but I'm almost there.
Code:
std::string evaluate_equation(std::string eq) {
	/* By the order of operations:
	   (1) Evaluate the expression in the innermost set of paranthesis, if there is one;
	   (2) Evaluate multiplication expressions left-to-right;
	   (3) Evaluate addition expressions left-to-right.
	   Use recursion.
	// (1):
	size_t FRFP = eq.find_last_of('('); // position of first right-facing paranthesis
	if (FRFP != std::string::npos) {
		// Set NLFP to be the position of the next left-facing paranthesis after the FRFPL
		size_t NLFP = FRFP;
		while (eq[++NLFP] != ')');
		/* Replace the space between FRFP and NLFP inclusive with the evalulation of the expression
		   between FRFP and NLFP exclusive:
		std::string paranstr = eq.substr(FRFP + 1, NLFP - 1);
		eq.replace(FRFP, NLFP - FRFP + 1, evaluate_equation(paranstr));
		evaluate_equation(eq);
	// (2):
	size_t firstast = eq.find_first_of('*'); // position of first asterisk
	if (firstast != std::string::npos) {
		// Set num1 and num2 equal to the respective numbers to the left and right of the asterisk:
		std::string num1, num2;
		size_t num1begin(firstast), num2end(firstast);
		while (--num1begin >= 0 && isdigit(eq[num1begin]))
			num1.insert(0, 1, eq[num1begin]);
		while (++num2end < eq.size() && isdigit(eq[num2end]))
			num2.push_back(eq[num2end]);
		// Replace the space of the multiplication equation num1*num2 with its evaluation:
		eq.replace(num1begin + 1, num2end - num1begin + 1, multStrs(num1, num2));
	// (3):
	size_t firstplus = eq.find_first_of('+');
	if (firstplus != std::string::npos) {
		size_t num1begin(firstplus), num2end(firstplus);
		eq.replace(num1begin + 1, num2end - num1begin + 1, addStrs(num1, num2));
	// If we made it to this point, all that's left of the equation is a single number. Return it;
	return eq;
From the console:
Code:
3*(6+1)
5+6*7+8
47
(((6)))
((6))))
Yea, those last two didn't come out right. Still got work to do!
You need to find the outermost pair of parantheses, not the innermost one.
btw. here is an expression evaluator I wrote in Java a while ago.
http://pastebin.com/4y5ELtng
You can use recursion by first evaluating the innermost parentheses and then replacing the space taken up by that parenthetical expression with its evaluation, and then reevaluating the entire expression, etc. That way is good because you can easily add a feature that prints out the steps of the evaluation. I got my program to work. I'm still going to check out yours, though. Mine is a very crude implementation.
Code:
#include <iostream>
#include <string>
std::string evaluate_equation(std::string);
std::string int2Str(unsigned int);
bool isdigit(char);
std::string addStrs(const std::string&, const std::string&);
std::string multStrs(const std::string&, const std::string&);
	// Evaluate expressions at the console
	std::string eqtn;
	while (std::cin >> eqtn) {
		if (!valid_equation(eqtn)) {
			std::cout << "Equation invalid; not evaluated" << std::endl;
		} else {
			std::cout << evaluate_equation(eqtn) << std::endl;
    return 0;
	   Use recursion.
	// (1):
	size_t LRFP = eq.find_last_of('('); // position of last right-facing paranthesis
	if (LRFP != std::string::npos) {
		size_t NLFP = LRFP;
		std::string paranstr = eq.substr(LRFP + 1, NLFP - LRFP - 1);
		eq.replace(LRFP, NLFP - LRFP + 1, evaluate_equation(paranstr));
		return evaluate_equation(eq);
	// (2):
		while (num1begin > 0 && isdigit(eq[num1begin - 1]))
			num1.insert(0, 1, eq[--num1begin]);
		int eqsz = eq.size();
		while ((num2end + 1) < eqsz && isdigit(eq[num2end + 1]))
			num2.push_back(eq[++num2end]);
		eq.replace(num1begin, num2end - num1begin + 1, multStrs(num1, num2));
	// (3):
		eq.replace(num1begin, num2end - num1begin + 1, addStrs(num1, num2));
	return eq;
	if (it == eq.end())
		return false;
	   valid_equation() immediately returns false.
		if (*it == '(') {
				return false;
			} else {
					return false;
					return false;
				return false;
			} else {
					return false;
					return false;
				return false;
			} else {
					return false;
					return false;
			++it;
			return false;
		return false;
// Given a decimal representation as a string s, str2Int(s) returns the corresponding decimal as an int
		return -1;
    int sum = 0;
			return -1;
		} else {
			sum *= 10;
			sum += *it++ - '0';
    return sum;
// Given an int n, int2Str(n) return the string representation
std::string int2Str(unsigned int n) {
	std::string retstring;
	if (n == 0) {
		retstring.push_back('0');
		return retstring;
	} else {
		while (n != 0) {
			retstring.insert(0, 1, char('0' + n % 10));
			n /= 10;
		return retstring;
// Function that checks whether a given character is in one of '0', '1', ..., '9'
// Adds 2 string decimal representations and returns the sum as a string decimal representation
std::string addStrs(const std::string& s1, const std::string& s2) {
	return (int2Str(str2Int(s1) + str2Int(s2)));
// Multiplies 2 string decimal representations and returns the sum as a string decimal representation
std::string multStrs(const std::string& s1, const std::string& s2) {
	return (int2Str(str2Int(s1) * str2Int(s2)));
FAQ: Making a program to interpret equations. Am I going about this wrong?
1. How do I approach making a program to interpret equations?
The first step is to clearly define the goal of your program and what types of equations it will be able to interpret. Next, break down the problem into smaller, manageable tasks and determine what data structures and algorithms will be needed to accomplish each task. Finally, write and test your code, making adjustments as needed.
2. Do I need any specific programming language or software to create this program?
The programming language or software needed will depend on your specific goals and preferences. Popular options for creating programs to interpret equations include Python, Java, and MATLAB. Research and compare different languages to determine which one best fits your needs.
3. Are there any resources or libraries available to assist with creating this type of program?
Yes, there are various resources and libraries that can assist with creating programs to interpret equations. These may include libraries for specific programming languages, mathematical equations and algorithms, and visualization tools. It is important to research and choose reputable and reliable resources.
4. How can I ensure that my program accurately interprets equations?
Thorough testing is essential to ensure that your program accurately interprets equations. This may include testing with various types of equations and inputs, as well as comparing the results to those obtained manually or with other programs. It may also be helpful to have others review and test your program for accuracy.
5. Is it necessary to have a strong understanding of mathematics to create this type of program?
While a strong understanding of mathematics may be beneficial, it is not necessarily required to create a program to interpret equations. However, it is important to have a basic understanding of mathematical concepts and equations in order to accurately interpret and process them in your program.
