danR
- 352
- 4
In the last hour. Also many post-items. Is there a glitch or failure? It's as though I've read almost everything in the Forums. I've never seen this before.
If you visit a forum, leave it and come back, quite often everything in that forum will appear greyed out as if it has been read. There is a reason this happens, but I can't remember it at the moment. Is that what you are referring to?danR said:In the last hour. Also many post-items. Is there a glitch or failure? It's as though I've read almost everything in the Forums. I've never seen this before.
Evo said:If you visit a forum, leave it and come back, quite often everything in that forum will appear greyed out as if it has been read. There is a reason this happens, but I can't remember it at the moment. Is that what you are referring to?
Sometimes the opposite happens, I'll read the new threads, they'll be grey, I leave and return and they're all bold again, even though there have been no new posts.
That was just a head's up from the mentor about the post being deleted. You're fine.danR said:I also got a warning for attempting to answer a post that appeared as any other. (It disappeared, along with my carefully written reply ), so I replied in a new post. There was nothing I recall about the OP that was delete-worthy; it seemed like some brand-new post. I try to help out like a good samaritan. It was really a quite unassuming naive topic that no-one else had answered yet.
Evo said:That was just a head's up from the mentor about the post being deleted. You're fine.
I've seen that happen, and my guess is this occurs if you are inactive for a while and get logged out. If you have "remember me" set, then you are automatically logged in again, but the software seems to assume that when you were timed out you had read everything on the site at that time.Evo said:If you visit a forum, leave it and come back, quite often everything in that forum will appear greyed out as if it has been read. There is a reason this happens, but I can't remember it at the moment.
I've also seen this, but only when browsing the site anonymously without logging in. In this case when you get timed out, the software seems to assume that you have read nothing on the site.Evo said:Sometimes the opposite happens, I'll read the new threads, they'll be grey, I leave and return and they're all bold again, even though there have been no new posts.
There could be a few reasons for this sudden change. It could be a problem with the website or forum itself, a browser issue, or a change made by the forum administrator.
It depends on the specific forum and which icons have turned grey. In most cases, greyed-out icons indicate that the feature or function is currently unavailable or disabled. However, you should still be able to navigate and use the forum as usual.
As a user, you likely do not have the ability to change the icons back to their original color. This is typically controlled by the forum administrator. However, you can try clearing your browser's cache and cookies or using a different browser to see if that resolves the issue.
If you believe the greyed-out icons are a problem with the forum or website, you can usually find a contact or support email on the forum's homepage or in the "About" section. You can also try reaching out to a moderator or administrator directly.
Unfortunately, there is no foolproof way to prevent this issue from occurring again. However, you can try keeping your browser and device updated, regularly clearing your cache and cookies, and reporting any issues you encounter to the forum administrator.
