Marginal densities of a Probability
The discussion centers on calculating marginal densities from a joint probability density function for random variables Y1 and Y2. The user attempted to set up the limits of integration for the marginal functions f1(y1) and f2(y2) but expressed uncertainty about their correctness. Feedback indicates that the limits of integration should be from 0 to 1 for both variables, ensuring no variables appear in the limits or results. The expected values E(Y1) and E(Y2) must also adhere to these boundaries. Correctly setting the limits is crucial for accurate calculations in probability density functions.
RET80
Y1 and Y2 have a joint probability density function given by:
f(y1,y2) = {8y1y22, 0<=y1<=1, 0<=y2<=1, y12<=y2
0, Elsewhere
f1(y1) =ʃ f(y1,y2) dy2
f2(y2) =ʃ f(y1,y2) dy1
For E(Y) (later, discussed in part 3):
E(Y1) = ʃ y1f(y1,y2) dy1
E(Y2) = ʃ y1f(y1,y2) dy2
All integrals are set to -infinity to +infinity, which are then adjusted to the boundaries of the density function
I attempted both marginal functions and set the limits of integration as follows:
for f1(y1), limits of integration were: y1 to 1
for f2(y2), limits of integration were: sqrt(y2) to 0
With those limits of integration set up, I then solved for both separately and received the answers:
f1(y1) = 8/3y1 - 8/3y17
f2(y2) = 4y23
Now my question is, are my limits of integration setup correctly for this kind of question/equation. I don't think they are because after this, I solve for E(Y1) and E(Y2) and if I'm not mistaken, those must be whole numbers and not numbers with variables and if I use the same limits of integration that I used here, it will not work (or it will and just look awful). Not too sure here.
0, Elsewhere
f2(y2) = 4y23
You have them both correct. But remember, they are both valid for their variable from 0 to 1, and 0 elsewhere. So when you calculate expected values your integrals should go from 0 to 1; no variables in the limits or answers.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
