Manchester Encoding Matched Filter
  • Thread starter Meteora
  • Tags
    Filter
In summary: Therefore, the impulse response of our matched filter is a square wave with amplitude A/2 and length T, starting at t = 0 and repeating every T seconds. To plot the matched filter output as a function of time, we can convolve the input signal (Manchester code) with the impulse response we just found. This will result in a new signal that we can plot as a function of time. Finally, to determine the peak value of the output, we can simply look at the maximum amplitude of our new signal after convolving with the impulse response. This will give us the peak value of the output. In summary, to determine the impulse response of a filter matched to a Manchester code, we use the definition of
Meteora
Consider one bit time of Manchester code of duration T where a positive pulse of amplitude A/2 and length T/2 is followed by a negative pulse of amplitude –A/2 and length T/2.
a) Determine the impulse response of a filter matched to this signal and sketch it as a function of time.
b) Plot the matched filter output as a function of time.
c) What is the peak value of the output?
Matched filter is filter with equation g(T-t) where g(t) is the input to the filter as far as I know for the Non return to zero case.
I know I have to use Schwarz's Inequality and somehow get to the mathced filter representation but I can't figure out how since I only know how to do it with NonReturntoZero encoding.
Hello,
Thank you for your post. To determine the impulse response of a filter matched to this signal, we can use the definition of a matched filter as a filter with a response that is the time-reversed and conjugate of the transmitted signal. In this case, our transmitted signal is a Manchester code with a positive pulse of amplitude A/2 and length T/2 followed by a negative pulse of amplitude -A/2 and length T/2.
So, the impulse response of our matched filter can be represented as g(T-t) where g(t) is the input to the filter. In this case, our input is the Manchester code, so g(t) can be written as:
g(t) = (A/2)u(t) - (A/2)u(t-T/2) - (A/2)u(t-T) + (A/2)u(t-3T/2)
where u(t) is the unit step function.
Using Schwarz's Inequality, we can simplify this expression to:
= (A/2)[u(t) - u(t-T/2) - u(t-T) + u(t-3T/2)]
Now, to sketch the impulse response as a function of time, we can plot the above expression for different values of t. For t < 0, the unit step functions will be equal to 0, so g(t) = 0. For 0 < t < T/2, u(t) = 1 and the other unit step functions are equal to 0, so g(t) = A/2. For T/2 < t < T, u(t-T/2) = 1 and the other unit step functions are equal to 0, so g(t) = 0. For T < t < 3T/2, u(t-T) = 1 and the other unit step functions are equal to 0, so g(t) = -A/2. For 3T/2 < t, u(t-3T/2) = 1 and the other unit step functions are equal to 0, so g(t) = 0.
FAQ: Manchester Encoding Matched Filter
What is "Manchester Encoding Matched Filter"?
Manchester Encoding Matched Filter is a technique used in digital communication to decode a Manchester encoded signal. It involves using a specific type of filter, called a matched filter, to recover the original signal from a Manchester encoded one.
How does Manchester Encoding Matched Filter work?
The Manchester Encoding Matched Filter works by using a filter that is matched to the shape of the Manchester encoded signal. This filter is designed to maximize the signal-to-noise ratio and recover the original signal from the encoded one.
What are the advantages of using Manchester Encoding Matched Filter?
There are several advantages of using Manchester Encoding Matched Filter. Firstly, it allows for reliable and accurate decoding of Manchester encoded signals. Additionally, it is less susceptible to noise and interference compared to other decoding techniques. It also has a simple and efficient implementation, making it a popular choice in digital communication systems.
What are the applications of Manchester Encoding Matched Filter?
Manchester Encoding Matched Filter has a wide range of applications in digital communication systems, such as Ethernet, RFID, and digital radio. It is also commonly used in data transmission over long distances, as it can help maintain the integrity of the transmitted data.
What are the limitations of Manchester Encoding Matched Filter?
One limitation of Manchester Encoding Matched Filter is that it requires precise synchronization between the transmitter and receiver. This means that any variations in the clock speed can lead to errors in the decoded signal. It also has a limited data transmission rate compared to other encoding techniques.
10K
