Marginal rate of technical substitution for a production function
In summary, to find the marginal rate of technical substitution for the given production function, we first calculated the partial derivatives with respect to labor and capital. Then, we took the ratio of these partial derivatives to obtain the MRTS. Simplifying the expression, we found that the MRTS is equal to 4 times the ratio of labor to capital raised to the power of -3.
claratanone
Find the marginal rate of technical substitution for the following production function:
\(\displaystyle Q=10(0.2L^{-0.5} +0.8K^{-0.5})^{-2}\)
Here is my attempt so far:
\(\displaystyle \frac{\delta Q}{\delta L}=[10(-2)][0.2K^{-0.5}+0.8L^{-0.5})^{(-2-1)}*[0.8*(-0.5)]L^{(\frac{-1}{2}-1)}=[(-20)*(-0.4)](0.2K^{-0.5} +0.8L^{-0.5})^{-3} *L^{\frac{-3}{2}}=8(0.2K^{-0.5}+0.8L^{-0.5})^{-3} *L^{\frac{-3}{2}}\)
\(\displaystyle \frac{\delta Q}{\delta K}=[10(-2)](0.2K^{-0.5} + 0.8L^{-0.5})^{(-2-1)}*[0.2*(-0.5)]K^{(\frac{-1}{2}-1)}\)
\(\displaystyle =[(-20)*(-0.1)](0.2K^{-0.5} +0.8L^{-0.5})^{-3}* K^{\frac{-3}{2}}=2(0.2K^{-0.5}+0.8^{-0.5})^{-3}K^{\frac{-3}{2}}\)
Is this all correct so far?
What do I do next?
Would anyone be able to guide me through the rest?
Mathematics news on Phys.org
Yes, your calculations so far are correct. To find the marginal rate of technical substitution (MRTS), we need to take the ratio of the partial derivatives you have calculated:
MRTS = \frac{\frac{\delta Q}{\delta L}}{\frac{\delta Q}{\delta K}} = \frac{8(0.2K^{-0.5}+0.8L^{-0.5})^{-3} *L^{\frac{-3}{2}}}{2(0.2K^{-0.5}+0.8L^{-0.5})^{-3}* K^{\frac{-3}{2}}}
Simplifying this expression, we get:
MRTS = \frac{4L^{-3}}{K^{-3}} = 4\left(\frac{L}{K}\right)^{-3}
Therefore, the marginal rate of technical substitution is equal to 4 times the ratio of labor to capital raised to the power of -3. This means that as we increase the amount of labor used in production, the amount of capital needed decreases by 4 times the ratio of labor to capital. Similarly, as we increase the amount of capital used, the amount of labor needed decreases by 4 times the ratio of capital to labor.
I hope this helps guide you through the rest of the problem. Let me know if you have any other questions. Good luck!
FAQ: Marginal rate of technical substitution for a production function
1. What is the marginal rate of technical substitution (MRTS) for a production function?
The marginal rate of technical substitution refers to the rate at which one input can be substituted for another while keeping the same level of output. It is an important concept in production theory as it helps to determine the optimal combination of inputs for a given level of output.
2. How is the marginal rate of technical substitution calculated?
The marginal rate of technical substitution is calculated by taking the partial derivative of the production function with respect to the two inputs and then dividing one by the other. The formula can be written as MRTS = ∂F/∂x / ∂F/∂y, where x and y are the two inputs and F is the production function.
3. What does a high MRTS value indicate?
A high MRTS value indicates that the two inputs are highly substitutable for each other. This means that a small change in the quantity of one input can result in a significant change in the quantity of the other input while keeping the same level of output. In other words, the inputs are flexible and can be easily interchanged.
4. Why is the MRTS important in production analysis?
The MRTS is important because it helps to determine the most efficient combination of inputs for a given level of output. By calculating the MRTS, producers can identify the optimal ratio of inputs that will minimize costs and maximize production. It also helps in understanding the substitutability and complementarity between different inputs.
5. Can the MRTS change at different levels of production?
Yes, the MRTS can change at different levels of production. This is because as production increases, the marginal product of each input may change, leading to a change in the optimal ratio of inputs. This means that the MRTS is not a constant value and can vary depending on the level of production.
