Kyelek
- 1
The problem is this. We have a structure (see the attached image) and need to make freebodies of all of the members. 150 lbs are applied to the platform being lowered by the strings. We also need to figure internal stresses, but I think I can get those if I can understand this first.
I picked one of the legs, and I idealized it into an elevation. Since each of the legs is equal in all ways, I divided the force applied by three, so 50lbs on the lowered platform.
Using the properties of similar triangles, and knowing that the string has to resist 50lbs of downward force, I found that 96.18lbs of force is acting in tension on the string.
This force is transferred to the tower at a 90 degree angle. I placed a pin at the bottom and a pin at the top. Using the sum of the moments, I found that 35.43 lbs of force were being exherted perpendicular to the top of the tower, and 60.74 to the bottom of the tower.
I started with the beam at the top of the tower. Again using similar triangles, I found that the forces acting on the end were 30.26lbs going into the beam in the x direction, and 18.42lbs going down. So the forces being applied where the three beams meet (from this beam) is the same, but opposite directions.
I think I'm wrong there, but I'm not sure how.
I also tried to figure it going to the base. Using the figures that I had from the tower, it's exherting 31.57lbs of pressure onto the base. That has to be wrong, as each tower needs to support 50 lbs.
So...I'm really not sure where I'm going wrong. I tried to figure everything more holistically, but I still don't see how the forces are moving, and how the 50lbs are getting to the points of connection. Thanks in advance for your help!
