Making Eulers eqs. comply with Lagrange eqs.
In summary, the Lagrangian must be expressed in terms of generalized coordinates and generalized velocities, in order for Lagrange equations to hold. However, when you try to do this, you get the linearized version of Eulers' equations, which is the same as Eulers' equations in their standard version. This is due to a condition that must be met for Lagrange equations to be valid--the Lagrangian must be in terms of the angular velocities around the zero point.
MechatronO
30
Lately when doing a simulation for a quadrocopters most reports I've come across regarding modeling use Eulers equation of motion. That makes sense, as the quadrocopter is a body rotating in 3 dimensions.
Then I tried to model the system using Lagrange equations instead but I don't get the same result. I wrote the Lagrangian as
L = T-U = T = 0.5*(Ixωx2 +Iyωy2+Izωz2 )
But applying Lagrange equations to L doesn't give Eulers equation of motions. Actually though, it gives the linearized version of Eulers, when linearized around the angular velocities zero.
Why is this? I must have missed some crucial condition that must be fulfiled for Lagrange equations to hold true? Did I get the expression for the lagrangian L wrong? Is it because Eulers model a continuous mass distribution, while Newton/Lagrange rather deal with a system of masses? I assumed the lagrangian to be in the rotating frame, as are Eulers equations in their standard version.
The Lagrangian L must be expressed in terms of generalized coordinates and generalized velocities. This is only I can answer on such a level of detailing
But we have three general forces that are the respective input torques for each axis, and three general coordinates that are the euler angles, right?
it is hard to find your mistake without formulas
You must set up your Lagrangian in terms of generalized coordinates and the corresponding generalized velocities, i.e., you always work in a holonomous basis on the tangent space of your manifold, but the Cartesian coordinates of the momentaneous angular velocity in the body-fixed system of reference, as used in Euler's equations, are not such holonomous coordinates.
For the rigid-body description you can use Euler angles in the Lagrangian formalism.
vanhees71: Hmm. Is there some way of seeing this algebraically?
You can evaluate the Cartesian components in terms of Euler angles. I can point only to my German mechanics manuscript, but it's in any textbook on analytical mechanics treating the spinning top:
It starts here (unprimed coordinates refer to the inertial space-fixed and primed ones to the non-inertial/rotating body-fixed reference frame)
http://theory.gsi.de/~vanhees/faq/mech/node74.html
The relations between Euler angles and Cartesian coordinates of the angular velocity is given at
http://theory.gsi.de/~vanhees/faq/mech/node78.html
The Euler angles are depicted here (note that the meaning of the angles in different textbooks differ!):
http://theory.gsi.de/~vanhees/faq/mech/node22.html
I follow the convention in
A. Sommerfeld, Lectures on Theoretical Physics, vol. 1 (Mechanics)
which has a very good treatment of the top (which is no surprise, because Sommerfeld wrote a comprehensive mathematical treatment of the spinning top together with Felix Klein).
there is a simple way to obtain formulas for angular velocity in terms of Euler angles. This way is based upon the addition theorem for angular velocities (without calculating of the matrices
Hmm. Food for thoughts.
I should try to understand the issue of rotation in a rotating coordinate system first. Because, if the coordinate system is rotating exactly the same as some solid object, the rotation of the object in this coordinate system must be zero. But, it seems like rotation like this is defined such that the object is making an infinitely small rotation before the coordinate system follows? So that the rotation of the coordinate system is always lagging behind an infinitely small angle? I can't see how this could happen otherwise. Am I on the right track?
Related to Making Eulers eqs. comply with Lagrange eqs.
What is the difference between Euler's equations and Lagrange equations?
Euler's equations are used to describe the motion of a rigid body in three-dimensional space, while Lagrange equations are used to describe the motion of a particle or system of particles in any number of dimensions.
Why is it important to make Euler's equations comply with Lagrange equations?
Making Euler's equations comply with Lagrange equations allows for a more comprehensive and accurate description of the motion of a system. It also allows for easier comparison and analysis of different systems.
What are the steps involved in making Euler's equations comply with Lagrange equations?
The first step is to derive the Lagrange equations from the Euler-Lagrange equations. Then, the Euler equations are modified to match the form of the Lagrange equations. Finally, any additional constraints or boundary conditions are applied to ensure the equations comply with the system being studied.
Are there any limitations to making Euler's equations comply with Lagrange equations?
One limitation is that this process may not be applicable to all systems, as some systems may not have a Lagrangian or may require different mathematical approaches. Additionally, this process may become more complex for higher dimensional systems.
How can making Euler's equations comply with Lagrange equations benefit scientific research?
By making Euler's equations comply with Lagrange equations, researchers can accurately model and predict the motion of complex systems, leading to a better understanding of physical phenomena and potential applications in various fields such as engineering, physics, and robotics.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
