Making up a question for Hooke's Law based on Calcullus
In summary: F = -...force? Doesn't the F = ma force mean that it is the force required for it to travel in the direction of displacement but the F = -ks force is the restoring force. And so since they're in opposite directions, for them to equal each other, shouldn't one of them be multiplied by negative?The force required for the object to travel in the direction of displacement is F = ma, while the restoring force is F = -ks. Since they are in opposite directions, one of the forces must be multiplied by a negative value.
bankedroads
I'm not sure if this should be in this thread of the calculus one as it involves a bit of both. Basically I have to to make a question up that applies Hooke's Law. The only other condition is that k (the spring constant) must be equal to 20N/m. It should involve integration or differentiation.
F = -ks
F = ma
a = -Rw2sinwt
My current idea is to use to use the simple harmonic equations associated with an oscillating spring. I plan on giving out the acceleration and some conditions so that the person solving the problem has to integrate it twice to get s = blah (where s equals displacement). I will also give out the force so that then they can calculate k, which will end up being 20. Does anyone think this will work or if it's too easy? (the question should be suited for an advanced maths class but not overly difficult)
The main issue I'm having is if it's applying Hooke's law. Does anyone else have any other ideas about how to come up with a challenging question using this very simple law (perhaps using period or that equation for a mass attached to the end of the string with the square root sign)? A teacher was telling me about using acceleration in the F = ma equation and using that to differentiate but i was a ltitle confused by it.
Also, what does w mean? I understand it is angular velocity but I'm not quite sure what that means in relation to an oscillating spring.
Thanks for your time!
Think of it as angular frequency rather than angular velocity. In circular motion, the angular frequency is the number of radians per second, omega = 2 * pi * f
In the context of SHM, you still have omega = 2 * pi * f
Omega is a useful tool in your equations as it stops you writing 2*pi all over the place.
Sounds okay to me. Of course you will have to specify some initial conditions in order to allow them to determine the value of the arbitrary constants.
As you correctly say ω is the magnitude of the angular velocity (called the angular frequency), which is defined as 2∏f, where f is the frequency of oscillation.
Thanks guys!
So can I just assign a random value for w? or would I need to give some reasoning for it? so say acceleration = -100sin10t, does that mean w = 10? Should i try to include the period but get the person to work out w for themselves? Is it of a high enough standard do you think? I'm just really worried it doesn't apply Hooke's law...
Also, one of my teachers was telling me that if:
s = 3sin2t and you differentiated till you got
a = -12sin2t, you could make an equation
F = ma, F = -ks
thus, ma = -ks (assume mass is 10kg)
10*-12sin2t = -k x 3sin2t
10 * 4 = k
therefore k = 40
does that work/make sense? Is it a better way of using Hooke's law than the previous method (is it harder?)? Can you make the F = ma force equal the F = -ks force? Doesn't the F = ma force mean that it is the force required for it to travel in the direction of displacement but the F = -ks force is the restoring force. And so since they're in opposite directions, for them to equal each other, shouldn't one of them be multiplied by negative?
sorry for askig so many questions!
F = ma, F = -ks
10 * 4 = k
therefore k = 40
This method looks okay to me.
Hooke's law is Hooke's law, there is no better way of using it, one simply uses it. Difficulty is virtually impossible to quantify, particularly from an applied mathematics/physics point of view. Often, the difficulty lies not in the actual solution, but in the wording of a question. There are infinite possibilities with a question such as this, the wording would also depend if you would like to focus more on the mathematics (i.e. solving ODE's) or the physics (i.e. interpreting) of the problem.
What age group are the students at which this question is to be pitched? Advanced Mathematics can mean a variety of courses.
Yes
No. Newton's second law simply states that the vector sum of the forces is proportional to the acceleration, there is no requirement that the force be in the same direction as motion, if there was then one wouldn't be able to apply Newton's second law to any problems that have a restoring force (such as this).
No need to apologise, that's what we're all here for :smile:
Related to Making up a question for Hooke's Law based on Calcullus
1. What is Hooke's Law and how is it related to calculus?
Hooke's Law is a physical law that describes the relationship between the force applied to an object and its resulting deformation. This relationship is linear and can be expressed mathematically using calculus.
2. How does calculus play a role in understanding Hooke's Law?
Calculus is used to analyze the relationship between force and deformation in Hooke's Law by calculating the slope of the linear function. This allows us to determine the stiffness of the object and predict its behavior under different forces.
3. Can you give an example of how Hooke's Law can be applied using calculus?
Yes, imagine a spring with a known spring constant. Using calculus, we can determine the force required to deform the spring by a certain distance, or the distance the spring will deform when a certain force is applied.
4. Are there any limitations or assumptions to using calculus in Hooke's Law?
Yes, Hooke's Law assumes that the material being analyzed is linearly elastic and obeys the law perfectly. In reality, there may be other factors at play that can affect the relationship between force and deformation.
5. How does understanding Hooke's Law using calculus benefit scientific research and engineering?
Understanding Hooke's Law using calculus allows scientists and engineers to make accurate predictions about the behavior of materials under different forces. This can inform the design and development of various structures and devices, making them more efficient and effective.
