- #1
brotherbobby
- 696
- 163
- Homework Statement
- A man stands on a steep shore of a lake and pulls a boat in the water by a rope which he takes up at a constant speed of ##v##. What will the speed of the boat be at the moment when the angle between the rope and the surface of the water is ##\alpha##?
- Relevant Equations
- 1. The horizontal component of a vector ##\vec A## making an angle ##\theta## with the positive direction of the ##x## axis is ##A_H=A\cos\theta##
2. Instantaneous velocity ##v = \dfrac{dx}{dt}##
3. In a right-angled triangle, ##\cos\theta=\dfrac{\text{Adjacent}}{\text{Hypotenuse}}##
Method 1 : I draw an image of the problem situation to the right.
Boat B moves to the right pulled by a rope from the point O where the man is located. The angle the boat makes with the horizontal ##\alpha## changes with time.
From the principle of horizontal and vertical components of a vector, the speed of the boat ##\quad\boxed{u=v\cos\alpha}\quad (1) \quad{\huge{\color{red}\times}}##
This method was my first reaction to the problem. Turns out, the answer is incorrect.
Method 2 : I consider infinitesimal increments of the boat and the rope. The diagram is to the right where I represent the boat B as a point (##\color{brown}{\bullet}##) to save space.
The boat B moves from B to B', a distance of ##dx## in a time ##dt##. B'P is perpendicular to BO.
In ##\triangle BB'P, BP=dx\cos\alpha##. This is the distance moved by the rope, in a time ##dt##. We note that PO = B'O.
Hence, the velocity of the rope ##v=\dfrac{BP}{dt}=\dfrac{dx\cos\alpha}{dt}=u\cos\alpha##, where ##u=\dfrac{dx}{dt}## is the velocity of the boat.
Hence, the velocity of the boat, ##u=\dfrac{v}{\cos\alpha}\Rightarrow\boxed{u=v\sec\alpha}\quad{\huge{\color{DarkGreen}\checkmark}}\quad (2)##
This answer agrees with the text.
Doubt(s) : I have two of those, for the moment.
(1) What is wrong with method 1, given it seems intuitive enough?
(2) If indeed ##u=v\sec\alpha##, then, as ##\alpha## is increasing with time, so is ##u##, as ##\sec\alpha## is an increasing function in the first quadrant. This can be shown as ##\alpha\uparrow\;\rightarrow\; u\uparrow##.
Isn't that counter-intuitive? I would imagine that the steeper the rope got (increasing ##\alpha##), the slower the boat should move horizontally along the water surface, not faster.
