Marginal evidence for cosmic acceleration from Type Ia SNe
A recent paper published on ArXiv challenges the widely accepted notion of cosmic acceleration based on Type Ia supernovae (SNe Ia), suggesting that the data may be consistent with a constant rate of expansion. The authors, Jeppe Trst Nielsen, Alberto Guanti, and Subir Sarkar, argue that when accounting for light curve variations and dust extinction, the evidence for acceleration is only marginal. Critics of the paper note that while it raises valid points, it does not sufficiently undermine the standard Lambda Cold Dark Matter (ΛCDM) model, which remains supported by other cosmological tests like the Cosmic Microwave Background (CMB) and baryon acoustic oscillations. The discussion highlights the need for a comprehensive statistical analysis that incorporates multiple datasets to validate any claims against the standard model. Overall, this paper may provoke further investigation into the assumptions underlying cosmic expansion theories.
Garth
A paper was published on today's ArXiv that questions the empirical basis of the acceleration of the expansion of the universe: Marginal evidence for cosmic acceleration from Type Ia supernovae . The authors are: Jeppe Trst Nielsen1, Alberto Guanti1, and Subir Sarkar1;2 (1Niels Bohr International Academy and Discovery Center, Niels Bohr Institute, University of Copenhagen, Denmark and 2Rudolf Peierls Centre for Theoretical Physics, Oxford, UK).
On the thread Standard candle - in question - affects distance estimates , which has been closed for Moderation until a Moderator "who knows this stuff look into this", (BTW Has there been a decision?) I made the suggestion that an alternative linearly expanding model might also fit the data (https://www.physicsforums.com/threa...fects-distance-estimates.808071/#post-5079683).
Even treating the SNe 1a as standard candles, when a larger data base, in which due allowance is made for the varying shape of the light curve and extinction by dust, then the standard model may be brought into question. In the present paper we read:
The `standard' model of cosmology is founded on the basis that the expansion rate of the universe is accelerating at present - as was inferred originally from the Hubble diagram of Type Ia supernovae. There exists now a much bigger database of supernovae so we can perform rigorous statistical tests to check whether these `standardisable candles' indeed indicate cosmic acceleration. Taking account of the empirical procedure by which corrections are made to their absolute magnitudes to allow for the varying shape of the light curve and extinction by dust, we find, rather surprisingly, that the data are still quite consistent with a constant rate of expansion.
(emphasis mine)
Furthemore
Thus we find only marginal (< 3\sigma) evidence for the widely accepted claim that the expansion of the universe is presently accelerating.
Garth
Likes dlgoff, metapuff, PWiz and 2 others
Space news on Phys.org
Interesting. As I read it, their analysis clearly favours an accelerating model (best fit with a pretty decent likelihood ratio over alternatives) (fig 2 and table I), but due to larger error ellipses than in the standard analysis, they conclude that the "cleaned" data is not sufficient to conclusively reject the possibility of a linear expansion.
Likes slatts and marcus
All they seem to have done is relax the errors a bit and given they aren't doing anything significantly new like a Baysian approach their analysis isn't particular interesting. It was always the case that SN-1a was only really useful when combined with the CMB and the BAO data which have different probability distributions of the parameters. The difference between LambdaCDM and non-acclerating is small. This is what rules out non-acceleration.
This doesn't call the standard model into question, what their claiming is that in their analysis showed constant expansion isn't ruled out by one particular test. For this to have impact you would need to make the same claim in the face of the other 2 major tests of cosmology. To call the standard model into question you would have to show LambdaCDM was ruled out or in tension.
Likes nnunn and marcus
But people have made just such a claim, as I said in https://www.physicsforums.com/threa...fects-distance-estimates.808071/#post-5079683
1st other major test:
In the standard model the angular size of the first peak in the CMB power spectrum agrees with the angular size of sound speed limited fluctuations magnified by inflation at t ~ 380,000 years if space is flat.
In the R=ct model the CMB is emitted at t=12.5 Myrs, nearly 40 times later than in the standard model and the sound horizon limited fluctuations are similarly larger, however the hyperbolic space of the Milne model makes distant objects look smaller than in flat space exactly compensating for the enlarged size.
2nd other major test:
The same shrinking of angular measurement by hyperbolic space applies also to the 'standard ruler' of baryonic acoustic oscillations. They are larger than in the in standard model but have the same angular diameter, and also the shrinking of angular measurement applies to the baryon loading second peak of the CMB power spectrum.
There is a degeneracy in the CMB data as it confirms both the flat geometry of space in the ΛCDM model and the hyperbolic geometry of space of the Milne model.
Such as the tension between the standard model and a possible age problem?
Garth
But you're talking about this paper. Where is the joint statistical analysis considering the other data sets as well? I see your hypothesis but where has that been tested in statistical rigour?
The "age problem" is not a cosmological test. It's a calculation involving both cosmology and galaxy formation, for that reason people don't use results like that for cosmology. It's convoluted and impossible to tell where the issue lies.
ruarimac said:
But you're talking about this paper. Where is the joint statistical analysis considering the other data sets as well? I see your hypothesis but where has that been tested in statical rigour?
I was originally talking about the OP paper, however in my comment "But people have made just such a claim" I was responding to your post #3, "For this to have impact you would need to make the same claim in the face of the other 2 major tests of cosmology."As I said in my post referred to in the OP "One alternative model is the linearly expanding model proposed by various authors under different guises such as: http://arxiv.org/abs/astro-ph/0306448%5B/URL[/URL],[URL='http://arxiv.org/PS_cache/arxiv/pdf/1110/1110.3054v1.pdf'] Introducing the Dirac-Milne universe[/URL], [URL='http://www.aanda.org/articles/aa/pdf/2013/05/aa20447-12.pdf']The Rh = ct universe without inflation[/URL]
Such a model expands as the Milne empty universe and requires either an EoS of ω=−1/3 or replusive antimatter as in the Dirac-Milne theory in order to produce the Milne model without it being empty."Now I agree that as a heterodox alternative to the [itex]\Lambda[/itex]CDM model there has been relatively little work done on the linearly expanding model, and therefore it has not been tested to the same degree of rigour, however authors that have written about it have found a surprising concordance with various data sets.
(viz: [URL='http://arxiv.org/abs/astro-ph/0306448'] A Concordant “Freely Coasting” Cosmology[/URL], [url=http://www.worldscinet.com/ijmpd/09/0906/S0218271800000682.html]Nucleosynthesis in a universe with a linearly evolving scale factor[/url], [URL='http://arxiv.org/abs/astro-ph/0502370']A case for nucleosynthesis in slowly evolving models [/URL], and the OP link.)
[quote]The "age problem" is not a cosmological test. It's a calculation involving both cosmology and galaxy formation, for that reason people don't use results like that for cosmology. It's convoluted and impossible to tell where the issue lies.[/QUOTE] Agreed, however with such objects as the ultraluminous quasar, SDSS J010013.02+280225.8, a BH ~1.2 × 10[SUP]10[/SUP]M[SUB]⊙[/SUB] seen at z=6.30 - 900 Myrs after BB - (alongside about 40 other quasars at z>6) there does appear to be at least a tension with the standard model. Note the problem in getting such an behemoth to form with Super Eddington accretion, say by direct collapse, is that such a process would not be bright - you need an accretion disc.
(cf. the [I]Nature[/I] letter [URL]http://www.nature.com/nature/journal/v518/n7540/full/nature14241.html#close[/URL]which can be read on the physics arXiv [URL='http://arxiv.org/pdf/1502.07418.pdf']here .[/URL])Garth
<<Mentor note: Moved from separate thread>>
This paper - http://arxiv.org/abs/1506.01354, Marginal evidence for cosmic acceleration from Type Ia supernovae, calls into question the original SNe-Ia data based conclusion favoring accelerated expansion of the universe. Utilizing additional SNe-Ia data, the authors instead contend the luminosity data does not rule out a constant expansion universe. This appears to apply the brakes to the LCDM model and appears it will make its way into the popular media in rather quickly.
Garth said:
A paper was published on today's ArXiv that questions the empirical basis of the acceleration of the expansion of the universe: Marginal evidence for cosmic acceleration from Type Ia supernovae . The authors are: Jeppe Trst Nielsen1, Alberto Guanti1, and Subir Sarkar1;2 (1Niels Bohr International Academy and Discovery Center, Niels Bohr Institute, University of Copenhagen, Denmark and 2Rudolf Peierls Centre for Theoretical Physics, Oxford, UK) and it has been accepted for publication in 'The Astrophysical Journal'.
Even treating the SNe 1a as standard candles, when a larger data base, in which due allowance is made for the varying shape of the light curve and extinction by dust, then the standard model may be brought into question. In the present paper we read: (emphasis mine)
Furthemore
Garth
It might fit the supernova data, as the error bars are pretty large. But there's no way it's going to fit the supernova data, the CMB data, and the baryon acoustic oscillation data at the same time.
Likes bcrowell
There are varying opinions on this point, Chalnoth, like http://arxiv.org/abs/1304.1802, Cosmic Chronometers in the R_h=ct Universe. I still view the OP paper as a serious challenge to LCDM.
Yeah, I don't buy that for an instant. His paper that discusses the CMB, for instance, is here:
http://arxiv.org/pdf/1207.0015.pdf
This paper is extremely thin motivation. The fundamental problem is that the ##R_h = ct## universe cannot produce a nearly scale-invariant power spectrum. You can see this complete and utter failure in fig. 6 of the paper, where he plots the first few multipoles of the CMB power spectrum as measured by WMAP. This plot is extremely revealing because he doesn't even bother to try and plot the higher multipoles as measured by WMAP. The richest information in the CMB starts at around ##\ell = 200##, and WMAP measured the power spectrum pretty well out to about ##\ell = 800## or so. He only plotted up to about ##\ell=50##, barely using the data at all. He completely ignores this figure in the text, probably because this figure completely destroys his analysis: the ##R_h=ct## universe diverges wildly from the WMAP observations by ##\ell=20##, which is barely scratching the surface of the richness of available data.
So no, the ##R_h = ct## model cannot possibly explain our universe. Its theoretical motivation is nonexistent and it cannot fit the data.
Garth said:
I was originally talking about the OP paper, however in my comment "But people have made just such a claim" I was responding to your post #3, "For this to have impact you would need to make the same claim in the face of the other 2 major tests of cosmology."snip
Agreed, however with such objects as the ultraluminous quasar, SDSS J010013.02+280225.8, a BH ~1.2 × 1010M seen at z=6.30 - 900 Myrs after BB - (alongside about 40 other quasars at z>6) there does appear to be at least a tension with the standard model. Note the problem in getting such an behemoth to form with Super Eddington accretion, say by direct collapse, is that such a process would not be bright - you need an accretion disc.
(cf. the Nature letter http://www.nature.com/nature/journal/v518/n7540/full/nature14241.html#closewhich can be read on the physics arXiv here .)
Garth
What I said was "This doesn't call the standard model into question, what their claiming is that in their analysis showed constant expansion isn't ruled out by one particular test. For this to have impact you would need to make the same claim in the face of the other 2 major tests of cosmology." Nobody has done that. Claiming you believe they will fit the data is irreverent, that's a hypothesis. You wanted to talk about the paper talk about the paper, not 20 others which do not address the point.
On the question of age, no there is no tension with Lambda CDM. There is tension with the product of some models of supermassive black hole formation and LambdaCDM. You can't ignore the assumptions made. Now, if everyone was agreed on how you form supermassive black holes that could be an issue but there are a good few mechanism. Hierarchical assembly for example has no limit to growth. It's a false assumption to say a body which grew like this couldn't be bright, it doesn't have to get bright via the mechanism that formed it.
Well, I started by just talking about the OP paper, and mentioned the closed PF thread on the question over SNe 1a as standard candles because it was relevant. You raised the point over two other major tests and I responded to that. Are you objecting to the fact that your assumptions may be challenged by reference to other papers?
Well there is a tension, i.e. a problem, in explaining how these behemoths formed apparently so early and the tension keeps reappearing such as here: - http://arxiv.org/abs/1506.01377[/PLAIN] -The Impossibly Early Galaxy Problem (thank you Chronos for that link by pm).
The current hierarchical merging paradigm and ΛCDM predict that the z∼4−8 universe should be a time in which the most massive galaxies are transitioning from their initial halo assembly to the later baryonic evolution seen in star-forming galaxies and quasars. However, no evidence of this transition has been found in many high redshift galaxy surveys including CFHTLS, CANDELS and SPLASH, the first studies to probe the high-mass end at these redshifts. Indeed, if halo mass to stellar mass ratios estimated at lower-redshift continue to z∼6−8, CANDELS and SPLASH report several orders of magnitude more M∼1012−13M halos than are possible to have formed by those redshifts, implying these massive galaxies formed impossibly early. We consider various systematics in the stellar synthesis models used to estimate physical parameters and possible galaxy formation scenarios in an effort to reconcile observation with theory. Although known uncertainties can greatly reduce the disparity between recent observations and cold dark matter merger simulations, even taking the most conservative view of the observations, there remains considerable tension with current theory.
Garth
I made no assumption, their paper is totally lacking in important information. An objective fact. No one else has done this and for some reason you felt obliged to spam unrelated papers. I came here to talk about a paper, not for you to push some cosmology which only exists by ignoring easily available data.
The objective reader will also notice the "Impossibly Early Galaxy Problem" contains only one set of stellar mass functions. That's just complete nonsense, you cannot pick one model of galaxy formation and declare job done. That's simply indefensible.
I find it strange to claim that data which clearly supports the hypothesis of accelerating expansion over others, albeit not as strongly as other data, should be taken as a challenge of that hypothesis or as support for an alternative it describes as about 150 times less likely, on a par with "empty universe" (cf. table I in the paper).
It only says "contrary to other studies finding accelerated expansion more than 1000 times more likely than constant expansion, we find the ratio to be only 150".
Likes marcus
Firstly may I belatedly welcome you to these Forums ruarimac, your contributions will be much appreciated. I didn't notice that you were a new member when you first posted.
I referred to the linearly expanding model just because it was mentioned in the OP paper as being "rather surprisingly" consistent with the data and we had already discussed it in the earlier thread.
Otherwise the OP paper does not disprove the standard model, just that the evidence for acceleration is more marginal than previously thought.
So would other sets of stellar mass functions explain how the reported number of massive halos could have formed at such high red shifts?
Garth
Enjoying the discussion. thanks all, appreciative welcome to Nuari.
I hope without distracting active participants to insert a pedagogical footnote for any reader unfamiliar with the way positive cosm. curvature const. is deduced from the Type!A Sne data.
The dimness of standard candle supernovae indicates their distance and the redshift luminosity data boils down to redshift-distance data.
In this graph I use the variable S = z+1. The distance to a source is proportional to the area under the curve from 1 to S.
Each curve corresponds to a different estimate of the curvature constant Lambda. that is, to a different asymptotic (long term) expansion rate H. Different possible H are denoted by their corresponding Hubble radii expressed in billions of years. The possibilities are 16.3, 17.3 (the current estimate), 18.3, 40, 1000. The Λ corresponding to a Hubble radius of 1000 billion LY is effectively zero, a negligible curvature constant. There is a big gap between the neighborhood of the current estimate of Λ curve (17.3), and the zero Λ. That gap is the reason people can confidently talk about zero Λ being "150 times less likely." there is a big difference between the areas under the curves.
Likes Garth and wabbit
Hi wabbit, the paper is not suggesting the standard \LambdaCDM model is to be replaced by the original 'vanilla' zero \Lambda model, as I said above, it finds that the 'constant rate of expansion' (linearly expanding) model (with EoS p = -1/3 \rho) is 'rather surprisingly, still quite consistent' with the data.
Garth
Garth
It's only consistent with a small, cherry-picked fraction of the data.
Garth
Right, but "quite consistent" still means "only 150 (closer to 250 actually) times less likely than their best fit showing an accelerated expansion with ## \Omega_\lambda\simeq0.6 ## " (using the term likely in a loose way, just translating their LLH figures here) - their fig 2 shows that the unaccelerated line just barely escapes being excluded.
As I read it, what they show is that their model may still have a fighting chance if all errors happen to favor the standard model by chance.
LCDM may very well be incorrect, but their model seems a rather unlikely cure in that case, based on their data and their analysis.
Just to add, I have no expertise in these models, just questionning their formulation given the numerical results they show. To me, their statistics simply do not support their conclusions - at best they show that their model is not completely ruled out.
The paper is claiming that because the single model they used cannot fit the stellar mass function it is impossible to do it under LambdaCDM. That's just bonkers. Imagine if after Edison's lab's first attempt at commercial light bulbs they declared it was impossible after trying just one design. Galaxy formation is not a one track field, there are dozens of models. The paper is logically unsound.
They openly ignore ab initio simulations like Illustris citing that it doesn't reproduce the stellar mass function even at redshift zero, they ignore the fact that this sink's there entire paper. Illustris, one of the two extremely advanced cosmological hydro simulations cannot reproduce exactly what we have observed for decades, what this shows is that galaxy formation is not finished to the point you can make absolute claims as they do. I really doubt such minor changes to the cosmology as you propose would make any difference. Similar simulations have done runs on no cosmological constant and it doesn't affect the galaxies.
To add one other thing: I'm pretty darned sure that the ##R_h = ct## model will not come anywhere close to predicting the right primordial element abundances.
It will be difficult to!
There is Nucleosynthesis in a Universe with a Linearly Evolving Scale Factor. (Int. J. Mod. Phys. D 09, 757 (2000))
In this article nucleosynthesis is explored in models in which the cosmological scale factor R(t) increases linearly with time. This relationship of R(t) and t continues from the period when nucleosynthesis begins until the present time. It turns out that weak interactions remain in thermal equilibrium upto temperatures which are two orders of magnitude lower than the corresponding (weak interaction decoupling) temperatures in SBB. Inverse beta decay of the proton can ensure adequate production of helium while producing primordial metallicity much higher than that produced in SBB. Attractive features of such models are the absence of the horizon, flatness and age problems as well consistency with classical cosmological tests.
Other eprints suggest that the baryon density is increased to about \Omega_bh2= 0.3, the model leaves a Deuterium problem but may ease the Lithium problem of standard BBN.
Another old paper that looked at the problems is Nucleosynthesis in power-law cosmologies (Physical Review D, Volume 61, Issue 10, 15 May 2000)
Garth
Likes nnunn
There is Nucleosynthesis in a Universe with a Linearly Evolving Scale Factor. (Int. J. Mod. Phys. D 09, 757 (2000))Other eprints suggest that the baryon density is increased to about \Omega_bh2= 0.3, the model leaves a Deuterium problem but may ease the Lithium problem of standard BBN.
Garth
So, in other words, it doesn't come close to fitting the data. In the second paper they state:
"Furthermore, consistency with 4He at ##\alpha = 1## requires a very high baryon density ##(74 \leq \eta_{10} \leq 86## or ##0.27 \leq \Omega_{B}h^2 \leq 0.32)##, inconsistent with non-BBN estimates of the universal baryon density and, even with the total mass density."
Yes, as I said above Ωbh2 = 0.3, and with h ~ 0.7 and with R = t^{\alpha} where \alpha = 1, the calculation would give \Omega_b ~ 0.6, i.e. roughly twice the total mass density.
However, if you look at Nucleosynthesis in power-law cosmologies Figure 2, a value of \alpha slightly greater than unity, about 1.03 or thereabouts would halve \Omega_b to around 0.3 and would therefore explain most of DM as dark baryonic matter.
A value \alpha just greater than 1 would keep the advantage of the theory not requiring Inflation as it would still not have the horizon, density and smoothness problems, and would be indistinguishable from the strictly linear expanding model in the SNe 1a analysis.
Now I'm not claiming to be able to solve all the problems but I find it intriguing!
Garth
Garth
Except ##\Omega_b## is less than ##0.05##. This really doesn't come close. Also, ##\alpha = 1.03## is no longer the ##R_h = ct## model.
It is impossible for dark matter to be baryonic, as prior to the emission CMB it couldn't have been dark.
But no, this is so far off I don't know why it's being discussed at all. ##\Omega_b = 0.3## is over a hundred standard deviations from WMAP's 9-year estimate of the parameter.
Just to enrich the discussion, we have published a model conciling a linear expansion universe today, and for most of their history, with an early decelerating universe close to the standard model, so that the most salient features of observational cosmology are accommodated, avoiding the age problem of some very old quasars. This steady flow model also avoids the horizon, flatness, cosmological constant and coincidence problems without the need of neither inflation nor initial fine-tuning:
http://link.springer.com/article/10.1007/s10509-012-1349-2
However, apparently this paper has not deserved any attention so far...
Hi Juan,
Thank you for that link, I would be very interested in reading it but find the £29.95 a bit steep for an independent like me!
Any chance of putting the original text (pre-refereed) on the physics arXiv ?
Garth
Hi Garth,
Thank you for your interest. You can download it in here:
https://www.researchgate.net/publication/251572020_steady_flow_cosmological_model
By the way, primordial nucleosynthesis is not an issue in the Steady Flow model...
JuanCasado said:
Hi Garth,
Perhaps we can discuss it in a new thread.
I would like to return to discussing the OP 'Marginal' paper.
I am finding the statistical analysis a little obscure, so thank you marcus for your 'pedagogical footnote'! I am unfamiliar with your usage and definition of H_{\infty} which of your curves is the Milne (hyperbolic space) model? (Isn't its corresponding Hubble radius 13.8 billion Ly?)
Garth
  • · Replies 30 ·
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 46 ·
