Marble around the loop-the-loop
  • Thread starter Lydia22
  • Tags
    Marble
In summary, to make the marble around the loop-the-loop without falling off, a track with a minimum height of h must be in place.
Lydia22
34
A marble rolls down a track and around a loop-the-loop of radius R. The marble has mass m and radius r. What minimum height h must the track have for the marble to make it around the loop-the-loop without falling off?
mgh = 1/2mv^2 + 1/2Iw^2
mgh= 1/2mv^2 + 1/2mr^2*v^2/r^2
gh=1/2v^2 +v^2
h=3/*2(v^2)/g
At the top of the loop
n+mg=mv^2 /r
it just need the minimum velocity therefore the normal will be zero
v=√gr
h=3/2*r which is incorrect please help
Is a marble rolling through the track or is a hoop rolling through?
What is the moment of inertia of a marble? :wink:
mgh= 1/2mv^2 + 2/5mr^2*v^2/r^2
gh=1/2v^2 +1/5v^2
h=1/10(v^2)/g
n+mg=mv^2 /r
v=√gr
h=1/10g
The marble is rolling in a hoop
gh=1/2v^2 +1/5v^2
h=1/10(v^2)/g
You'll have to double check your math. :smile: 1/2 + 1/5 isn't 1/10
n+mg=mv^2 /r
v=√gr
h=1/10g
The way you are approaching the problem is a good approximation if R >> r.
I'm not sure how precise you are supposed to get for this problem. But if you want to get technically exact, the radius of the loop-the-loop that the ball moves through not quite R. The marble has its own radius, meaning that the radius traversed by the ball's center of mass through the loop-the-loop is only R - r.
If r << R, this differences is negligible. But if you have a big marble and a small loop-the-loop it can be significant.
And there's something else that's very important too. The problem statement says,
Is h relative to the ground or to the top of the loop (i.e. 2R)? This makes a big difference.
gh = 7/10 [v]^2
[v]^2=10/7 gh
v=√gR-r
10/7gh =g(R-r)
h=10/7(R-r)
the height "h" is relative to the ground
Lydia22 said:
gh = 7/10 [v]^2
[v]^2=10/7 gh
v=√gR-r
10/7gh =g(R-r)
h=10/7(R-r)
By the way, I'm assuming that your above equation is [itex] h = \frac{7}{10}(R-r) [/itex].
Okay, that's the right idea, but it's making an assumption about h.
Your original formula, [itex] mgh = \frac{1}{2}mv^2 + \frac{1}{2}I\omega^2 [/itex], assumes that all of the gravitational potential energy mgh gets completely converted into kinetic energy.
The assumption your method makes is that h is relative to the center of the ball when it is at the top of the loop-the-loop.
In that case, you're not quite finished yet.
When the ball is at the top of the loop-the-loop (at a height of 2(R - r)) does it have any gravitational potential energy?
yes it will have gravitational potential energy ,so do i add the radius of the marble to the height?
You've done most of the work already. :approve: So you're almost there.
The way you've treated h so far, h is the height above the ball when the ball is at the top of the loop-the-loop (which is 2(R - r) above the ground). That's because in your original equation, you did not leave a gravitational potential energy term on the right hand side of the equation.
So if you add those two heights together, you'll have the minimum starting height of the ball relative to the ground. :smile:
[i.e (height from ground to ball at top of loo-the-loop)+(height from ball at top of loop-the-loop to starting height above that)]
Related to Marble around the loop-the-loop
1. What is "Marble around the loop-the-loop"?
"Marble around the loop-the-loop" is an experiment in which a marble is rolled around a circular track with a loop at one end. The goal is to understand the forces and momentum involved in the marble's motion.
2. How does the marble stay on the track?
The marble stays on the track due to a combination of centripetal force and gravity. The curved track provides the centripetal force that keeps the marble moving in a circular path, while gravity keeps it from flying off the track.
3. What factors affect the marble's speed around the loop?
The marble's speed around the loop is affected by the angle of the loop, the size of the loop, and the initial speed of the marble. A steeper loop, a larger loop, and a higher initial speed will result in a faster marble.
4. How does the loop's size impact the marble's motion?
The size of the loop impacts the marble's motion by changing the amount of centripetal force needed to keep the marble on the track. A larger loop requires more force, while a smaller loop requires less force. This can also affect the marble's speed and the force of impact when it reaches the bottom of the loop.
5. What can the "Marble around the loop-the-loop" experiment teach us?
This experiment can teach us about the principles of motion and forces, such as centripetal force and gravity. It can also demonstrate the effects of changing variables, such as loop size and initial speed, on the marble's motion. Additionally, it can help us understand concepts like momentum, velocity, and acceleration in a tangible way.
11K
