pivoxa15
- 2,255
- 1
It is accepted that in exothermic chemical reactions which is essentially a reconfiguration of electrons into a more stable form, photons are emitted. When a molar sample is experimented, we can most easily observe these photons as heat (since not all emit photons in the visible wave length).
If you think about the heat mechanism like convection, conduction. The atoms interact with each other via the collision of the outer shell electrons. When they are exicted the electrons move into a higher level orbit and when they go down again, photon is emitted. So in this way, heat transferred via conduction and conduction is also due to the photon. There is also heat transfer via radiation which obviously is a more direct way of using photons to heat objects.
In nuclear reactions the force carrier are predominantly gluons. However, in nuclear reactors used for energy generation, they claim the energy they derive from nuclear reaction is mainly heat which then goes to heat water and the mechanical energy of the water in the form of steam is able to all sorts of useful work. In this way the manifestation of gluons is heat again.
So the manifestation of photon and gluon is heat. Correct?
What about W and Z bosons? How about the graviton if they exist?
http://en.wikipedia.org/wiki/Messenger_particle
