Many-Particle Wavefunction Question
In summary: I have a question about density functional theory that I'm not sure where to turn for an answer. I've heard it's a very important tool in quantum chemistry, but I'm not sure how it works. Can you explain it in more detail?This is very fascinating. I have a question about density functional theory that I'm not sure where to turn for an answer. I've heard it's a very important tool in quantum chemistry, but I'm not sure how it works. Can you explain it in more detail?
CuriousLearner8
TL;DR Summary
Multi-particle wavefunction testable results?
Hello,
I hope you are well.
I have been doing a lot of readings on the wavefunction and have a question I did not see asked anywhere else in these forums. I was wondering if someone could shed some light on this for me?
I know the wavefunction is in 3N coordinate space and could be used to describe multiple particles. The greatest triumphs of Quantum Mechanics comes from single particle wavefunctions, however, such as predicted the spectra of hydrogen-like atoms. What are some examples of multiple-particle wavefunctions producing testable predictions that have been measured in the laboratory? If you have some papers I could read or look up, that would be most appreciated.
Thank you to you all.
Any multi-electron atom (i.e., any atom other than hydrogen) is an example for the success of many-particle physics, and it can be described by non-relativistic 1st-quantized multi-electron wave functions.
My understanding that no multi-electron atom has been successfully described by a multi-electron wavefunction because the math becomes difficult to disentangle. Did I misunderstand?
Yes, you misunderstood. Few problems in physics lead to closed form solutions. Even the three-body classical gravitational problem does not have a general closed form solution.
https://en.wikipedia.org/wiki/Closed-form_expression
https://en.wikipedia.org/wiki/Three-body_problem
This means that the solutions to specific physics problems lead to numerical approximations, that are nevertheless equally valid solutions to the problem.
Likes topsquark, vanhees71 and CuriousLearner8
Thanks for the response. I'm genuinely curious. What numerical approximations have we used for multi-particle systems? I'd like to learn more.
I'm very interested in close approximations matching experimental results. I'm working on a project, hence these questions.
After hydrogen comes helium:
https://www.math.hmc.edu/~dyong/math164/2007/reed/finalreport.pdf
One of the main hopes of quantum computing is that it will provide further numerical solutions to problems that are too hard for classical methods. E.g. optimising the production of ammonia:
https://digitalcommons.dartmouth.edu/cgi/viewcontent.cgi?article=1031&context=dujs
Likes topsquark and CuriousLearner8
Many thanks for these. If anyone has other examples as well, they would be much appreciated.
Mr Google might have a few!
Likes topsquark
I have checked, but seeking further input. :-)
This link may give you some ideas. Searching quantum chemistry is probably going to get you better results than multi-particle wavefunction.
Likes CuriousLearner8 and vanhees71
Much of solid state physics involves multiparticle solutions. Because of the periodicity it is often possible to find collective motions that look like nearly free quantum particles.
There are folks who have spent careers calculating the electron density in real world atoms to the precision afforded by the latest supercomputer.
And as @Haborix points out computational quantum chemistry is a real thing.
Likes CuriousLearner8, vanhees71 and PeroK
A.bit surprised nobody explicitely mentioned ''density functional theory'', or ''DFT''. Those are terms the OP should google and wikipediade.
FAQ: Many-Particle Wavefunction Question
What is a many-particle wavefunction?
A many-particle wavefunction is a mathematical function that describes the quantum state of a system consisting of multiple particles. It contains information about the positions, momenta, and other properties of all the particles in the system.
How is a many-particle wavefunction different from a single-particle wavefunction?
A single-particle wavefunction describes the quantum state of a system with only one particle, while a many-particle wavefunction describes the quantum state of a system with multiple particles. The many-particle wavefunction takes into account the interactions between the particles, which makes it more complex than a single-particle wavefunction.
What is the role of the many-particle wavefunction in quantum mechanics?
The many-particle wavefunction is a fundamental concept in quantum mechanics as it allows us to understand the behavior and properties of systems with multiple particles. It is used to calculate probabilities of different outcomes and predict the behavior of the system under different conditions.
How is the many-particle wavefunction related to the Pauli exclusion principle?
The Pauli exclusion principle states that no two identical fermions can occupy the same quantum state simultaneously. The many-particle wavefunction takes this principle into account and ensures that the overall wavefunction of a system of fermions is antisymmetric, meaning it changes sign when two particles are exchanged. This is known as the fermionic nature of the many-particle wavefunction.
Can the many-particle wavefunction be solved exactly for all systems?
No, the many-particle wavefunction can only be solved exactly for simple systems with a small number of particles. For more complex systems, approximate methods must be used to calculate the wavefunction. This is due to the inherent complexity of the interactions between multiple particles in a system.
12K
