Making use of completion relation to find general expectation
In summary, the question asks us to show that if the complex conjugate of the operator <Ω> is equal to its negative, then the expectation value of <Ω> is equal to zero for any real function f. Using the completeness relation and the fact that f is real, we can prove this statement.
ChemicalTom
I am stuck on this Self-test 1.6 in molecular quantum mechanics by atkins and friedman.
Probably making use of the completeness relation the question is the following: Show that if <Ωf>*=-Ωf*, then <Ω>=0 for any real function f.
Anyone got a clue?
A:Let's see what we can do.Using the completeness relation, we can write$$\langle \Omega \rangle = \int_{-\infty}^{\infty}\Omega(x)f(x) dx = \int_{-\infty}^{\infty}\Omega^*(x)f(x) dx = \langle \Omega^* \rangle$$Since $\langle \Omega f \rangle = -\langle \Omega^* f \rangle$ and $f$ is real, we have$$\langle \Omega \rangle = \langle \Omega^* \rangle = -\langle \Omega^* \rangle = -\langle \Omega \rangle \implies \langle \Omega \rangle = 0$$
Related to Making use of completion relation to find general expectation
What is a completion relation?
A completion relation is a mathematical concept used to extend a given set or structure to a larger set or structure that contains all possible elements or properties. It is often used in the study of algebra, logic, and computer science.
How is a completion relation used to find general expectation?
A completion relation can be used to find general expectation by first defining the completion relation on a given set or structure, then using it to extend the set or structure to a larger one. This larger set or structure can then be used to determine the general expectation of a given property or behavior.
What are the benefits of using a completion relation to find general expectation?
Using a completion relation to find general expectation allows for a more comprehensive and systematic approach to understanding a given set or structure. It also allows for the identification of patterns and relationships that may not be immediately apparent.
Are there any limitations to using a completion relation to find general expectation?
Yes, there can be limitations to using a completion relation to find general expectation. One potential limitation is that the completion relation may not be defined or applicable for all sets or structures. In addition, the general expectation determined through a completion relation may not always accurately reflect real-world scenarios.
In what fields or applications is the use of completion relation to find general expectation most common?
The use of completion relation to find general expectation is most common in mathematics, logic, and computer science. It is also frequently used in the study of probability and statistics, as well as in various engineering and scientific fields.
  • Quantum Physics
  • Quantum Interpretations and Foundations
