Manometer finding absolute pressure at P1
In summary, a manometer is a device used to measure the pressure of a fluid in a closed system. When using a manometer to find the absolute pressure at P1, the height of the fluid column on the side connected to P1 is measured and used in conjunction with the density of the fluid to calculate the pressure. This method is commonly used in industries such as HVAC and chemical engineering to accurately measure and monitor pressure levels.
TJSq
nxWvK
https://imgur.com/a/nxWvK this is the problem
P=Patm + dgh
I really just need to check if i did this right. I converted the densities to kg/m^3 and did p1= ((1121.689)(9.8)(.15) + ((1019.717)(9.8)(.04)) which gives 2048.61 Pa + 729mmHg which is 97.192 kPa so the answer would be 99.204 kPa
If you did the arithmetic correctly, your approach looks OK. But, I think they want the answer in mm Hg.
Related to Manometer finding absolute pressure at P1
What is a manometer?
A manometer is a device used to measure the pressure of a fluid in a closed system. It typically consists of a U-shaped tube filled with a liquid, such as mercury, and is used to compare the pressure of the fluid to the pressure of the atmosphere.
How does a manometer work?
A manometer works by using the principles of hydrostatics and fluid pressure. The liquid in the tube will rise or fall depending on the pressure of the fluid being measured. By comparing the heights of the liquid on either side of the U-shaped tube, the pressure difference can be determined.
What is absolute pressure?
Absolute pressure is the total pressure exerted by a fluid, including the pressure of the atmosphere. It is measured relative to a perfect vacuum and is typically expressed in units of Pascals (Pa) or pounds per square inch (psi).
How do you find the absolute pressure at P1 using a manometer?
To find the absolute pressure at P1 using a manometer, you will need to measure the height of the liquid on both sides of the U-shaped tube, as well as the density of the liquid and the acceleration due to gravity. Once these values are known, the absolute pressure at P1 can be calculated using the equation P1 = P2 + ρgh, where P2 is the pressure of the atmosphere, ρ is the density of the liquid, g is the acceleration due to gravity, and h is the height difference between the two sides of the tube.
What are some common uses of a manometer?
Manometers are commonly used in various industries, including HVAC, plumbing, and automotive, to measure pressures in closed systems. They are also used in laboratory settings for experiments and in medical devices, such as blood pressure monitors. Additionally, manometers can be used to measure and monitor fluid levels in tanks and other containers.
9K
27K
