Manipulation of negative square root of a negative term/#
In summary, when solving for y in the equation x\leq 1, (x-1)^2 = y, it is important to consider the domain and range of the function. Since (x-1)^2 will always be 0 or negative when x\leq 1, we must take the negative square root of (x-1)^2 to get y. However, it is not correct to simply multiply both sides by -1 and take the square root of y, as this can lead to incorrect solutions. Instead, we should square both sides and solve for x, which will automatically satisfy the given conditions.
hatelove
101
Suppose I have to solve for y:
[tex]x\leq 1[/tex]
[tex](x - 1)^{2} = y[/tex]
So I know that (x - 1) will always be 0 or a negative, therefore I must take the negative square root of (x - 1):
[tex]-\sqrt{(x - 1)^{2}} = -\sqrt{y}[/tex]
Am I to understand that this is the same as:
[tex]-1 \cdot \sqrt{(x - 1)^{2}} = -1 \cdot \sqrt{y}[/tex]
[tex]=[/tex]
[tex]-1 \cdot (x - 1) = -1 \cdot \sqrt{y}[/tex]
[tex]=[/tex]
[tex]-x + 1 = -1 \cdot \sqrt{y}[/tex]
Or how does this work?
Mathematics news on Phys.org
[tex]x\leq 1[/tex]
[tex]=[/tex]
[tex]=[/tex]
Do you have another example? The equation you've given already has y as the subject.
For the equation $y = (x-1)^2$ where $x \leq 1$ you can deduce that $y \geq 0$ (in other words the range of the function is $f(x) \geq 0$)
As you said you must take the negative root of $x$ but not of $y$ because $y$ is always non-negative so we take the positive square root. In essence I'm not sure what you want to do with the equation? Do you want to solve for x (and basically find the inverse function)? If you do then remember the domain and range are swapped.
One of the easier things to do is consider and ordered pair.
$f(x) = (x-1)^2$
$f(0) = (0-1)^2 = 1$
So (0,1) is an ordered pair. If we try this in your final equation (which you've done correctly bar taking the negative root of y): $-0+1 = -1 \cdot \sqrt{1} \rightarrow 1 \neq -1$ so that equation doesn't hold.
If you took the positive root of y (ending up with $-x+1 = \sqrt{y} \rightarrow -0+1 = \sqrt{1} $ which works. Try it for another ordered pair (but remember that $y \geq 0$)
[tex]x\leq 1[/tex]
[tex]=[/tex]
This is an error [tex]\sqrt{(x-1)^2}= |x- 1|[/tex] not x- 1. Here, since x-1< 0, |x- 1|= -(x- 1) so what you should have is
[tex]-1(-(x-1))= x-1= -\sqrt{y}[/tex]
[tex]=[/tex]
This can't be right because if x< 1, -x+ 1> 0 and [tex]-\sqrt{y}[/tex] is positive.
Again, [tex]\sqrt{x^2}= |x|[/tex].
[tex]x\leq 1[/tex]
This is already "solved for y". Did you mean "solve for x"?
What?? You have squared one side and taken the square root of the other side! From [tex]\sqrt{4}= 2[/tex] it does NOT follow that [tex]4= \sqrt{2}[/tex]
What you need to do, to solve for x, is square both sides: [tex]x- 1= y^2[/tex] and form that [tex]x= 1+ y^2[/tex]. It follows automatically that x is less than of equal to 1 because, with [tex]x\le 1[/tex], [tex]x- 1\le 0[/tex] so y is an imaginary number, or 0, and [tex]y^2[/tex] is less than or equal to 0.
the rest of this is relevant.
[tex]=[/tex]
[tex]=[/tex]
I would like to clarify that the manipulation of negative square roots of negative terms is not a valid mathematical operation. The square root function is only defined for non-negative numbers, so taking the square root of a negative number results in an imaginary number. In the given scenario, if x is less than or equal to 1, then (x-1) is also less than or equal to 0, which means that the square root of (x-1)^2 would result in an imaginary number. This is not a valid solution for y.
Furthermore, the steps taken in the given scenario are not mathematically accurate. Multiplying both sides by -1 does not change the value of the equation. The correct way to solve for y in this scenario would be to first rewrite the equation as (x-1)^2 = y, and then take the square root of both sides, resulting in the solution y = ±√(x-1)^2. This means that there are two possible solutions for y, one with a positive square root and one with a negative square root. However, both solutions are not valid if x is less than or equal to 1, as they would result in imaginary numbers.
In summary, the manipulation of negative square roots of negative terms is not a valid mathematical operation and the steps taken in the given scenario are not accurate. It is important to follow proper mathematical principles and definitions when solving equations.
FAQ: Manipulation of negative square root of a negative term/#
What is the negative square root of a negative number?
The negative square root of a negative number is an imaginary number, represented by the letter i. It is the square root of the positive version of the number, but with a negative sign in front. For example, the square root of -9 is 3i, because 3i squared is equal to -9.
Can the negative square root of a negative number be simplified?
No, the negative square root of a negative number cannot be simplified further. It is already in its simplest form as an imaginary number.
What is the difference between the negative square root and the positive square root of a negative number?
The negative and positive square roots of a negative number are two different imaginary numbers. The positive square root is represented by the letter i, while the negative square root is represented by -i. They are the same distance from 0 on the imaginary number line, but in opposite directions.
How is the negative square root of a negative number used in math and science?
The negative square root of a negative number is often used in complex numbers and calculations involving imaginary numbers. It is also commonly used in engineering and physics to solve problems involving electrical circuits and wave functions.
Is it possible to take the square root of a negative number without getting an imaginary number?
No, it is not possible to take the square root of a negative number without getting an imaginary number. This is because the square root of a negative number is defined as an imaginary number, and there is no real number that when squared would result in a negative number.
