MHB Map of Area Bounded by y=5x & y=-3x in Upper Plane
  • Thread starter Thread starter Amer
    Complex Mapping
The discussion focuses on determining the area bounded by the lines y=5x and y=-3x in the upper half-plane using the transformation w=1/z. The mappings for the lines are derived, resulting in w_1 and w_2, which correspond to the equations v=-5u and v=3u in the uv-plane. A specific point (0,1) is analyzed to confirm that it lies within the bounded area defined by these lines. The conclusion emphasizes that if (0,1) is included in the original z-plane area, its image must also be contained in the w-plane. The boundary lines and point mapping are validated in the context of the transformation.
Amer
what is the map of the area bound by y=5x and y=-3x in the upper half plane, under w=1/z we have the lines : $ z(t) = t + 5t i $ , and the line $z(t) = t - 3ti $
Fist line
$\displaystyle w_1 = \dfrac{1}{t+5ti} = \dfrac{1}{26t} - \dfrac{5i}{26t} $
Second
$\displaystyle w_2 = \dfrac{1}{t - 3ti} = \dfrac{1}{10t} + \dfrac{3i}{10t} $
We get the lines in the uv plane
$v = -5u \; , v=3u $
taking a point in the area for example (0,1) under 1/z (0,1) so we will take the bounded area between $v = -5u \; , v=3u $ which has the point (0,1)
is that right ?
Thanks
You have correctly found the boundary lines as $v = -5u$ and $v=3u $. But if the original area in the $z$-plane contains the point $(0,1)$ then the image in the $w$-plane should contain the image of that point under the map $w=1/z$.
  • · Replies 56 ·
11K
  • · Replies 67 ·
11K
  • · Replies 39 ·
13K
  • · Replies 121 ·
23K
